Thanks for all the emails for the new intake,, if everything goes as planned ,, I will have them for Paso,, hers some information on the intake.. ~S,, *Coming* Soon X2-8x2 for *Small Block Chevy*, offered in 3-bolt pattern and 4-bolt pattern, Fully C.N.C.ed, comes complete with hardware. Intake is slightly taller which will, allow you to run any valve cover. For maximum rocker ratio, Intake walls thicker for maximum porting, all carb studs bottom out in intake,, No VACUUM LEAKS!! Sorry one thing I forgot to mention... is the intake will ONLY Fit a MAGNETO!!! I had the tolerance around the MAGNETO AS tight as we could make it,, so you would be stuck running a MAGNETO,, other distributors may work,, I dont know???.. I just wanted to keep the look of the intake SiCk *** F!$&@!#!!! Keep the Them going.. As far a sa price.. I couldn't say anything right now.... Art work by:Sin.. or as we call him Sa****!..
Aww Steve you let the kat out the bag before you hooked your boy phil up, Its kool your droppin mine off at the house right?
thats monsterous! i love it. once i get one i will be taking donations for carbs. that will look bad*** once bolted on i cant wait to see one used.
