So where to get electrical connectors?
Discussion in 'The Hokey Ass Message Board' started by ROADRAT EDDIE, Mar 2, 2007.
  1. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    The male/female blocks with between 10-20 pins in them....Would make removing a body much simpler if every wire in the cab was bundled into one connector that disconnected
  2. Missing Link
    Missing Link
    Radio Shack and/or Napa
  3. specialk
    specialk
    Radio Shack for electrical stuff (ha ha)
    This is not to dis you by the way, it's just that RS has so turned to **** in the last 10 years. They need to change their name to 'Totally ****ing Annoying Employees'. It would be far more descriptiive of their purpose in life
  4. Goztrider
    Goztrider
    from Tulsa, OK
    Depending upon whether you are concerned about how pretty it looks, you might be able to find a male and female plug similar to what you are wanting in a salvage yard or an old junk car. Think about most cars that have an engine harness where when you remove the engine you just unplug it.
    I know the 97 Dodge intrepid I had used 3 separate ones for the engine and transmission - each with 10-15 or so wires on each plug.
    Might be the low buck method - yanno?
  5. rodknocker
    rodknocker
    my 99 ford ranger has a good sized connecter right near the brake master cylinder that would be easy to snip out at a junkyard,probably 20+ pins
  6. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Yeah, that's probably the route i'll go
  7. Big Pete
    Big Pete
    I make money do'ing this stuff, the problem is the crimping tool always necessary for those lab coat hi tech harness'es always seem to run over 300 bucks or so.
    If your serious PM and I'll send some pictures and direction.
  8. 2manybillz
    2manybillz
    These guys in Nebraska have a mountain of electrical stuff that can be used in cars. I've bought parts for amps from them - seem OK to deal with.
    http://www.surplussales.com/index.html
    I've also stripped connectors and harnesses from the junkyard.
  9. chumly2071
    chumly2071
  10. Couple of nine-pole trailer connectors.
  11. 59NASH
    59NASH
    I do this at work as well. The company has the crimpers and such, but I wanted a set of my own. I looked on ebay and found a pair of crimpers that were used in the aircraft industry, 12 bucks to my door. If i bought one through the company, Caterpillar, it would have been close to $400.
  12. 4tford
    4tford
    Try www.painlesswiring.com in there connector and pigtail section they have sealed and unsealed connectors.
  13. gahi
    gahi
    from Moab, UT
    I always called them a bulkhead connector.
  14. terrarodder
    terrarodder
    from EASTERN PA
  15. kwiksilver
    kwiksilver
    We call them Molexes. Car stereo shops and van conversion shops. Car stereo harnesses came in male and female versions. or get the radio end and cut the other end out of a car. steering column plugs have an *** of wires. maybe that helps
  16. hot rod wille
    hot rod wille
    I have done electrical for almost 35 years--I have done the disconnect thing forever--a great way to go,but you're better off breaking it down into 2--3--or 4 plugs. It's easier to trouble-shoot this way and you can seperate different curcuits like lighting--front to rear--engine--etc. I have used Del City stuff for a lot of years ---great stuff and they sell in small amounts to average guys like us.
    www.delcity.net
  17. skele4door
    skele4door
    from Dallas
    If you have a Fry's locally, head up there and check out what they have. I picked up some nice cheap unsealed connectors that aren't so small that they are impossible to ***emble. If you need something sealed then I've had good luck with Delphi Weatherpack connectors. You can get a reasonably priced kit that has everything you need to make OEM quality connections (minus the crimpers) at the link below.
    http://www.ledfoote.com/osc/product_reviews_info.php?products_id=76&reviews_id=5
  18. heinz
    heinz
    from CA
    I used connectors similar to what you are looking for from McMaster Carr. Used them for an ignition module on a bike years ago. Check them out at http://www.mcmaster.com/. They have a pretty good variety of configurations and materials.
  19. Mozes
    Mozes
    Use Trailer Plugs, Watertight And Inexpensive, Get Em At Autozone Or Napa, Like 5 Bux Man.
  20. Kustomz
    Kustomz
    Go to everyones favorite auction site and search for cannon connectors. They come in a variety of pins and are military grade stuff. Might just work good for your project.
  21. blowby
    blowby
    from Nicasio Ca
    Old thread, new question: I'm tired of buying cheap crimp connectors from Radio Shack or the auto parts store. Where's the best place to buy quality (br***?) connectors in bulk?
  22. stimpy
    stimpy
  23. mike in tucson
    mike in tucson
    from Tucson
  24. jwray
    jwray
    from Omaha, Ne
  25. OldFord39
    OldFord39
    from Monroe, Wi
  26. I'm fond of late 80s early 90s ford connectors. I go to the salvage yard (ask permission) and cut out mating sets and leave 4-6" pigtails on them. When I am wiring up a vehicle, I just splice the wires by stripping and twisting the 2 together then solder and cover with the shrink tube that has hot melt glue inside. I've never had a failure, but it is time consuming. At the price of good store bought stuff, I can afford to loose some time.
    Right now I have 2 5 gallon buckets full of all different sizes, I figure they are worth $1 per pair of pins.
