My first attempt at making a fuel block...what ya think???
Discussion in 'The Hokey Ass Message Board' started by xxwelderxx, Mar 3, 2007.
  1. I made it out of a 3"x2"x1" piece of solid alluminum. Did the work on a Bridgeport. Im gunna try my hand at a fuel log next. Sorry the pictures arent the greatest.
  2. Flatman
    Flatman
    Looks tough and servicable!:D Now you can play with making them fancy:D
    Flatman
  3. kustombuilder
    kustombuilder
    from Novi, MI
    pretty cool... for BILLET!!! :eek: :D
  4. dammit i knew it..... next time i make one it being made from a petrified tree.
  5. flathead okie
    flathead okie
    Gotta be better than the "Mr. Gasket" **** out there. Looks good to me, but what the hell, I need gl***es.
  6. publicenemy1925
    publicenemy1925
    from OKC, OK
    Did someone say billet?
  7. fergenboysinc
    fergenboysinc
    Hell Ya! At least "you" did it. Round the edges with a angle grinder and polish it if you want it to look more traditional. I like it!
  8. Thanks!!
    What would be the best fittings to use? br*** or SS?
  9. Personally I don't see a problem with using billet. Every good forged axle, forged crank, or forged piston starts from a billet. If you make it yourself by hand or with the use of equipment for your own ride then more power to you. A billet is a chunk of ferrous or non-ferrous metal that is used in the formation of a machined or forged part. I think you did a great job. Plenty of guys back in the day would have used billet to make parts if it and the equipment was as readily available as it is today. Good Work, I'd run it.
  10. bohlsd
    bohlsd
    Looks good. Main thing is something you did.
  11. GTS225
    GTS225
    Ignore the "billet" bashing. Ya did ok. Like Fergenboy says, round the edges and corners, and maybe even mill slots all the way around with a round-nose, 1/8" bit. Make it look cast. Polish it if you want, personally, I'd blast it and call it good.
    Roger
  12. Shifty Shifterton
    Shifty Shifterton
    Don't use steel fittings, steel+aluminum=corrosion
    As the others have said, knock the edges down and the vintage will come out.
    Just don't anodize it purple..........
    nice little craft project BTW, looks good.
  13. Spyder
    Spyder
    from Houston
    I think the suggestion about round edge slots is on the money. Such a project is on my to do list.
  14. fergenboysinc
    fergenboysinc
    And there is nothing wrong with spending two days on a part you can buy for 25 bucks :D. I have done it many times.
  15. I made one just like that in my high school machine shop cl***....50 years ago ! It looks traditional to me. :D
  16. Indocil Art
    Indocil Art
    If you do one again mill fins in it. round the corners then sand blast the fins. It rounds the fins and makes it look like a cast piece. I have seen a bike that the guy rounded every billet part this way even the wheels. I thought he had a set of wheels cast for the bike but they were really blasted billet
  17. DualQuad55
    DualQuad55
    from NH
    It came out nice.
    I agree with rounding the corners, at the top of the 'block' and also the edges of the base around the bolt holes.
    It looks like a one piece version of some of the ones I have collected.
    Job well done!!
  18. I agree to round the corners.Then blast it with the most course material you can find.Top it off with br*** fittings.You might also want to stamp your name in it before you blast it for a one off type of deal. Then wait to see if your friends ask you where you got it! My 2 cents.
  19. Yo Baby
    Yo Baby
    It looks like a KISS rule part.
    Nuthin' wrong with that.
  20. BigDanF4i
    BigDanF4i
    I almost ****ped myself at this. anyways, i think it looks decent, i agree that a little time making it more visually appealing wouldn't hurt.
    you made it yourself, therefore, if it works, its automatically cooler. and if it doesn't, blame someone else
  21. banjorear
    banjorear
    I agree with the comments that you made it yourself. Looks good. Keep trying and knock it around a bit to lose some of that "newness" look.
    Good work, squire!
  22. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Pretty cool there............. I also agree with the "rounded corner gang".
    I can't help but wonder, if you made some to look like Chevy Bowties, might sell some? Or Ford Ovals? Mopar Pentastars?
    or fin the top, round it to exactly match Cal Custom valve covers!
  23. swimeasy
    swimeasy
    Anything that you make yourself is always cool!!! That goes for houses,boats,kids,and hot rods!!KEEP IT UP!!!
  24. Why buy it when you can make it. A man after my own heart. BTW, the term billet is extremely overused and miss-used.
  25. kustombuilder
    kustombuilder
    from Novi, MI
    LOL. just givin ya a little **** is all bro. LOL :D
  26. kustombuilder
    kustombuilder
    from Novi, MI
    you looked that up in the dictionary did'nt you??? ;) :D
  27. Looks cool.. nice work..
    I would personally round off the edge and then run a 1/8" mill for a few p***es down the center to give it a finned look...
    Bridgeports rule don't they.
  28. Ok here are some finished pieces....what you think? First one is the rough one after I rounded the edges and the second one is a 5" x 1" piece of alum., but I also used the laser at work and etched my last name into the piece. I still have to weld on brackets on the log looking one.
    What ya think?
  29. Empire32
    Empire32
    from FRANCE
    can be really cool engine turned !
  30. Wesley
    Wesley
    I was going to suggest machining your name (or something smart***)into it. Why buy it when you can make it. Over the years I have made more of my own parts than buying them, because I am usually broke and always cheap. It is amazing what you can learn by taking a big chunk of metal and turning it into a small usable part and alot of shavings on the floor. By the way, most of the parts I made along the way didnt look near as good as what have there.
