BARE MINIMUM for V8 swap into an A chassis?
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Feb 21, 2007.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    I've had my eye on a neglected A roadstar stuck in a nearby garage for quite a while. It's an older restoration and in decent shape. I'll likely never have it but it's fun to think about what I would do if I ever had the opportunity.
    Right now I'm wondering what the bare minimum of needed supplies would be to swap a flathead V8 into it.
    New brakes are a no brainer. I've seen A steering boxes on old hot rods so I ***ume it could stay if in decent shape.
    Most interested in what would be involved in a motor swap? Flathead and toploader mated to stock TT and rear seems simple... but is it possible to actually mate the V8 right to the A transmission? Remember this is supposed to be bare min. so performance can take a backseat to just using what's at hand.
  2. j ripper
    j ripper
    from napa ca.
    interesting thread kevin, not sure about mating the v8 to the a box, but anything is possible.
  3. DeepSouthRick
    DeepSouthRick
    You'll have to box the frame or a V8 will twist it like a pretzel.
  4. revkev6
    revkev6
    from ma
    nah. stock flatmotor should be fine without boxing. definately need the v8 ******, modify the stock A radiator for twin inlets/outlets. if you want to go REAL early Av8 run a 21 stud motor and keep the mech. brakes. leave the windshield stock height and take it off most of the time. I think it would be cool.
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    Nah... I could leave it unboxed. I could even leave the mechanical brakes if I wanted. I just threw that in my initial post so I wouldn't have to read through ten suggestions of swapping to juice. :)
    So how about it? I know there's a swap for the four banger to a toploader combination - but this flathead V8 to A trans interests me. And if doesn't really work... will an A tube mount up to a later toploader?
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    And I dig the 21 stud motor angle. Nice.
  7. reece
    reece
    from NC
    I am not sure the unsynchronized A ****** would be a lot of fun behind the V-8. I am scheming ways to get a synchronized ****** behind my 4-banger right now. The later synchronized gears in a '32 ****** is the solution that I may try to run. I thought about the adaptors to put a V-8 ****** behind the banger but I am not crazy about all the funky brackets involved for the brake, clutch, and wishbone mount.
    Reece
  8. AV8 Dave
    AV8 Dave
    Kevin: Apparently there are adapters that will mate an "A" trans to a flathead V8 although I've never seen one. The "A" torque tube will bolt up to the V8 top loader trans. I had to fab up a spacer to gain engine bay space for my 8BA style flathead in my '28 sedan. You MIGHT be OK with a 21 studder. There are definitely engine bay space issues if you are running stock hood and fenders. Regards, Dave
  9. SUHRsc
    SUHRsc
    yep
    it'll work, my car has the stock A rear hooked to a 39 box
    you need all of the socket parts for the rear of the v8 ******
    if your going to go with the v8 motor/****** your going to need to make some sort of way to bolt the ****** in as the A attaches to those 2 side mounts from the bell housing
    and in the front you'll need somthing different also
    i have an A radiator that they just capped the stock upper outlet and added one on each side
    then for the lower they put an extra hose off the side of the original one...so it is a Y coming out and going to each water pump
    if your gona run hydraulic brakes...mine has the master cylinder on the p***engers side taking advantage of the stock brake cross shaft
    you can use the stock pedals and all hooked up
    then put the master cylinder under the p***engers floor on a bracket and your done
    i havent done this myself but my car has it done on it and a friend of mine just copied the idea in his roadster and it worked out great
    you better go get it, sounds like a great project!!
  10. chuckspeed
    chuckspeed
    Kevin -
    what Zach sez is correct.
    I wouldn't use the A box - no synchros and not a lot of torque capacity. I wouldn't worry about boxing the frame IF the V8 is stock - or close to it.
  11. hotrawd
    hotrawd
    from lima,ohio
    Kevin,The November,1953 issue of Hop Up mag. has a good article on how to do this. If you can't locate one,PM me and I'll send you a copy.
  12. SUHRsc
    SUHRsc
    just a quick story
    my dad's uncles (the Suhr Brothers) built hot rods and race cars since the 30's
    there was a small garage in the town close to me
    well the Suhr Brothers built a roadster and put a flathead V8 in it
    I'm not sure what year this was but i think around WWII
    then they drove it down to Grub brothers garage...
    went inside and asked for info on putting a V8 in a model-A
    the mechanics all said...that cant be done...
    their reply...we did it....and its sitting outside!!
    the old barn/garage is still there Grubb Bros garage with a big coca cola sign painted on the side
    every time i drive by that place i think of this story and try to picture a little roadster sitting there idling away with a bunch of grungy mechanics standing around in awe
    boy i wish they took more pictures!!
  13. DeepSouthRick
    DeepSouthRick
    I guess I automatically think of a significant boost of horsepower when swapping to a V8.
    But yeah, if you keep it light, it'd work -- and be a very cool project, too!
  14. Artiki
    Artiki
    from Brum...
    An option would be the mechanical front brakes from a '35. I've heard they have a larger contact surface area than stock A's and are a fairly easy swap. Not done it myself, just what I heard.....
    I'd certainly look to avoid using the A trans though.....
  15. Kevin Lee
    Kevin Lee
    Super Moderator
    So I remembered loudpedal's swap and found this.
