What Did You Get Done This Weekend?!
Discussion in 'The Hokey Ass Message Board' started by HotRodRick49, Mar 25, 2007.
  1. HotRodRick49
    HotRodRick49
    You know, every Sunday night I read this thread, and I FINALLY got something done on my car. I gave my car a stance, first of many things to be done to it.
    We got some three inch lowering blocks for the back, and we heated up two coils. I didn't want to go TOO low, but I'm happy with the result.
    Those are before we did anything, there already was 2 inch lowering blocks in the back.
    The Youngster doing his own work! Not on a Honda Civic!
    Thats as soon as we dropped the back.
    And now... the good stuff!
    And now the best... All done up.
    Now its got its stance. What do you guys think?!
  2. Yankeyspeed
    Yankeyspeed
    NICE, I think the stance of a car is one the most important aspects of it.
    I worked more on my Plymouth. I am hoping to have back out before too much of the season is gone.
  3. InDaShop
    InDaShop
    from Houston
    Good job, looks good!
  4. El Zilcho
    El Zilcho
    from Austin, TX
    I shattered the last bone in my pinky finger of my left hand
  5. G V Gordon
    G V Gordon
    from Enid OK
    Relocated the F100 steering box on my Model A for header clearance. Shortened the pitman arm a bit. Next is fabbing a ****** crossmember and "bones" mount. Then I can blow it apart and finish welding the frame.
  6. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I spent my whole weekend wet-sanding the Burb in 600 grit. Man, I'm tired!
  7. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Tons and tons of yardwork saturday, then a lot of beer/poker Sat nite. Hungover slightly Sunday got the motor/trans etc into my shoebox, ready to roll tomorrow nite hopefully.
  8. sko_ford
    sko_ford
    got the rear spring mounts tacked on spring mocked to the mounts and rear end slid unter the A mod and started engene mock up in the front but i may chang the whole rear end set up
  9. plmczy
    plmczy
    Nice stance.
    I managed to cut off the drivers side fender on my 40 dodge tudor sedan. Yes you read that right,cut off. The previous owner welded the entire front end together and made a fip front end out of it. I wasn't happy with the way it looked,it didn't seem to fit right. The tilt portion was welded right to the frame and not removeable. later shawn
  10. gahi
    gahi
    from Moab, UT
    I struggled for two days trying to make a deck lid for a '40 pontiac. I havn't really gotten anywhere but burned up a sheet of steel. Hopefully next weekend will go a little better. not easy
  11. skyrodder
    skyrodder
    took out my gas tank, so i can put my fuel cell in, cause the old gas tank was dirty and s****ed on some streets
  12. chaddilac
    chaddilac
    I got the brush out and painted 3 rooms in the house... then went in the office and pinstriped these can lights to put in the cl***ifieds. [​IMG]
  13. CLSSY56
    CLSSY56
    Saturday, I had gone to the dark side and did an alternator conversion on my 56.... Then went cruising up and got ice cream ;)
  14. Flat Ernie
    Flat Ernie
    Tech Editor
  15. Harris
    Harris
    ALL day friday yard work, lotsa yard work on Sat., and a birthday party for one of my buddies 1yr. old. Sunday rested (lucky not to have overdosed on ibuprophen)
  16. Royalshifter
    Royalshifter
    Moderator
    I built a patio cover......whoo whoo.
  17. Tdreamer
    Tdreamer
    started the chop on my 53 bel air...hence started...now i gotta find a shoebox ford back window and sorround to lay in...wnet more then I had planed on...figured if I was ginna chop it...then really chop it
  18. MADMILLER
    MADMILLER
    from Las Vegas
    painted my 57 and started to put the peices together,last weekend it was wet sand city glad to be done
  19. ARCHANGEL
    ARCHANGEL
    I WHENT TO THE GOODGUYS SHOW IN PLEASENTON CA, :mad::mad::mad:
    AND FORGOT THE DAMMM CAMERA :( :( :(
    RAFA.
  20. merc-o-madness
    merc-o-madness
    i painted my firewall and air cleaner with hok pearlecent p***ion purple.
  21. cretin
    cretin
    Got some done on the airbags for the 54 chevy. Front is almost done, and for the engine driven compressor mounted. Cant wait till get that thing on the road.
  22. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    worked on a lincoln.
    started some work on my 28 Model A body.
  23. I got the bed mounted to the ch***is, beat the snot out of my run over tailgate to get it flat again. Bolted the cab down, built a torque tube tunnel out of an old F250 bedside. Started to bend up a fuel line tonight before I shut 'er down.
    Still have the remainder of the floor in the cab to finish, toeboards & mount the seat. Then have our gl*** buddy, or cut myself a piece of Lexan fer the windshield. I've got to mount the tank, finish the lines, run the wires fer lights & add a horn. Trim the length of my plug wires, find & swap tires, mount the tach, find me a taillight, bleed the brakes for the last time & road test it.
    But, at least I have until late Wed. night, ha.
  24. I also put a 7000# single jack on my friends equipment trailer. And went to another friend's b-day party Sat. night. Never enuff time in a weekend, ha.
  25. michael037
    michael037
    Not a lot, on Saturday I did nothing but rest after driving for 9 hours on Friday to attend a funeral. Sunday up at 5.30am to go to a swap meet. Bought a nice cup of tea, and was home before 12, and spent the afternoon doing yard work. I suppose there is always next weekend.
    Michael
  26. ZZ-IRON
    ZZ-IRON
    from Minnesota
    Nice Club Coupe !!!!!!!!!!!! I Worked On My Garage. Picking Up Packing Peanuts Off The Floor, The Foam Things That Are A Big Pain. They Make A Mess Unpacking A Box Of Part's. I Wrote A Article On Hokey, That Worked Well Dumping Them In To Plastic Bags. Putting The Little Monsters In Prison, So To Speak. Then Back To The Toss And Save ! Took All Day. I Got The Usual, It Dosn't Look Like You Did Anything Out Here. Large Hail Was Coming, It Didn't Show ! & That Was Great. Today Back At It, Till It's Done. Then Off To Wyoming To Get My 55 Buick Special 2 Dr Ht. 2 ND Trip In May For The Other. The 3RD One Is A 4dr Special With Factory Air & Drive Line. Take the Parts I Need And Leave The Carcas. That Will Take Up Next Weekend. 2000 Round Trip Adventure. They Always Are. Rich
  27. lindross
    lindross
    We put the finishing touches on our winter rebuild and took for a 60 mile test drive around our interstate. All is well and we bless it with a stamp of approval. :cool:
  28. carzguy
    carzguy
    Had to put a new water pump on my 50 ford--not a big job but it is kind of a headache because of that &*#& bolt inside the water neck---I mean who did ford pay to come up with that bright idea ?????
  29. rodknocker
    rodknocker
    finally got some decent weather and got the rear window and c pillars welded solid
  30. Went to a Phillies/Braves spring training game Fri. Hung out with DIRTYT's mom and her boyfriend at a cruise night in Orlando Sat. nite. F'd around with my minibike on Sun., got it running, and took a ride, but it needs new tires and some leaks fixed.
