I have issues
Discussion in 'The Hokey Ass Message Board' started by Dreddybear, Apr 28, 2007.
  1. Dreddybear
    Dreddybear
    Space issues. One-car garages=:mad:
  2. Goztrider
    Goztrider
    from Tulsa, OK
    I've got 2 Model A (AA) trucks in a 14' wide space. My garage is 18' wide, but I've got at least 2' of shelving and storage on either side. They're so close together that you cannot walk down one side or between them.
    I feel yer pain. I'm dreaming of that house we're going to buy in the future where I can have a 30x50 shop!
  3. squirrel
    put the pinball in the living room where it belongs....
    but other than that, I can' offer any help, just sympathy. And it doesn't get any better when you get more garage space, we have 10 cars in the two garages and still not much room to work!
  4. Dreddybear
    Dreddybear
    That'll be nice (30x50). I dreaming of a two car garage at this point. And I'm sure if I had a two car I'll need a three and so on and so on...
  5. Ford Freak
    Ford Freak
    I am in the same boat. I have about a 1.5 car garage. 20 yrs. ago I built a small barn/shed in the back yard for things like engine crane, etc. that I don't use regularaly. It helps, but now thats full of **** too! Help!!!:eek:
  6. Dreddybear
    Dreddybear
    And that pinball is heavy. Living room is three floors up. Plus just to get in I have to roll out My sand cabinet and gantry..
  7. squirrel
    the back of the pinball comes off, you know...just unplug the 3 or 4 cables, and take out the 4 bolts. makes it a lot easier to move up stairs! (yes, I've done it)
  8. rodknocker
    rodknocker
    build up,as in putting shelves in up high or a small loft, for the creeper,stool,exhaust etc.
  9. 32chevysedan
    32chevysedan
    from Texas
    Send the Hemi my way......I will store it for you........
  10. Dreddybear
    Dreddybear
    Oh I know, My apartment is worse than my garage:eek:
  11. 29bowtie
    29bowtie
  12. Belchfire8
    Belchfire8
    Doesn't really matter how big you build, you'll "expand to fill your available space"...I think it's a physics thing or something...I have a four car, 24 X 46 shop/garage and I still have to walk sideways between stuff!
  13. joeycarpunk
    joeycarpunk
    from MN,USA
    This is true, room is always an issue. Put bigger tools on wheels, get stuff of the ground and hung up will help. I've had smaller garages and now have bigger garages and pole structures. I just acquire more treasures.:eek: :cool:
  14. 3Mike6
    3Mike6
    I'll add what;s asaid above...
    When I lived "in the city" with a small 2 car garage, I was able to keep my projects truck, welder, small lathe, tools, compressor and my DD Camaro inside...
    Fast foward a few years (about 6), I have a 22x36 built in front of a 18x24...have a 20 x 60 barn...acess to more space too...all full and I can't walk through anythnig in a straight line.
    Keep is small, one project at a time...otherwise you'll go nuts;)
  15. LordMaximo
    LordMaximo
    from Roy, UT
    Nice little hole...lol...sorry for the pun......I have found that those industrial shelves work wonders for space saving. Not the BS shelving you would normally see being offered up in th emens stores, but the very same shelving they use for their inventories and wares.
    That industrial shelving can be had for cheap, and actually is strong enough to hold engines, welders, compresors, heating units, anything you can think of, off the floor.
    You can set it up on two walls in your garage and have plenty of floor space to work. Good luck to all of you with limited floor space, I found it works perfact and gives me more then enough.:D
    Maximo
  16. J Man
    J Man
    from Angola, IN
    Industrial shelving? where do you find that?
  17. Q
    Q
    By the way, where does (did) the door in the corner go? :D :D :D
  18. Judd
    Judd
    Looks to me like Y'all are bragin about havin garrages!
  19. petebert
    petebert
    wow your 1 car garage is huge! let me find a pic of my car in my military base housing garage. working on the p***enger side I actually lean against the wall.
  20. I too feel your pain! I moved out of a full 80X144 that had space for 52 cars into a 26X55 with room for 4 cars if I'd throw all my good stuff away!
    More space = More ****! there is no way to win
    on the flip side every car I've ever built sat in one space till it was finished. less space = fewer projects = more focus and earlier completions
  21. squirrel
    yup, after not having one, it IS something to brag about!
  22. Casey
    Casey
    take the hemi apart and reasemble it in the living room where it belongs ! it will complement the pinball machine ? wall standards screwed to the studs , with shelves above your head, dont take any floor space, home depot!
  23. petebert
    petebert
    Homer: Hmm. I wonder why he's so eager to go to the garage?
    Moe: The "garage"? Hey fellas, the "garage"! Well, ooh la di da, Mr. French Man.
    Homer: Well what do you call it?
    Moe: A car hole!
