Pinstripers, I have a one shot question?
Discussion in 'The Hokey Ass Message Board' started by 29 sedanman, May 4, 2007.
  1. 29 sedanman
    29 sedanman
    from Indy
    Will one shot hold up to gas with out clearing over it?
    Beneath my gas fill on the back of my car I want pinstriped but oc***ionally if not paying real close attention the gas will back up out of the fill neck while filling and run down the back.
  2. 29 sedanman
    29 sedanman
    from Indy
    Here is the car and area in question. You can see a little bit of a stain down the back in this shot.
  3. PeteFromTexas
    PeteFromTexas
    I Have Never Used Gas On One Shot But I Would Think If Mineral Spirits Would Cut The Stuff Then Gas Would Also...
  4. Stu D Baker
    Stu D Baker
    from Illinois
    Not sure about the gasoline, but I know for a fact that hog urine will soften and lift one-shot. Please don't ask how I know this tidbit. Stu
  5. chaddilac
    chaddilac
    After a couple days of setting, you can wipe over one shot with mineral spirits. But I've never gotten gas on em... stripe something let it set and them get some gas on it.... probably wouldn't be a problem if you wiped it down rather quickly... or keep a rag handy!
  6. IGOR
    IGOR
    I did a tank for someone and the stripes stayed. It ate the paint from underneath the stripes.
  7. 1Shot-Scot
    1Shot-Scot
    from Minnesota
    If it's good and cured it can handle the occasional splash...
  8. hsheartaches
    hsheartaches
    Make sure it's catalyzed with hardener. Then it won't go anywhere. Stripe fast!! :D
  9. FASI
    FASI
    What catylst do you use to "harden" the One Shot?
  10. 29 sedanman
    29 sedanman
    from Indy
    Thanks for the info guys. I appreciate all the replys.
    When I have it striped I will ask them if they will put the hardener in.
  11. oldbobsign
    oldbobsign
    1-Shot #4007 hardener
  12. Doc22
    Doc22
    It should hold up fine. I know that once the one shot fully dries 48-72 hours that stuff is pretty bullet proof, even without hardener. I'd go for it.
  13. 29 sedanman
    29 sedanman
    from Indy
    Thanks, That is what I like to hear.
  14. Unkl Ian
    Unkl Ian
    Safariknut suggests don't wipe the gas off,pat dry instead.
    Less likely to smear anything.
  15. ruralrod
    ruralrod
    ditto tracy. i'd go for it. that'd look great back there. how ya been?
  16. MIGHTY
    MIGHTY
    wipe it off right away preferably with soap an water. Be careful fillin her up. gas is nothin nice just dont let it sit on there.
  17. pimpin paint
    pimpin paint
    from so cal
    Hey,
    This is gonna have alot to do with where you're buying your fuel.
    Out here in SoCal, we have Alcohol in our fuel, pretty much 12 months a year ,thanks....Tree Huggers! With the new no-lead
    One-Shot formulations, I'm not lookin to get the colour hold up
    we've come to expect from this product.
    DO NOT SHOOT CLEAR OVER ONE-SHOT WITHOUT A HARDNER!
    Expect white and pastel colours to discolour , over time, if fuel
    splashed.
    S****ey Devils C.C.
