Carb Question
Discussion in 'The Hokey Ass Message Board' started by goodman, Apr 14, 2007.
  1. goodman
    goodman
    from Miami
    Do you guys know of any NEW carbs that fit this application? I'm tired of fouling spark plugs, running way to rich.
    Thanks, R
      115.3 KB
  2. strombergs97
    strombergs97
    Hello..I would check the jets in the strombergs..Really, that shouldn't be to much fuel for that engine..1.5 to 2 CFMs per cubic inch..
    Duane..
  3. goodman
    goodman
    from Miami
    It fouls the plugs at idle, I have a few cars with multi carbs set ups and the only one that idles right is my truck that has three carters on it. Any suggestions would help
    Thanks, R
  4. tommy
    tommy
    The first thing I'd do is add a fuel pessure regulator set for 2-2.5 lbs even though it looks like you are running a mechanical pump.
  5. goodman
    goodman
    from Miami
    I ready to try anything, before I put a stock carb back on it and make my life easy
    Thanks, R
  6. dochorsepower
    dochorsepower
    Yea, fuel pressure regulator. Regular pump pressure can sometimes over power the needle and seat on those Strombergs.
  7. tommy
    tommy
    Don't give up. I run dual 97s on 2 of my cars. They can be made to run just fine.
  8. dickster27
    dickster27
    from Texas
    You didn't mention what engine size, cam, heads, realistic HP rating,etc., also what size jets are in the 97's now? Given these facts we can hopefully get you back on track.
    the ****ster
  9. Spyder
    Spyder
    from Houston
    I would love to see a picture of the 3 carter set up, I have lots of carters and have thought of running the same set up.
  10. goodman
    goodman
    from Miami
    Here's a pic of the carters, and the motor is a 327 in the two carb set up.
    Thanks, R
  11. strombergs97
    strombergs97
    Hello..I would also check and see it the idle tubes have been modified..you can't believe what I've run into..Lots of times they cut the tappered end off and try to enlarge the tube..OH..Maybe the power valve is leaking through????
    Again, I don't think it's too much fuel for the engine..300 CFMs????
    Duane
  12. beetlejuice55
    beetlejuice55
    i'm running twin rochester 2g's on my 287" pontiac v-8. my motor is bone stock, and i am running straight linkage (both carbs open at the same time), and a stock mechanical pump. twin strombergs should not over carburate a small block chevy, not even a stock one. it almost sounds like your carbs are flooding over...float stuck, fuel pressure too high ? i think strombergs like 2-2.5 psi of fuel pressure max. has it always done this, or did this problem just start ?
    i don't have any problems with my rochesters, and actually...my engine starts better, idles better, and runs better with the twins, than it ever did with a single 2 barrel.
  13. Bruce Lancaster
    Bruce Lancaster
    I think any Chevy V8 mechanical pump will have around twice the pressure a Stromberg will accept.
  14. If its flooding at idle I'd also suggest the regulater. Ya might check the float adjustment also. And while your at it pull the idle needles out and make sure that they are up to snuff.
    New Strombergs are between 300 and 400 a copy if you can get 'em.
  15. scofflaw
    scofflaw
    from Ohio
    Try a regulator, but spend a little money and get a good one and a liquid filled pressure gauge.
    I was running a similar set up from Vintage Speed on my old 26-T. I had the same fouling problem but was running a regulator. Turns out, the regulator I was originally running was total junk.
    A stock mechanical sbc fuel pump puts out like 6-7 psi. I was told to run 3-3.5 pressure to the Stromberg’s to prevent needle and seat overpowering.<O:p</O:p
    </SPAN>
  16. goodman
    goodman
    from Miami
    Thanks, I'm going to try everything
    R
