'62 chevy 3 speed O/D: need parts
Discussion in 'The Hokey Ass Message Board' started by greasel, Mar 5, 2007.
  1. greasel
    greasel
    from Fresno, CA
    working on a 3 speed O/D trans from a '62 Belair and I need parts for it. I've pulled it out, haven't dug into it yet. I have a good book that shows how to dis***emble/***emble but don't know where to get stuff from.
    any info?
    thanks
  2. the trans is the same as other non o/d trans, but if you looking for o/d parts they're kinda hard to come by. either get a spare trans or hit the 'bay/ old time wrecking yards.
  3. greasel
    greasel
    from Fresno, CA
    the O/D is fine as far as I know. I'm looking for parts specifically for the transmission...at least bushings and seals, maybe some shafts or gears, not sure exactly what parts I need because I haven't pulled it apart yet. Kinda wanted to find out where to look for parts to overhaul the transmission itself.
  4. Dan Boehm
    Dan Boehm
    Northwest Transmission Parts
    Winchester, OH
    1-800-327-1955
    www.bright.net/-nrthwest
    automatics, 1940 up
    manuals, 1933 up
    GOOD PEOPLE!
    Dan
  5. 265glide
    265glide
    Greasel,
    Replace the syncronizer clutch,It's the large drum the 2/3 shift fork fits on.If the br*** rings are loose in the ends, this = grind, going to 2 or 3 gear.Years ago in the dealership any time a 3 speed was down the syncro clutch was changed.
    Sorry do not have any parts connections for it.
    glider.
