1958-1962 Chevy inline six serial number decoding
Discussion in 'The Hokey Ass Message Board' started by flatblackindustries, Apr 25, 2007.
  1. flatblackindustries
    flatblackindustries
    from Ogden, UT
    Can anyone help me with my 1958-1962 Chevy inline six serial number decoding. The casting number says its a 1958-1962 235 but I can not find any other info based on the serial number stamped just left of the Dist.
    Anyone know how it works or a good web page to help decode exact year/plant etc. etc.
    Number reads : F I 0 2 I J C
    Thanks
  2. squirrel
    Flint
    october 21
    59-62 pickup truck 235 with manual trans and heavy duty clutch
    if you look on the block kind of hidden by the starter you might find the casting date code, it will look like J 2 9 or something, the last digit is the last digit of the year.
    since it was made in october the casting date will be for the year of manufacture, the model year will be the following year, as production started around the beginning of Sept, I think.
  3. flatblackindustries
    flatblackindustries
    from Ogden, UT
    Damn,
    I figured you would be the first one to chime in.
    Kinda hard getting parts from the local the parts store without a year. Those numbers doe not specify truck type right?
    C10 1/2 ton, corvair series van, etc?
    This is a transplant in a 1952 GMC "101 22 P 35297" so I don't have the vin ***ociated with the engine to cl***ify.
    Thanks a ton squirrel
  4. squirrel
    That engine code JC was used in light and medium trucks for a few years.
    glad to help!
  5. Longbox55
    Longbox55
  6. flatblackindustries
    flatblackindustries
    from Ogden, UT
    Longbox,
    Thats what was confusing me. I am familiar with the corvairs but for some reason all of the stovebolt number runners I was using kept pulling it up in the same field as 1961 corvairs/vans etc.
    Anyhow here is the number behind the starter on the block: J177
    So am I looking at a engine manufacture year of 1957 / model year 1958 right?
  7. squirrel
    yeah, should be an October 17 1957 casting, used in a 58 truck, although my book shows that the JC code was used on the 4000 series truck (1-1/2 ton), not a pickup, in 1958.
    it's still a 235 though.
  8. bobby terry
    bobby terry
    I have a 57 with a 235 I thought need to know what year the motor is numbers and letters by distributor are FI229B and behind starter is CON4 L 27 1
  9. squirrel
    L 27 1 probably means December 27th, 1961 casting date. B would be a 235 with a Powerglide transmission, in a 1962 p***enger car.
    The engine was ***embled in Flint on Dec 29th.
  10. bobby terry
    bobby terry
    So not the original motor that came with the truck then
  11. squirrel
