12 x 2 Trailer Brakes- Cheap Alternative?
Discussion in 'The Hokey Ass Message Board' started by gashog, Jan 19, 2007.
  1. gashog
    gashog
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    I know this was talked about on here, but I just spent 10 minutes searching for it - it must be buried in another thread instead of its own thread.
    I think it would be adaptable w/o too much problem...
  3. What about hubs?
  4. Wonder if you could run these with Buick drums...and what the backing plates look like from the other side...
    Steve
  5. Yo Baby
    Yo Baby
    What he said.;)
  6. revkev6
    revkev6
    from ma
    well,
    first off they will only work on the fronts. no E-brake setup.
    second, what's going to happen when you need new wheel cylinders or shoes? sure it might save you a couple bucks over ford backing plates but then you have to cut them up to make them fit
  7. Yo Baby
    Yo Baby
    What's your point? Cuttin stuff up is what most of us do.LOL
    Besides that,how many sets of Buick drums have ya seen on rears anyway?
  8. thrasher
    thrasher
    they make all the parts to rebuild one of those setups. when i was in auto shop i had to rebuild a setup on a horse trailer.
  9. gashog
    gashog
    Agree. Bendix parts are all pretty interchangeable/available. $300 a set less than other 12" backing plate options, is worth a little trouble.
  10. raven
    raven
    I wonder if Croft has anything like this?
    r
  11. 34toddster
    34toddster
    from Missouri
    Red Neck trailer supply Springfield MO
  12. revkev6
    revkev6
    from ma
    two sets :D
    one 45 fin set on the back of my 28 and one 90 fin set on the back of my 32
    I've done two other sets of rears, one for my uncle and another for a car he was building for a client.
  13. 34toddster
    34toddster
    from Missouri
    Hey do you want your car delivered tomorrow?
  14. Yo Baby
    Yo Baby
    So what did you do for rear plates with E-brake hole?
    I've got 6 90 fins now and no rear plates.
  15. revkev6
    revkev6
    from ma
    I'm using a 47 ford banjo rear with the stock backing plates. when you put them in the brake lathe you just have to clearance the drum a bit for the backing plate. doesn't take very long but makes a HELL of a noise. I did mine in my vocational high schools brake lathe. all the other kids in my cl*** wanted to kill me when I started taking the clearance cut. everyones ears rang for hours
  16. Pook
    Pook
    from Langley BC
    Did anyone mock this up? I need some juiced drums but for $400plus I don't want to buy repo's.
  17. Lotek_Racing
    Lotek_Racing
    The rear drums on my '67 Jeep Gladiator have no e-brake setup in them from the factory. It has a driveshaft e-brake.
    There are ways around the e-brake problem. The simplest is a manual gearbox.
    Shawn
  18. 29bowtie
    29bowtie
    Unfortunately Lotek,unless the e-brake is at the wheel,it won't p*** BC MVI.
  19. Pook
    Pook
    from Langley BC
    why is that? some suzuki samuri's and older ones have tcase mounted ebrakes and p*** the BC MVI and I have had built a few toyota 4x4's with custom t case mounted disk brake ebrakes and had them p*** MVI.
  20. Just ordered two pairs - gonna give 'em a try with my Buick drums...think I smell a tech post comin'...
    Steve
  21. Lotek_Racing
    Lotek_Racing
    Sorry man, my truck was sold in BC when it was new. The MVB can't simply change their minds about what is/was legal and what isnt.
    If the factory set it up that way and it was approved and sold when new, it's still legal.
    That's like saying they will bust me for not having shoulder belts and airbags.
    Trust me, I've been through this **** with V.I.'s before.
    Shawn
  22. ironhead68
    ironhead68
    Hey hemisteve, I've been checking this out and it sems to me that the $4o+ 12x2's are single servo, i.e. do not work in reverse(for baking up trailers). I ordered a pair of dual servos for $80+ each to try on '38 Chev spindles..we'll see. Maybe the single servos will work fine if you don't use them on all four wheels..or race in reverse..don't want you to back into trouble.
  23. Thumper
    Thumper
    Ironhead.....good eye to spot that. You are correct, those are "free backing" style to allow for backing a trailer with surge brakes.
  24. Smokey Stover
    Smokey Stover
    from Upstate NY
    I'm obviously missing something (not unusual).
    Could you 'splain it to me?
  25. Smokey Stover
    Smokey Stover
    from Upstate NY
    OOPS! Duh, I see it now.
  26. ironhead68
    ironhead68
    Trailer brakes (Dexter 12x2) arrived. Bummer..not going to work with Buick drums without milling the backing plates down from 14" to clear the finned rim..back they go. Scored a pair of recently rebuilt '55 Buick fronts at the swaps..12x2 1/4..fit real nice..even bolt up to the Chev spindle..ahhhh.
