Wide Whitewall Tire Grinding
Discussion in 'The Hokey Ass Message Board' started by Section 8, Apr 8, 2007.
  1. Section 8
    Section 8
    from AZ
    I found the elusive Doyle Killebrew and had him grind my white letters into whitewalls.
    This guy's a character, and knows all the old-timers. He has a stack of his work in magazines and letters of thanks including one from Dig Daddy Roth.
    Any questions on the process, let me know.
    The tires turned out great, $160 for all 4. He refused a tip.
    My wheels are a little rigged, but are better than the cold-cut slicer look. Still trying to decide between some steel smoothies and Torq Thrust D's
  2. bloodandwhisky
    bloodandwhisky
    from DFW Texas
    They look great, process please!
    I believe there was a video post recently covering this.
    But if this guy is doing something different, I'd like to hear it.
  3. bloodandwhisky
    bloodandwhisky
    from DFW Texas
    heres the vid
    <object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/xkcm3rh60p0"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/xkcm3rh60p0" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
    this is by BUGMAN by the way.
    heres the link to his post,
    http://www.jalopyjournal.com/forum/showthread.php?t=124144
  4. chop509
    chop509
    Awesome!
    "Smell like burnt rubber", can you imagine the black **** that comes outa your nose?
  5. Section 8
    Section 8
    from AZ
    He's been doing this since 1976 and "doesn't believe" in wearing a mask.
    The main difference between the do it yourself method with a grinder, and the ones he does, are these are slightly recessed and have really sharp lines and the texture of factory made ones.
    His machine has a drum that rotates the wheel slowly, about 15 RPM.
    It connects to a shaft driven grinder with some kind of milling head located by a couple of arms to hold it stable so it makes nice straight cuts.
  6. wvenfield
    wvenfield
    Truck looks far better with the wide whites. I'm sure doing it on a rotating device does make for a better outcome.
    Cheap does have it's advantages though. You really did improve the trucks look.
  7. pan-dragger
    pan-dragger
    the price sounds high to me. a guy does them here in denver for 15.00 a piece.
  8. Section 8
    Section 8
    from AZ
    Next time I'll drive to Denver.
  9. Jalopy Joker
    Jalopy Joker
    This is one way-subtracting rubber. Or, try Whitie's Wide Whites that does a process for vulcanizing (adding) white rubber onto your tires.
    Do the math. Whitie's has posts on the H.A.M.B., and offers a discount. Or see his site on MySpace.
  10. jchav62
    jchav62
    I just had a set done in Albuquerque for $60. I just need to get wheels now...I'm not sure if I want to run Smoothies with no caps or Supremes. I like em both...Your truck looks great by the way!
  11. mercury Bill
    mercury Bill
    8.00 a piece here in NM..
  12. y block
    y block
    from kcmo
    I like the idear of DOING IT YOURSELF on a couple $10 tires- he says (in the vid) he is only taking 1/16" off- what does this do to the integrity of the tire- surely that black rubber was needed- I don't need a blowout at 60per- I have enough to worry about (brakes, trans, frame....)
  13. Kustomz
    Kustomz
    Do they not make whitewall tires anymore? Guess I didn't realize they weren't available. Shows how long it has been since I bought a whitewall tire.
  14. tstclr
    tstclr
    If you guys are looking for wide white bias ply tires, ask your dealer if he has any blems. I inquired about a set for my 54 Chevy. Firestone WW's listed at $212CDN. I enquired about whether he had any blems and he did- $163 each. Still pricey but a significant savings. I'm going to have a look at them to see how bad the blems are...
    Todd
  15. jchav62
    jchav62
    Where?? In Albuquerque?? I usually go to this place on N. 4th Street called Cl***ic Cars. He's gone up in the last year though.
  16. jchav62
    jchav62
    Yes they do, but they are priced out of my league... Even if they are blemished. I got about $300 invested in my WW's. I've been around buffed whitewalls my whole life and no one has ever gotten a blowout because of them...I think they are fine...IMO...
  17. mercury Bill
    mercury Bill
    Bahito lowrider is where...To be honest I wouldnt piss on Cl***is cars chuckie if he was on fire.
  18. jchav62
    jchav62
    He is kind of shady...him and his son. Thanks for the info about Bajito's. I'll check with them next time.....You going to the Rumbler's show downtown next month?
  19. draggin ass
    draggin ass
    from hell
    tried it on some old skinny WW bias plys.... gummed up right away the second i touched it.....(didnt work)
  20. bloodandwhisky
    bloodandwhisky
    from DFW Texas
    ordered a set of steelie 15s w/tires and WIIIIIIIDE whites from whitie on myspace, gonna pick them up at back to the beach in ventura on the 21st. Ill update you fellas on how they look/ride.
    wayne
    oh. by the way, it was 300 for him to supply the wheels/tires and whites!
  21. mercury Bill
    mercury Bill
    lol, yea hes shady alright I'll probably go to the show. If I get my merc re-primered.
  22. metalman
    metalman
    Hey Bill, thanks on the tip, didn't know Bandito's was still around. Cl***ic Cars did my Olds last year, burned right thru on 2 tires, all I got was "sorry"
  23. Video was pretty educational,thanks.
  24. lexistars
    lexistars
    from Fontana
    Love the Video! i am itching to Try it out.. the mr Wont let me near the angle grinder yet..lol scared I will Get to close to the new tires hahaha
  25. Section 8
    Section 8
    from AZ
  26. me too, what is being removed is minimal and if that make the difference of whether my tire blows out or not, I need to get away from chinese tires and buy american chinese tires:cool:
  27. Reverand Greg
    Reverand Greg
    When you go to the Rumblers show go to Maloneys around the corner good place used work there about ran the place.Lots of smoking up stairs,if you know what I mean
