Help me dump my dumptube-Rocketeers?Yorgatron?
Discussion in 'The Hokey Ass Message Board' started by NOAH324, Feb 23, 2007.
  1. NOAH324
    NOAH324
    Yorgatron mentioned in another post he added a pcv-valve to a rocket motor.
    Anyone got pics of this for the olds? Can you eliminate the dumptube and block off the hole?
    Can I put a hole/grommet/pcv directly in the valley cover? This would be easiest, I think.
    Or has anyone come up with a different solution??
  2. yorgatron
    yorgatron
    1st remove the road draft tube,then go to the auto parts and get a grommet that fits,and a PCV to match.
    then run a hose from the PCV to a hole cut in the bottom of the air cleaner,or plumb it into the base of the carb if it has a fitting for power brake vacuum.
    it's just that simple ;)
  3. NOAH324
    NOAH324
    Thanks!
    Did you remove the inner part (see pic) too?
    Damn that's going to be a big PCV - didn't know they made em that big - gotta be like 2" diameter.
    I'll post pics when I get her in.
    ps - did you see my other thread with the kooky rocker arms:
    http://www.jalopyjournal.com/forum/showthread.php?t=164316
    Noah
  4. bones35
    bones35
    hey noah i know what your talking about its a big hole ive been trying to figure out how to accomplish the same thing. cory
  5. NOAH324
    NOAH324
    OK - I think I got it.
    Cory-check the attached pics, you should be able to make out the part #'s for the grommet & PCV.
    The grommet fits well - but not super-snug, so I used silicone sealant too.
    I used nuts/bolts/silicone for the bolt-holes.
    I'll let you know if it leaks!
    Noah
  6. Why not block off the old draft tube location completely and just drill a hole in the back of the valley pan and use grommit and pcv valve there? The pcv valve will need to be mounted vertically anyway to work best, atleast that's the way I did it on my Y block and it works great.
  7. ROCKET303
    ROCKET303
    I miss my Rocket Motor
  8. Bobert
    Bobert
    Just a thought on the round baffle can. Don't toss it, you may need it on there to keep from ****ing oil through the pcv. There is a lot of oil flying around in the lifter gallery when the engine is running.
  9. NOAH324
    NOAH324
    A54 - that's what I was thinking too. I guess it's 6 of 1, half dozen......
    I guess this way I didn't have to fab a blockoff and drill a hole.
    Hey - you driving to the Roundup? I live in San Angelo.....
    Noah
  10. NOAH324
    NOAH324
    "Just a thought on the round baffle can. Don't toss it,"
    Ahh-I still got it- maybe Yorgi'll chime in if he was able to go without it...
  11. yorgatron
    yorgatron
    i kept the baffle can.
  12. X38
    X38
    Baffles are pretty important. It's amazing how much oil can be ****ed through PVC's if they're not baffled.
    Another thought for any old draft tube engines, freeze plugs of vaious sizes can offen be used to fill unwanted big holes, sometimes also drilled for a smaller, snugger PCV and grommet.
  13. NOAH324
    NOAH324
    The Baffle is back!
    The grommet worked even better now too.
    THANKS GUYS! - Don't know why I was so 'baffled' by this...
  14. Noah, I went last 2 yrs, loved it, but his yr I'm holding out to go to the HAMB drags----- Have fun at the roundup.
    Richard
  15. NOAH324
    NOAH324
    In honor of TECH WEEK - here's some pics of the finished product. It gets a little complicated when using a stromberg 4x2 setup with no vacuum/PCV provisions so you have to improvise.
    I used some 2" carb risers to give me somewhere to tap the PCV line into.
    (You'll need longer carb studs to accomodate the risers)
  16. NOAH324
    NOAH324
    Then drill and tap a hole in the riser, install a fitting and attach the hose.
    Done!
    Of course this is untested - but I'm ***uming it won't affect the air/fuel flow.
    I'll let you know if it does!!
