Rusty floored 38 Ford, Need some measurements
Discussion in 'The Hokey Ass Message Board' started by RonH, Apr 29, 2007.
  1. RonH
    RonH
    I need some help getting some measurements on a (solid) 38 Ford 2dr humpback. Basically the floors on mine are completely rotted away to the point where they're only attached at the back.
    I want to weld some triangulation in to stabilize the body, but first I need to establish just how wide the body is at certain points.
    Point 1 is at the base of the firewall, I need the measurement from there to the opposite side of the firewall.
    Point 2 is 3" above the top of the hinge plate, I need the measurement to same place on the other door.
    Point 3 is just below the mount for the dash, once again I need the measurement to the opposite side under the dash.
    Point 4 is 12" below the point marked as ref, measured to the opposite door.
    Point 5 is just about the wheel well, to the opposite wheel well.
    Thanks guys this will help alot.
    Ron
  2. RonH
    RonH
    ttt on the hope that somebody can get me the measurments.
    If not could somebody point me to a dimensioned picture of the frame that I can take the body mount locations off of?
    Ron
  3. 35WINDOW
    35WINDOW
  4. RonH
    RonH
    Thanks, that helps!
