9" AXLE problems....Lincoln Big bearing
Discussion in 'The Hokey Ass Message Board' started by RustyCoupe215, Mar 4, 2007.
  1. RustyCoupe215
    RustyCoupe215
    from Owings, MD
    Hey guys,
    probably a retarted quesiton, but here's the situation.
    I needed to replace 3 wheel studs on my 9" and ran into a issue in the process. Its a ' 79 Lincoln big bearing rear, yes with the "non traditional" Disc brakes. :rolleyes: TWell since 3 of the studs were bad I bought 10 and plan on replacing all of them.
    I poped theaxle out after removing the caliper braket/axle retaining stud nuts. well as you can see from the pics the bearings/ bracket are retained on the axle by this ****ing metal bushing...the round solid bearing race...etc....HOW do I remove/re install it and any info or advice is greatly appreciated!!!!!:D
    The bearings appear to be ok, and I've tried using a BFH (Big F*ing hammer) to beat the bearings/cylinder down off the axle towards the splines but the ****er wont budge.....
    <a href="http://photobucket.com" target="_blank">[​IMG]</a>
  2. squirrel
    the shop manual say something about drilling a hole in the lock ring to get it to pop off...then you press off the bearing...then do your stuff...then press on a new bearing...then press on a new lock ring....
    PITA
  3. HemiRambler
    HemiRambler
    The last ones I did I took my 4" grinder and ground into that collar (wedding band) until it was thin - careful you don't wanna damage anything. On one side as I got close it made a huge "bang" as it cracked - FWIW the other side did not go bang.
    Thenjust press the new "wedding band" in place.
  4. bwiencek
    bwiencek
    If it was a shop doing it - a bearing separator plate and a big ol shop press... Most machine shops should be able to press off and on a new bearing for $10-20 if you stop in with the new bearing and some cash in hand... Takes a few minutes and a lot easier than beating or grinding it off...
