48 to 52 F1 pick up parts
Discussion in 'The Hokey Ass Message Board' started by docholiday72tx, Mar 29, 2007.
  1. docholiday72tx
    docholiday72tx
    I went to an old wrecking yard the other day to round up a set of F1 shock mounts for a car that I'm building and scored a set for 20 bucks. I noticed that a lot of guys on here are looking for F1 parts.
    The guy that I bought my mounts from had at least 6 48 to 52's and another half a dozen 53 to 56 pick ups. There is another guy that has 3 F1's sitting out to pasture that said I could have all 3, but they're about 100 miles away. To me the parts just aren't worth enough to drive that far for, unless I'm missing something. What all parts from 48 to 56 are good for hot rod material, and what is a fair going rate for them? If they're worth my while, I'll go get them.
    Doc
  2. spoons
    spoons
    from ohio
    hard to find good sheetmetal (fenders, boards) for 48-52.
    You can get most stuff for 53 - up alot easier.
    I had to make my metal for my fenders on my wife's 49'..
    s****s
  3. docholiday72tx
    docholiday72tx
    Are there any good parts that can be used for hot rod parts like the front shock mounts?
    Doc
  4. fab32
    fab32
    I would be interested in a pair of rear fenders depending on the price. I'm looking for ones w/o that Michigan Patina (rust:D )
    Frank
  5. ClutchDumpinDan
    ClutchDumpinDan
    Lots of people are using the front brake setups (hubs, backing plates, etc.) as they can easily be put on early ford spindles with just slight modification. And of course the shock mounts and fenders. :D
  6. docholiday72tx
    docholiday72tx
    Truant, Are people using the fenders on hot rods?
  7. ditz
    ditz
    How about steering boxes and steering columns?
  8. spoons
    spoons
    from ohio
    Columns yes, I'm not sure about the boxes. Mine has a '56 f-100 box on it
    s****s
  9. f1 fred
    f1 fred
    from mn
    i have heard that the rods in truck blocks are heavier than p***enger cars so the flatmotors might be worth your while if not cracked
  10. Lakota
    Lakota
    There's a place in Seguin (Seh geen) Tx that some of us rodders call Candyland. He's got acres of old iron and it takes hours to walk the whole place. The last time I was there we only did the Ford section, it took us all afternoon. He has about 20-30 F1's and F100, 30-40 mid-late 40's coupes and sedans, 40-50 50's, over 100 60's cars and trucks, and the list goes on...
    If you can get there and haven't got enough cash, he'll put your stuff on lay-away. He put's it in a separate yard and you can make payments on it till it's payed for. If you do a transaction over the phone, he will do shipping. Here's a couple of items to wet your appe***e. 1941 Ford pick up, complete except for gl*** and left rear fender, has engine, trans, rearend, with ***le-$1500. 1971 Ford F100 Shortbed, 396 Chev engine, auto trans, power steering, can be driven home, has small hole in exhaust system, with ***le-$1200.
    Here's his info:
    John's Salvage Company
    2020 Fox Trotter Rd
    Seguin, Tx 78155
    (830) 379-2092
    (830) 303-9300 Local
    Mon-Fri 9-5 Sat 9-1 Central Time.
    His place is located 6 miles south of town off Hwy 123 South.
