hello all, I hope all is well,Im looking for some help on what to use on my 59 buick, it sits on a 76 225 frame Im putting on air bags and wanted to know if I can use rev. supremes a friend said there might be some clearance problems, any help would mean a lot ,thank you -big bad wolf-
I have put them on Mopar/Ford 5 x 4.50 or 5 x 114.3 and Chevy 5x4.75 and on Cadillac 5on5 14 inch rim will fit over the big Cadillac drum and will clear the Chevy disc 11"Rotors and Caliper. You just need to make sure the offset will clear the skirts.
If you use a 7" full rev you will be fine. You can also buy a Pacer wheel sold by American Tire it is a Cragar wheel with a Pacer center cap. Much better price. Part# 167c-5708r = 15X7 = -47 REV. I sell wheels 4 a living this is the way to go if you want that deep lip. Or 14x7 part# 167c-4708r = 14x7 -54 rev. I had a Buick fit like a glove. You will have to run a narrow tire. If you do a 14x7 std = -9 witch really means 3.75 pack spacing that will give you a 3.25 outer lip. Way more options on tires. Just drop the r off the part number. You can see them at (atd-us.com) just click on wheels and hit the 06 catalog. They should have a dealer locater in there.
