Oil Filters
Discussion in 'The Hokey Ass Message Board' started by Betruger, May 4, 2007.
  1. I'm wondering (because I have to crawl under the wagon this weekend) what the concensus is in regard to what the best oil filter for the money might be ( 355 Chev motor). I always use NAPA's "silver" filters, anything better out there? T.I.A. Your Pal, -Betruger- :D
  2. George
    George
    There's a couple of threads on this subject. You have a good one. Wix also, actually there were several brands listed as good, Framwasn't one of them.
  3. AWWWW... But Fram's got that grippy **** on em'...
  4. lol i see so many of those come into the shop every day, they dont work for **** when there is a quart of oil burnt onto it
  5. brownbagg
    brownbagg
    from grand bay
    napa and wix are the same filter, I use fram for the grip
  6. Fraz
    Fraz
    from Dixon, MO
    Wal-Mart uses Fram and Pennzoil on their oil changes. All of us that work in the TLE department and know their **** use other filters and brands of oil.
    Wix and Havoline for me thx.
  7. Paul2748
    Paul2748
    Yhe NAPA "Gold" filters are supposed to be a**** the best on the market.
  8. Shifty Shifterton
    Shifty Shifterton
    Purolator is my off sale choice for standard filters, but will run almost any brand's "premium" version if it's on sale. Except fram, have cut apart new ones and seen scary things. I figure that regular changes are more important than the filter brand ultimately
    Here's my advice. Invest $25 in oil filters, pick an engine you own and buy one of each brand. Cut em apart with an exhaust cutter. Wipe out the can and see what's in em. Look for manufacturing debris. Verify media quality. That's how I got to purolators. It gives more comfort in my choice than any amount of internet hooey.
  9. 1950Deluxe
    1950Deluxe
    from Kansas
    I run purolator or Microguard. Fram filters are JUNK. I cut one open once and it looked like mush. I also run the big block chevy filters for a 454 mainly because they are a little bigger and will hold a little more oil inside. Bigger is better right? Just my opinion!
  10. napa gold or wix only for me
  11. Sracecraft
    Sracecraft
    It's policy at work, to cut every oil filter open that I remove from a race engine. All different kinds. They are not all the same inside,
    I have been using Wix racing filters, Napa stocks them for popular engines, as Napa Racing Filter, same thing. I think they make a good filter.
    Craig
  12. 29 sedanman
    29 sedanman
    from Indy
    I have switched to WIX.
    Had always used AC but latley the quality seems to be going down with everyone I buy. The last one would not even spin on the threads were so screwed up. That was probably thae last one I will ever buy.
    It is good to hear good reviews on the WIX filters.
  13. petebert
    petebert
    someone has done it for you http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
  14. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    Wix branded, Carquest Blue, and NAPA Gold are all the same filter. Part numbers are even similar. A Wix oil filter for Ford is 51515, Carquest Blue is 85515, and NAPA Gold is 1515. The NAPA silver and Carquest Red are secondary lines designed for low price customers. The difference between the premium (Wix branded, Carquest Blue, and NAPA Gold) and the secondary line (Carquest Red and NAPA silver) are interior differences; fewer pleats of the filter media, gasket material is different, by-p*** design and material is different. The same applies to the air filters. Although there are some numbers in the secondary air filter line that are exactly the same as the premium line, only the part and price is different.
    Dan Marvin, Owner
    Exeter Auto Supply
  15. andysdeuce
    andysdeuce
    I use a k&n filter on the hot rod...seems to do a pretty good job. Generally fram on the daily drivers.
  16. pasadenahotrod
    pasadenahotrod
    from Texas
    This got a lot less response than I thought it would. I always go with the WIX filters. Usually use Valvoline which is the hose branded oil in both CarQuest and O-Reilly's, maybe NAPA too.
  17. yekoms
    yekoms
    NAPA Gold/Wix filters. Valvoline VR1 oil.
    If you don't have a roller cam drop in a jug of GM E.O.S at oil change.
    Racing oil filters are like screen doors they only keep the big bugs out. The gnats still get in. Smokey
  18. Fullblast
    Fullblast
    Where can you get the "GM E.O.S."?
  19. yekoms
    yekoms
    General Motors Engine Oil Suppliment.
    Part number #1052367
    At your local GM dealer.
  20. johnnykck
    johnnykck
    I use Mobil 1, probably the best filter out there. At least that's my opinion, pricey though.
