boxing a frame i need some tips
Discussion in 'The Hokey Ass Message Board' started by 331caddy, Mar 19, 2004.
  1. 331caddy
    331caddy
    im gonna box the frame on my 31 A..... what guage steel should i use and how far up should i go with the boxing.
    thanks guys
  2. bobbleed
    bobbleed
    from Awesome
    3/16". All the way.
  3. No Shine 53
    No Shine 53
    1/8" works too.
  4. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I did one last month. I made templates of the frame, one for ahead of the stock middle crossmember and one to rear. I took the templates to my local welding shop that has a huge shear. He used my patterns and made me the 4, 1/8" boxing plates plus the two 1/8" plates for the inside the crossmember and charged me $20.00. The next time I do this I will have the plates made a little smaller. It will make it easier to set them inside the frame and allow a small gap to make a better weld.
  5. Thirtycoup
    Thirtycoup
    i used 3/16" end to end
  6. 1/8" will do it.
    It's what the ch***is shops use.
    Take a look at some of the ads and you'll get a good idea of what's required where.
    You will want openings for various things.
    Fwiw - my Deuce factory frame with 1/8" boxing plates under the 32 roadster with tube axle up front just rolled over 40,000 miles with no problems.
    That's with a torquey 462" Buick and running some of the rough roads near the house as well as Highway 99 which is pretty beat up by the big trucks.
  7. gotcha
    gotcha
    from Sanger, TX
    I use 3/16 when I do notches, but for boxing, 1/8 is all you need...
    JP
  8. jub
    jub
    from York, Pa
    I used 3/16, made templates front ot back had them cut at local metal shop, to fit inside the frame rail so they sat back in a 1/8, I think this way it is stronger.
  9. 331caddy
    331caddy
    thanks for the tips guys this week i should be getting into this deal... ill have some progress pics coming soon..
    thanks again
  10. Rusty
    Rusty
    Great guys I was going to ask this question myself. Almost finished wiring my shop so I can get started. Will update pics as I get them.
  11. CGkidd
    CGkidd
    What do you guys recommend for welding on frames Wire feed or Stick? Just curious. I am getting ready to start boxing my frame soon.
  12. trey
    trey
    i used wire feed for my dodge frame. man, thats a lot of friggin welding!!! no twisty twisty now though.
    trey
