Non-traditional Chassis for a Traditional Custom: '49 Chevy Fastback Update
Discussion in 'The Hokey Ass Message Board' started by Bass, Mar 12, 2007.
  1. attitudor
    attitudor
    from Finland
    Wow! I'm gonna save these pics for my '41 Pontiac build-up! Please keep the project photos coming, looks really good. --mika
  2. BoomBoom
    BoomBoom
    Metal Sculpture! The artist comes out no matter what the medium. Great work BB!
  3. Kilroy
    Kilroy
    from Orange, Ca
    Really clean welding and fab work!
    I've got a general question about the torque arm config. I almost never seen them the same length as the trailing arms but I thought if you didn't keep them close to the same length, the driveshaft universals would bind or wear-out?
    Is that just an old-wives tale or is there some 'magic' that's applied to compensate for it?
  4. Rusty
    Rusty
    Very Very nice Work!!!!!!
  5. HonkyTonker
    HonkyTonker
    from Irving, TX
    B***, Your a Ruler for sure..
    Neal0o
  6. kustombuilder
    kustombuilder
    from Novi, MI
    WOW!!! well done home slice. i'll have to save this one to my personal archives!
  7. rustypipes
    rustypipes
    from san jose
  8. 53burb
    53burb
    The detailed and descripted steps are golden that ya posted here B***. One of the best that I have seen on here yet!!!!!!!!!!! KNUX!
  9. Nads
    Nads
    from Hypocrisy
    Absolutely gorgeous!
  10. Evel
    Evel
    OMG!!! You are da Bomb Shizzy
  11. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    how did you determine where to z the front? was it just eyeball'd
  12. Slide
    Slide
    Regarding the dropping down of the front frame horns/radiator crossmember, do you think you'll have any trouble getting the lower control arm pivot bolt in & out? It seems like this bolt was pretty much right under the frame rail on my sedan, and that bolt is pretty long.
    Again, really nice work.
  13. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
  14. Bass
    Bass
    from Dallas, TX
    I cut it where I did in the front for two reasons. One, the Mustang II crossmember still bolts in from the bottom, so I had to cut it back far enough to retain that feature. Two, I needed to cut it far enough forward to gusset it in a way that it would have that "swoop" look from the side profile, but not interfere with the front-most bodymounts that extend down from the firewall.
    The spot I cut it at allowed me to do both.
  15. Bass
    Bass
    from Dallas, TX
    If I measured correctly, once the front frame horns are dropped 2.5", I should be able to still get the bolt in from the front because of the way the frame gradually kicks up in front.
    Thanks again for all the kind words guys.
  16. Cshabang
    Cshabang
    killer work man....as usual...funny I was thinkin the same for my pick up...trd outside on inside...more modern ch***is..haha...
  17. A 31 MO FO
    A 31 MO FO
    from D/FW
    BRILLIANT is all I can say!
  18. Anderson
    Anderson
    Killer work B***, as usual.
  19. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    How do you plan to modify the brackets to hold the front sheetmetal? I think I want to z mine. I planned to use the original front suspension.
    Do you see any problems with it or should I MII it?
  20. Dat Dirty Rat
    Dat Dirty Rat
    Jesus,,amazing work holmes......I havent found them lights yet but i'm still sorting/liquidating alot of sh!t...
  21. slammed
    slammed
    My eye's bugged on the ft. frame stepping. Unreal. The 'stack of dime's' welding, sky reaching rear frame. Well laid out. Stout.
  22. SapienKustom
    SapienKustom
    from Merced, CA
    Looks good. You do some bad work. Keep those pics coming!
  23. chopstix
    chopstix
    great work ! I wish I could weld like you do! Ive been working on my 51 chevy coupe . I did Z in the front . 2 link in the back. it lays pretty low.
  24. squigy
    squigy
    from SO.FLO.
    Incredible work!!
  25. Those welds look real nice ,I like it! Rags
  26. Chaz
    Chaz
    Sheeeit! That is truly notable work. and lots of it. Hats off to you.
  27. Kustom7777
    Kustom7777
    from Austin, TX
    you do some of the nicest work ive ever seen
  28. bobx
    bobx
    from Indiana
    you do nice work b***. those welds make me want to go run some beads..
  29. Royalshifter
    Royalshifter
    Moderator
    Very very nice work.
  30. The37Kid
    The37Kid
    Wow! Now we know who won HAMB Welder of The Year for 2007.:)
