I started using Shell Rotella T a while back in a few of my engines because of the lack of zinc issue. It seems to me that an engine that puffs a little oil now and then just plain smells bad. Oil smoke has always been an old familiar smell to me that was non offensive. This stuff stinks! Is it just me, or have any of you all noticed it too? ...And don't tell me you've never had an oil burner either. -Mike
It does. I run it in my ***mins and when I change oil, it takes a couple o'days to burn off the filter spillage. I drive with my head out in the breeze til it clears up. Dan
my boss always adds a pint of Lucas Diesel Additive to Rotella in his tow trucks....seems to work great after 2years,and 85,000+miles and i really Hate the smell of diesel.this stuff seems to help.
lol! Thats fuuny! I pulled up to a 7 11 the other day and some lady asked why my car stinks. i have used rotela oil for years and must be used to the smell! the old 'bird burns a little oil but still burns rubber to!
It's not you---I worked at a shop ,and the owner swore by Rottela---and yes, that **** stinks bad---after a while, my hands smelled like it. It took almost a year to get rid of the smell!
The reason it stinks is because it's a Group III Hydrocracked Petroleum Basestock...basically it's in the middle of being synthetic and conventional. If it smells like sulpher, then it's a bad batch, call Shell and they'll replace it. I run Shell Rotella T 15w-40 in my hopped up ***mins Turbo Diesel Dodge pickups and I only smell the funk during oil changes. I'm pretty **** about cleaning up any spillage with solvents so the underside of the truck looks spotless.
I ran the stuff in a 350 that I had for about 3 years. Never noticed any odd smells. I did, however manage to still wipe out 3 camshafts, despite using Rotella for its zinc-whatever-phosphate. I figured that a lot of the lifter bores were bad, and I did go through the whole engine each time, replacing bearings, checking journals for scoring, and had the engine hot-tanked and cleaned, etc. The cam that came with the engine was fine, and had served for 60,000 miles of the engine's life. I would have put it back, had I not mixed the lifters up. But yeah, I never smelled any thing from the oil.
we heard you the first time! i guess i have to explain for the retarded. after every oil change 6500 miles between each he uses Lucas...sheeeesh is that better?..
