Disc grinder bit the dust... New brushes?
Discussion in 'The Hokey Ass Message Board' started by Rocknrod, Mar 12, 2007.
  1. Rocknrod
    Rocknrod
    from NC, USA
    Hi guys...
    I'm wondering where to look to buy some new brushes for my disc grinder. It is a pre-historic black and decker, strong as an ox sort.
    Could you point me to where I can buy some? I don't mind doing some file work to get them to fit.
    Thanks
  2. Possibly Grainger? They have a huge selection of replacement motors and ***ociated parts.
  3. Gasserman
    Gasserman
    from Tulsa OK
    Find a Electric Motor Repair shop ,they will stock a good supply . G***erman
  4. 39 Ford
    39 Ford
    Try a GOOD hardware store, "not Home Depot" they should have some.
  5. 55 dude
    55 dude
    napa carries some. get on google and punch in "black and decker service" that should bring up service locations in your area.
  6. Moonglow2
    Moonglow2
  7. Rocknrod
    Rocknrod
    from NC, USA
  8. yorgatron
    yorgatron
    does your grinder look like mine? :confused:
    if you end up buying a lot of brushes i'll buy some off you.
  9. polisher
    polisher
    Alliance Vendor
    I get my brushes from a local builders merchant that has a repair shop.
    They don't always have what I need, but I can generally solder bits together swap springs and sand stuff down 'till I get what I need.
  10. joeycarpunk
    joeycarpunk
    from MN,USA
    I used brushes from a CS 130 GM alternater in my sawsall a few years ago and its still running fine. Any alternater repair shop should have something similar you can modify.
  11. pimpin paint
    pimpin paint
    from so cal
    Jeeze Yorgatron, I haven't seen that model of Black & Decker in
    thirty years! Talk about traditional!
    S****ey Devils C.C.
  12. 29 sedanman
    29 sedanman
    from Indy
    My local Sears hardware store still has a decent selection of the littel trays with odds and ends. I noticed just yesterday that they had a tray with nothing but brushes of different shapes and sizes.
    Any hardware store with Dreml supplies will stock brushes for a dreml. Allot of brushes are pretty standard, you might give them a look.
