3 on the tree to 3 on the floor
Discussion in 'The Hokey Ass Message Board' started by Saoutlaws_Gotti, Apr 15, 2007.
  1. Saoutlaws_Gotti
    Saoutlaws_Gotti
    any one out there done a three on a tree to three on the floor in a 53 chevy car
    how big of a ***** is it and what do i need to know
  2. matthew mcglothin
    matthew mcglothin
    its pretty easy. i own a 1952 chevy with a 3-speed. i converted it to the floor with a kit i bought at advanced auto parts . kit is from mr gasket co. took about 2-3 hrs to do. well worth it! cost about 60.00 bucks
  3. Saoutlaws_Gotti
    Saoutlaws_Gotti
    im gonna have to keep that in mind considering i only do business with two auto parts chains
    advanced and napa
    you got any pics
  4. matthew mcglothin
    matthew mcglothin
    all the pics of my car are on mad greasers c.c. / myspace. its a 52 chevy black with a white top ,chopped and bagged. i noticed your from s.a. tx. ill be over your way in may. and by the way if you and your s.a. guys arent busy april 28 were having are 1st annual mad greasers cc\hooters in beaumont . i know its a good ways away but will have a great show and alot of hotels . you guys are welcome to come over here
  5. Saoutlaws_Gotti
    Saoutlaws_Gotti
    dammmm if i had known earlier id be there but i got some **** going on that weekend
    so was this install a pretty much follow the directions in the box or was it a fab ur own kinda thing
  6. matthew mcglothin
    matthew mcglothin
    pretty much 50\50. its really a "pick-up truck 3-speed shifter" but there really all the same. as far as the install details. i did most of the work in the intierior of the car by removing the inspection cover on the floorboard. with a little bending of the mounting brackets and some stacks of washers for spacers your shiftin on the floor. hope it work for you! let met know you tou need any other details
  7. matthew mcglothin
    matthew mcglothin
    i almost forgot. i can get the mr. gasket part no. off the box tomorrow . maybe it will help to locate to part in not in stock
  8. I put a floor shift on a 3 speed in a pickup; the only tough part was cutting the hole in the floor. And that wasn't too bad.
    Just for giggles, here's the syllabus for the advanced course...
  9. 401HLWD
    401HLWD
    Maybe you can post a tech on it (or anyone else that might have done it)- I'm throwing around the idea myself with a '51 chevy coupe.
  10. choppermatt
    choppermatt
    i did it in mine with a hurst kit someone gave me, jus a generic kit for a 3 speed on floor. The hardest part was to modify the arm the reverse gear is on. I had to make the pivoting point higher on the arm. Other then that easy weld it wasnt to bad.
  11. 57JoeFoMoPar
    57JoeFoMoPar
    My '57 Ford was a 3-on-the-tree converted to the floor when I got it. It had one of those generic Mr. Gasket 3 speed shifters in it, which was a total piece of ****. It broke several times on me before I pulled it out, bought a Hurst Indy set up for $75 from Jeg's and never had another problem. Easy job even for a beginner
  12. S.F.
    S.F.
    Yeah that would be a good Idea cause I got an old hurst indy shifter im thinkin bout puttin n' my 60 Fairlane.
  13. merc-o-madness
    merc-o-madness
    i did it in my 51 chevy with the mr gasket kit pick up truck kit. It wasnt too bad, basically just fine tuning the shift linkage.
  14. screwtheman
    screwtheman
    National Chevy ***oc also sells a floor shifter kit specific to the Chevy trans. Looks pretty beefy. But I've never used it. :D
  15. Saoutlaws_Gotti
    Saoutlaws_Gotti
    you happen to know the price on that bad boy or perhaps a part number
  16. sinner13
    sinner13
    from Buffalo NY
    Coppied from National Chevy
    $169.00
    ProdNo 7105
    Designed to fit your 1949-54 exclusively – not a universal fit. Shifter does not interfere with the seat and shift pattern fits the car perfectly. Pre***embled, easy to install and instructions are included.
  17. triton6972
    triton6972
    I would advise on a good quality shifter like a Hurst or one like Sinner13 recommended. Never had any luck with those Mr. Gasket ones. In my opinion there ****. They shift sloppy and the mounting brackets ****.
  18. 49Dodgeboy
    49Dodgeboy
    Not to hi-jack, but anybody ever done a Mopar?? '48/'49
  19. Saoutlaws_Gotti
    Saoutlaws_Gotti
    hey thanks sinner
    you one of these in your car
  20. sinner13
    sinner13
    from Buffalo NY
    Nope, mines to slow....if I had a stick I would try to drive it like a race car ;)
