351c in 53 Ford
Discussion in 'The Hokey Ass Message Board' started by HankHearst, Apr 9, 2007.
  1. HankHearst
    HankHearst
    I have the opportunity to buy a 351c, and would like to install it instead of a SBC, if its easy enough. I know I'd have to change the Maier oil pan, but are there other problems I might encounter? Right now its got the stock flatty. Still runs, but I'd like to use it as a daily driver (I work 15 miles away round trip, no traffic, all freeway) and go faster. I'd appreciate any tips or advice, I've searched as much as I can but I can't find much info on 52-54 Ford mods.
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    The flatty makes a great daily driver. I drive my '40 daily w/stock flathead - I do 60-70 for the 10 miles of interstate I get on.
    Of course, you can put a 351C in there too - not familiar with 52-54 Fords though, so can't help you there. Standard SBF mounts will work - you're on your own after that. ;)
  3. I have a 351 C in my 52 truck, 53's I believe have more room.
    The 351 c is an awesome motor, but if I had a flathead I'd make that thing run.
  4. hot rod steve
    hot rod steve
    from compton
    its real easy. you can do it in a day. no major tools needed at all. simple swap and your done. good luck with that, now give me your flattie. they are junk and shouldn't ever be seen.
  5. FiddyFour
    FiddyFour
    you're gonna play HELL with the steering column/exhaust manifold
  6. HankHearst
    HankHearst
    the steering column is what i was worried about, I mean i don't see now i can even put headers on the flathead now. The engine runs fine, doesn't smoke but when i did change the oil I could smell fuel. I haven't taken the heads off to check for cracks cause I don't have spare gaskets. I found this page trying to get more information.
