"Ruins to Rags" my model A build
Discussion in 'The Hokey Ass Message Board' started by kwiksilver, Jan 22, 2007.
  1. kwiksilver
    kwiksilver
    I've been reading and collecting parts and analyzing other builds until I finally started today. It will include a multicarbed 327, saginaw 4-speed, hydro clutch and brake under floor, 3" channel and 4-5" chop(will see after channel for headroom), suicide tierod, f1 box, spring to bones(not like pics), 32 shell -2", jeep lowback seats, moon tank in rear over kick, coilovers with ladderbars, silver on black. heres some pics. all info is appreciated good or bad. Thanks to all who posted up tech. To be continued...
  2. Jack
    Jack
    from Austin Tx
    I like the Radio Flyer gravity racer pic. Only a little top heavy.
    kwiksilver likes this.
  3. guiseart
    guiseart
  4. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    That looks good. sounds like you have a plan that will work very well.
    damn those tires look big..
    you are going to mount the spring behind and lower on the axle right ?
    its going to sit low...
  5. kwiksilver
    kwiksilver
    yeah I had it set up with the spring mounted to the perch but it was too high. The frame is at 5 1/2" in the front and 6 1/2" rear now but it might come up depending on how the spring behind works out. I had to narrow the frame after a boo boo so I left the perch off and figured I'll wait until I get the one from Macsratz and make it permanent.
  6. Boones
    Boones
    from Kent, Wa
    When I get back from GNRS I will come by and check it out (plus I want to try those meats on the back of my ride to see if the offset works..)
  7. flamedabone
    flamedabone
    Well look at you go..
    This is one of the funner parts of building a hot rod....You still need to set the body on the frame, sit on a 5 gallon bucket and make vroom vroom noises.
    You haven't fucked it up yet, makbe this weekend we can come and visit.
    -Abone.
  8. kwiksilver
    kwiksilver
    Got some more work done on the frame. Next is setting the motor and tranny mounts and cutting out the xmember thats in the way. I also want to figure out the steering tierod. not sure if I like it out front. I can actually bend them out a little bit to improve ackerman angle. as usual, questions and critisizms appreciated. Thanks, Rich
  9. Harris
    Harris
    Lookin' good - don't know if this makes me excited to start mine or scared?
  10. Eddie's chop shop
    Eddie's chop shop
  11. Tin Can
    Tin Can
    Looks great, you have a great start, and it looks like you have a mice a body to start with. A lot nicer than the one that i picked up recently. I am currently in the parts collecting stage for my tudor.
  12. Zumo
    Zumo
    That car will rule.
  13. Harris
    Harris
    Mind if I ask what spring rate you're coilovers are?
  14. dickieboy7
    dickieboy7
    from hoover,al
    good work son...looks like you are doing a lot of good work...as usual measure twice and "still cut it a little long"...dad:D
  15. kwiksilver
    kwiksilver
  16. Harris
    Harris
    Thanks for the link- more helpful than you can imagine.
  17. publicenemy1925
    publicenemy1925
    from OKC, OK
  18. OFT
    OFT
    Like the looks you have going.
    Front spring shackle angle looks like spring is too long. That is the angle you want at ride height (sp). When you add the motor ect the spring will be hitting the 'bones.
    Earl
  19. draggin ass
    draggin ass
    from hell
    ah i remember being at that point.. i thought i was close to driving it. HAH boy was i way to excited for nothing..... looking good.
  20. kwiksilver
    kwiksilver
    Yeah I was aware of that too. I measured it out and it looked like a 29" spring would work but that was too short. I pounced on the frame with my 250lb ass and it didn't get to vertical but you are right, it is close. I need a 30" spring but I havent had any luck finding one with reversed eyes and less arch. I think if I could find the same length spring with a lot less arch I'd be OK. I want it lower anyway. Any of you parts gurus know of one let me know. Asta
  21. wagonracr
    wagonracr
    Could you give some info on the tire and wheels you are using. They would look good on my 31 3-window.
  22. Lucky77
    Lucky77
    Looks really good, and it appears you know what you're doing. Only thing I ask is, are you sure that floor is level? Is that what you're going off for your chassis measurements? Only reason I ask is because I tried building my tudor's chassis on my garage floor and it didn't end up good. After a baseline measurement was off, I ended up cutting the rear clip off and having to redo the frame on a table.
  23. kwiksilver
    kwiksilver
    front- 15x5 reversed 2" bs rallymerica smoothie w/babymoon, 5.60 ribbed tires from Radir
    rear- 15x8 reversed 2" bs same wheel radir 8.20 cheater slick "piecrust"
    I used the 2" bs to clear the body with the 62" ford 9".
  24. kwiksilver
    kwiksilver
    before anything gets tacked I measure it for square and level and then shim or do whatever to make sure it is right. I have a 4x8x1/2" steel welding table I will clamp it to for finish welding. I actually checked the floor for level in that spot too. I dont want to do this twice! heres todays pics. not much though, I need a shifter to do the rest of the bracing, and I am not sure about the pedal location. I went by the directions from Pete and Jakes...we'll see.
    Oh yeah, I ordered a new spring-30" is the right spring
  25. gierhed
    gierhed
    Looks like good progress. Keep it up.
  26. dickieboy7
    dickieboy7
    from hoover,al
    Gary, be sure and check the spacing between the front of the motor/water pump and the radiator??? not sure whether you are using an electric sucker or blower or a regular fan???? one picture looks close and another looks ok??? just an observation...dad
    ps:... it is nice to watch your progress
  27. kwiksilver
    kwiksilver
    I am planning on moving the motor back a couple of inches.Will know for sure when I set the body on there. Thanks
  28. kwiksilver
    kwiksilver
    Got the new spring in. The shackle angle is much better now. It even has most of a motor to weight it down. Ordered a '32 2" chopped aluminum radiator from PRC and a shifter so I can get back to crackin'. Later
    I added a pic of the radiator to waterpump clearance. I have a couple of inches in the front to play with. Trying to keep the clearances and gaps equal and easy on the eye.
  29. dickieboy7
    dickieboy7
    from hoover,al
    looking good....thought you already had that 32 grill shell????
    ps Ronnie said everything would be used and thanks....:eek:
  30. kwiksilver
    kwiksilver
    Got the body on for some placement so I can finish the frame. It felt pretty good when it basicly fit on the first try! taking measurements and building the frame off of them was pretty nerve racking but Its all downhill from here. I am in the middle between finishing the body out or just running it rusty. It looks pretty good without the chop but I think I will cross that road when I get there. I will sit in it and see where the old noggin is for a headroom check. How about that 32 shell from my local "cool parts" guy! Later...
    p.s thats one of my helpers. He really digs the "hotrod"