    I see he has a spacer between the trans and TT. He says the spacer is 1.5" thick. So is there enough driveshaft there to slide it out 1.5" and have enough left for the u-joint? I've sent him a PM but thought I'd toss it out here for consideration as well. He's not one to cut corners at all from what I've seen - but I didn't read where he had done any work to the driveshaft either.
  16. Dale Fairfax
    Dale Fairfax
    Don't forget pedals-once you remove the "A" engine/bellhousing/transmission ***y you no longer have a clutch & brake pedal. You'll need something out of a later car. '39 preferred if you're going hydraulic. A '32 K-member (Ouch! $) and a '32 pedal ***y makes the V-8 installation a lot easier.
  17. RodLand
    RodLand
    Hot Rod, December 1951,(A V-8 in your model A)
  18. HotRodMicky
    HotRodMicky
    Hi SUHRsc,
    could you post a pic of
    "i have an A radiator that they just capped the stock upper outlet and added one on each side
    then for the lower they put an extra hose off the side of the original one...so it is a Y coming out and going to each water pump"...
    i don't understand how they did the lower hose thing.....
    TIA
    Michael
  19. 2muchstuff
    2muchstuff
    from Eastern KS
    Kevin, I've been looking at this same swap and have done some measuring. I'm planning on using the A rear end and torque tube. I think the easiest fit is the early 59 block with a generator mounted fan. You'll need to fab engine mounts (or I believe Vern Tardel makes a nice bolt in set for the A frame) and a trans mount. As noted above, you lose the pedals with the A trans. A 1/2 ton pickup crossmember from 42 - 52 can be easily modified to fit the A frame and give you the pedals & ****** mount. You can then go to juice brakes, or modify the brake pedal to work with the A mechanicals. The next issue is your front wishbone mount - it also leaves with the A transmission. Split the bones and fab mounts. Another option, a 32-35 front end gives a slight (about 1 1/2") drop over the stock A front. The wishbone (longer than the A wishbone) can be mounted to the new crossmember with some fab work. The original brake rods can be connected to the 32-35 brakes.
    It appears the 8BA engine/trans combo is to long to fit as direct replacement for the A engine/trans without considerable work.
    If you're bored some weekend come on down and take a look. I've got about everything to do this swap and you can measure everything up. I'm only about an hour west of KC.
  20. SUHRsc
    SUHRsc
    yeah i can when i get home...
    in about 3 hours
    Zach
  21.
  22. SUHRsc
    SUHRsc
    i havent run the radiator yet
    someone gave it to me for my truck...which is in a million pieces still
    its pretty crude looking but i think it would work ok
    I'm no radiator expert though
    i'll try to get a picture as soon as i can
    Zach
  23. continentaljohn
    continentaljohn
    I'm doing this right now on the vicky. The 39 motor and trans to a model A TT. All you need is a V-8 coupling the Model A is a 6 bolt to the trans were the V-8 is a 4 bolt. I also used the V-8 U joint.. I didn't need any spacer and was puzzled by that.. As far as the brake pedal and stuff I had planned on useing my 32 K-member.. I have all the parts but the pedals that bolt in?? I thought I had them but no can do.. The brakes are juice ones I had picked up here or there..
  24. SUHRsc
    SUHRsc
    i was wrong on the rad. sorry
    hadn't looked at it in a while
    heres the pic anyways
    Zach
  25. j ripper
    j ripper
    from napa ca.
    i have tried also sending pm. 1 1/2" without driveshaft mod will not work. im making a 1/2" spacer right now. thats all you need.
  26. Bruce Lancaster
    Bruce Lancaster
    The 1951 HRM article is general in nature, covering several different ways of handling radius rod (best and hardest is belly band replicting original bellhousing), different crossmembers, etc. Best and hardest X member is likely what you've already done, '39 type with no boxing...
    I don't think A trans is even a contender, and I've never seen an adaptor to keep one. I'd certainly base all locations on original tube, and figger out a way to map and duplicate original pedal locations, since there isn't much room to go in any direction on an A...
    Two other souces are the old California Bill speed manual and the very specifically detailed builds in the 1954 HRM (car just featured in Rodder's Journal) and the A-V8 book. 3 sources? Probably correct way to plan period style is to select a random year of available wrecked V8 and use everything from that...
    Even if I were building a B powered A I would use the general A V8 approach rather than the horrible stacked up adaptors to keep A pedals and trans.
    I actually just started gathering an A V8/B, but screwed up at step one because the first frame I tripped over was a '32. So much for the plan.
  27. SUHRsc
    SUHRsc
    i could help you out....i have a real nice A frame
    wana swap ;)
  28. Bruce Lancaster
    Bruce Lancaster
    I think it's just destiny telling me to steer a careful line between the primitive and quaint (1931) and the trendy, faddish world of high tech (1933). I'm just a deuce magnet, can't seem to find anything that's not '32. :)
  29. Kevin Lee
    Kevin Lee
    Super Moderator
    I talked to Kris (loudpedal) and he said spacer was around an inch. This is all done to keep from cutting the firewall I presume. And again, I don't he's one to fudge something - especially a driveshaft.
  30. Kevin Lee
    Kevin Lee
    Super Moderator
    This is all a pipe dream anyway. I am very much concentrated elsewhere - trying to steer that same sort of line I guess. Plus I don't think I could get this thing out of the garage unless I offered a "really neat" dune buggy or 4x4 in trade. Don't have either.
