Pic Request - 28-29 with recessed firewalls
Discussion in 'The Hokey Ass Message Board' started by Spark Plug, Feb 14, 2007.
  1. Spark Plug
    Spark Plug
    from Duvall, WA
    Been working on my old man's 29 Roadster trying to get it out of my way.
    He's running a SB Chev so I had to put in a Sac Vintage 4" recessed firewall. Now I am not sure how I am going to get the steering column through it. The steering column is a flaming river tilt column (sorry, he's old & arthritic as long as he's paying the bills I'll build it however he wants it).
    Anyone have any pics of similar setups. Where'd you end up cutting the hole at? Thanks in advance for help and ideas. I'll try to post some pics later if anyone needs/wants to see them.
  2. swade41
    swade41
    from Buffalo,NY
    Need more info like what kind of box are you mounting it to.
    I would take wooden dowl mock up for fit on the inside , take a dial indicator and see how many degrees it is. Measure up from the bottom of the firewall to bottom of dowl and tranfer measurements and degrees to the engine side.
    You'll have to drill your hole at the same degrees to get a nice tight fit too.
  3. Spark Plug
    Spark Plug
    from Duvall, WA
    Sorry, minor detail...Vega box.
    I'll see if I can get the pics to display. To me the way the column will exit the firewall into the enging bay will be right in the bend of the 4 in recess. I just hoping that someone else has this same configuration and could post some pictures of how theirs is punched through.
    Thanks,
    Chad
  4. sometimes the column has to go where it need to be...that means you will probabilly end up with a real odd shape hole. but the hole should look round when looking down the column. hope that nakes sense.
    mark the center of the hole and do what you need to make a tight fitting hole...you can use a hole saw at the proper column angle if you use a long pilot bit
    this is about the only picture i could find on my computer that may give you an idea:
  5. attitudor
    attitudor
    from Finland
    bttt
    I need this info as well...
    Not the steering column though, but trying to build a good-looking recess...
    Thanks.
  6. bradslowmodela
    bradslowmodela
    something i did on my 1930 sedan was i cut the original firewall out and flipped it and welded the thing inside out. i now have a factory mod that looks original.
  7. scootermcrad
    scootermcrad
    Just a concern... is that that final resting place for the transmission? The cutout for the transmission and tunnel seems pretty tight. Are you going to get interference once things really start flexing and moving around?
    Just an observation. Not being critical. Only curious. Just seemed a little tight and wondered if there was a reason for it.
  8. Spark Plug
    Spark Plug
    from Duvall, WA
    That is certainly a concern I have and trying to make sure I have clearence. Right now nothing is touching. The car will be full fendered and still has 1/4" of rubber body pads to go down plus the thickness of the fender/spalsh apron.
  9. revkev6
    revkev6
    from ma
    one more concern for ya. being a 28-29 body, and stating that your father is old and arthritic, why owuld you decide to torture him by further cramping the ****pit with a 4" recess! my 28 roadster is maxed out with me driving it with a stock firewall. I'm 5' 7"
  10. Spark Plug
    Spark Plug
    from Duvall, WA
    Mainly the body was what we had available. Second its actually a sport coupe that has been made into a roadster and I am able to position the seat back far enough to where he cand stretch his legs far enough to be comfortable. The recess was needed for the small block chevy powerplant which is the only reason for it. The frame with motor and trans was already setup for my 31 Tudor, but that project has been sidelined for now, thus putting his Roadster body on it and getting him something to enjoy, while he can.
    Build it on a budget with what you got, right?!?
  11. This is a model A with a 4" recesed firewall and a chevy smallblock.
  12. Spark Plug
    Spark Plug
    from Duvall, WA
    Thank you! That helps a lot. Granted the recess is done differently, but with your pictures I can visualize it a little easier. Just waiting for my column drop to show up from Speedway so I can get rolling on it.
    Thanks again.
  13. 28Abone
    28Abone
    from Toronto
    Hi there I'm building a 28 coupe and used a *****ing firewall it to has curve were the steering has to go through , what I did was cut out a hole an make it to the toe kick angle . Then boxed in the other side.
    (see pic's) I hope this helps.
    [​IMG][​IMG]
  14. Spark Plug
    Spark Plug
    from Duvall, WA
    Awesome, thanks. The thought of cutting out the area and boxing it didn't even cross my mind. I really do appreciate everyones input.
    Thanks,
    Chad
  15. 28Abone
    28Abone
    from Toronto
    No problem.... It had taken me quite a while to do it with the older model A's is you don't have much room to work with. Get all your parts together and go from there. make carboard templates then cut the steel. It would nice if you had a old cowl ***embly , make sure you have the person who is going drive the there. Wooden dowels are great for figuring out shaft lenghts, and the seat is in the right location. Good luck with it.
    28Abone.
  16. 28Abone
    28Abone
    from Toronto
    Hi there again just in case you didn't get my pm. I though you might likr to see how the pro's do it...... The web page is http//hotrodscustomstuff.com/GonzModA-o6.html.
    28Abone.
  17. Spark Plug
    Spark Plug
    from Duvall, WA
    This is a perfect example, thanks. Now if the column drop would just get here already so I can start working again!
