adapters for inline sixes
Discussion in 'The Hokey Ass Message Board' started by Saoutlaws_Gotti, Feb 18, 2007.
  1. Saoutlaws_Gotti
    Saoutlaws_Gotti
    is there any kinda adapters out there to bolt a late model 250 straight 6 to my 3 on the tree ****** in my 53 chevy
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    The 250 has the same bellhousing pattern as any small block Chevy. You can adapt a Chevy to anything! Try Wilcap first, I don't have their info handy.
  3. I'm not certain, but you may be able to just use a stock early SB bellhousing.
  4. Saoutlaws_Gotti
    Saoutlaws_Gotti
    well ive got several old school bellhousings that may be a possiblity
  5. RatInfested
    RatInfested
    Offenhauser made that adapter bellhousing in the 60's. Stock 49-54 three spd trans bolts right up to it. You use all your stock parts, flywheel, pressure plate, disk, throwout bearing. Bolts up to any Chevy motor. I used it on my 53 in 1974 with a 327. Worked just fine. Tore up a bunch of trannies though hole-shotting it! Still got it. For the right price I might unload it.
  6. cwatson1953
    cwatson1953
    if you don't mind let me know what you find out...i've got a 292 that i'm gonna put in my '53 and i'd like to keep the 3 on the tree for a little while, but from what i've been told i'd be better off finding a t-5 or 4 speed through the floor....
    i guess its really ALL possible, just depends on how far you want to take it. :D
    take care.
    Chris
  7. RatInfested
    RatInfested
    Sorry, I goofed. Can't use stock flywheel on that conversion. It's been so long since I did that I don't even remember if I used the original pressure plate and disc or not. It all depends if it will bolt up to a later model flywheel or not. You'll have to check that out.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    There were such adapters, but I don't see them very often. It would probably be easier to find a
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    There were such adapters, but I don't see them very often. It would probably be easier to find a three speed transmission from a '48-'54 Chevy truck, which has the correct bolt pattern to bolt up to a 292 bell housing.
  10. enjenjo
    enjenjo
    from swanton oh
    use a 49 to 54 Pickup trans. It will bolt to the stock torque tube, and a stock later model bellhousing.
  11. cwatson1953
    cwatson1953
    back on this....i picked up a '54 P/U ******, and unless i'm retarded(it is possible) there is no way that bell housing will work on my 292.
    that or i picked up WHAT I THOUGHT was a '54 P/U ******....heh....
  12. Stovebolt
    Stovebolt
    I haven't tried this...... but why not look at making a sleeve to go over the locating ring on the 53 trans, to allow it to locate the gearbox onto the later bellhousing. The diameter of the hole on the Pre 55 gearbox is considerably smaller then on the post 54 and truck boxes.
    The input shaft diameter is the same length as the later 'boxes, and the spline on the clutch is the same. Use the clutch setup for the later engine and bellhousing.
    You will have to redrill your bellhousing for the gearbox bolt pattern.
    Like I said I haven't done it.... but it makes sense to me anyway.
  13. cwatson1953
    cwatson1953
    that does make sense, although it may be more work than is needed....if i'm gonna go that far...i'd probably be better off just doing a rea-end/****** update.
    thanks for the idea though, i'm gonna look at it when i get home and see.
  14. mtkawboy
    mtkawboy
    You might check out inlinersinternational.com
  15. 53sled
    53sled
    from KCMO
    inliners.org
  16. cwatson1953
    cwatson1953
    yea, i love that site, alot of cool stuff!
  17. 6inarow
    6inarow
    you are probably stuck either going to the 235/261 or early gmc series engine or swapping the trans and torque tube if you keep the 250/292 series engine. It s just not practical to use the earlier trans with the later motor
  18. cwatson1953
    cwatson1953
    yea i know...i'm just being impatient and wanting to drive it NOW! haha.
    but yea, i'm leaning more and more toward just doing the rear end/****** swap.
    thanks.
  19. RichFox
    RichFox
    When I was running a 270 or 302 GMC I used the stock bellhousing and bolted it to a common later Chevy 3 or 4 speed. I now have the same 4 speed that I had behind my last 302 behind a 350. I don't know if ant of this applies, but it seems like they bolt up. Never looked at a torque tube trans. RF
  20. Bruce Lancaster
    Bruce Lancaster
    The right pickup 3-speed should bolt in at both ends of this swap--I think you bought the wrong lump. Also, the adaptor route should be entirely workable--bellhousing pattern and flywheel pattern are same on 250 as V8, all you need is to be sure you get the diameter of wheel that afits toi the 250's starter location--just count the teeth and match to 250.
  21. cwatson1953
    cwatson1953
    thanks for the info guys, that helps alot.
    Chris
  22. old dirt tracker
    old dirt tracker
    from phoenix
    cwatson read what enjerjo said again, a 49-54 trans and a LATE MODEL bellhsg.
  23. cwatson1953
    cwatson1953
    OH! damn i feel dumb now. haha:eek:
    i wonder what kind of late model bell would work...
    thanks man.
    Chris
