Finnally did the motor swap. (Thanks Bud! for the Flatty and OD) Upgraded the car to a much better compression motor and and OD trans. Car had a standard 3-speed w/ 3.78 gears in the rear. This thing should fly nicely in Overdrive. Dressed up the motor, pulled and cleaned up a bunch of caked on grease parts and cleaned them up. It had 1" of "cake" on everything. Dont mind the firewall and inner fender panels, when I do the body work, they are coming off and going to the sandblaster for a nice cleanup. Every bolt I tried to take off, including the hood hinge bolts busted. Lots of drilling and re-tapping. What a pain. I really wanted to pull the front clip to paint the firewall...after a few busted bolts, I opt'ed to wait till I really hit the body work hard. Well...here is the new motor - Headers, Early Chevy Flattop 4-lobe Distributor conversion, dual carbs, chrome intake adapter, and other chromed up goodies (thanks Chevnut). im hoping to fire it tomorrow night, new exhaust on Saturday!
Chopped 50, Progress is looking good ! Wish I could say more about my Model "A". I have a friend who has a lathe. I will check with him this weekend. I may have a ****** case for you. I had to use all the parts out of it to rebuild my '47 Truck Trans. I will stay in touch ! 41 Dave
Thanks guys, I just turned over the motor tonight with the starter ****on. Gotta make linkage for the dual carbs, plug the vaccuum port and I think she will fire!
no problem. Update: Got it to idle and run smooth. Need to set the timing and adjust the carbs. The car is a bit sluggish w/ the 2 to 1 adapter.
Yep, it was the timing. Slightly retarded. Advanced it up 7 degree's and it purrrrrrrs like a kitten. The 2-1 Adapter operates smoothly. Also, Just wired up the OD trans. Test run will follow Wednesday. Ill post more pictures of the final result. Thanks all for the good comments.
The car is bad-***. And thanks for keeping us posted. Too many of the past HAMB chop cars have disappeared... I noticed the 2 HAMB Alliance tags... Did I miss the renewal date?
What are you the H.A.M.B. Police, errr Highway Patrol? It looks like the spacing of the letters turned out nice- the furlough worker done good! Thanks, Kurt
It depends on when your 2006 membership started. Go to your profile and click on 'paid subscriptions'. it shows when your renewal is due for 2007.
Speed, The rear window was lifted 4" and flipped upside-down to close the gap between the rear side window and rear gl***. Plus, it give the rear window area and roof a "tapered in" look from behind. As for the 3/4 rear view, you dont have the typical 1-2' gap in the 'sail panels' between the side and rear. Here are a couple of pictures that I had on file so you can see what I mean. My opinion on the preference of the position of the rear window is how I wanted my build, I dont mean that the other 'boxes' are incorrect. I just prefer the way it was done on mine. The rear window flipping was a mere suggestion by Killer, that was later taken literally. I thought it was a great choice. Hope this helps.
fantastic chop - the angled pillars/rear side windows, the flipped back window... really interesting and it all works. I'm filing this one away for future consideration for when I chop my sedan Love it.
