removing rust and paint with soa ash and abattery charger
Discussion in 'The Hokey Ass Message Board' started by phil, Mar 16, 2007.
  1. phil
    phil
    what is the processe
  2. rodknocker
    rodknocker
  3. Frank
    Frank
    Its been covered extensively under electrolisys (sp?) rust removal.
    Battery charger
    plastic bucket
    Steel or iron bar
    Salt
    Your part
    Fill the bucket with water, dissolve salt in it. Doesn't have to be much.
    Set the bar in vertical and clamp it to the wall of the bucket so it can't fall over. Connect the positive to this bar
    Connect the negative to the old part and submerge. Make sure they two parts can't touch.
    Plug in the charger. After a bit it will start to bubble and produce a yucky green/orange slime. Leave it for a few hours.
    OUTSIDE. The bubbles are hydrogen gas and explosive. DON'T SMOKE! Unplug the power to the charger before you mess with the terminals so you don't cause a spark.
    The part will blacken, rust will dissolve. Pull it out and brush/wash in clean water. Your results may vary. Several good sites if you google.
    http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
  4. phil
    phil
    Great help guys thank's. now I got some rust removal to do.
  5. 39 Ford
    39 Ford
    If you are a reader of the HAMB a must to have is the May 2007 issue of Rod and Custom with Rolf's coupe on the cover. In that issue they also have an article on rust removal that covers just what you need. GET IT WHILE YOU STILL CAN.
  6. polisher
    polisher
    Alliance Vendor
    It won't remove the paint.
  7. hotrodhenry
    hotrodhenry
    from elmonte,ca
    for metal trim i've used coke (soda) and steel wool it worked pretty good. but the electric thing sounds cool.
  8. rixrex
    rixrex
    I have the article from R&C..in step#4 it says "I connected the negative terminal right to the part for demonstration purposes, its good practice to use a non-copper jumper wire..but in the picture the wire on the bucket is clearly copper and aren't the jumper wires on my battery charger copper? its a tad confusing....
  9. polisher
    polisher
    Alliance Vendor
    DO NOT USE SALT !!!
    FUME IS CHLORINE ( it can kill you real quick)
    Washing soda is best, baking soda is ok.
    but salt is a no-no.
  10. Frank
    Frank
    Seriously? I had no idea. I didn't have baking soda one day so I just used some Kosher salt I had. I ***umed it was hydrogen gas. Either way it is definately something you would want to do outdoors. I usually have it sitting in the yard and use long cords.
