Good source for pre-cut tabs, threaded bungs, gussets, etc.
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, May 8, 2007.
  1. scootermcrad
    scootermcrad
    I know there are quite a few sources that sell pre-cut gussets, tabs, threaded weld-in bungs, engine mounts, things like that. Can you guys recommend some places? I know only of the Welder Series website and also I noticed that Speedway carries a few things, but not seeing what I want.
    Also, looking for someone who sells just the weld in bungs with the 7* ID taper that mate up to the Ford style tie rod ends that everyone uses with their split wishbones. Need a source for those pretty quick.
    Thanks guys!
    Scooter
  2. I got the bungs for my split wishbone from Speedway, maybe ten bucks. I have some sources for the other stuff, i'll get back to you.
  3. SUHRsc
    SUHRsc
  4. scootermcrad
    scootermcrad
    I've got the one's that are tapered on the outside diameter that weld into the bones. That's a done deal. I mostly need the ones that will weld into the frame that have the tapered ID.
    What I would do to have a lathe in my garage. I wouldn't be asking questions like this! :(
  5. Bruce Lancaster
    Bruce Lancaster
    Also, get a catalog from Stock Car Products, circle track place. Lots of neat hardware, all a bit different from drag/streetrod type places.
    Their truck bar page is pretty neat, too.
  6. scootermcrad
    scootermcrad
  7. Get one of these. I had one, very high quality and U.S.A. made! Way better than the Harbor Freight, etc. 7x10, but a little smaller. Perfect size for making stuff like this, though. Although it doesnt have change gears(but can be modified) get a few few taps and dies, and you're in business.
    http://www.taigtools.com/
  8. SUHRsc
    SUHRsc
    for the price speedway sells those bungs for...i dont even waste my time at the lathe
    I've done a few in alot larger diamater steel and also the main advantage to the lathe is that with a 4 jaw chuck you can clamp in a non round part and put the taper anywhere you want it on that part....saves having a weld on the end of your wishbone mounts
    Zach
  9. brandon
    brandon
    i have bought some stuff from the "real products" on ebay .....fast service....and the prices are nice......they are worth a look .......
    horton's welder series stuff is nice stuff too...... brandon:D
  10. scootermcrad
    scootermcrad
    This was my theory as well. Same with the gussets. I didn't feel like going a whole stick of flat bar to make something that was already made for me and I could use that time to work on the 1-million other things I need to do on this damn car.
  11. brandon
    brandon
  12. rooman
    rooman
    Besides those already listed here are some alternate sources of spuds, bungs, tabs and brackets (and all sorts of other widgets too). The first two are circle track oriented so their stuff is generally beefier and more suited to hot rods. The others however have lots of trick stuff that can make life easier.
    Coleman Racing Products: www.colemanracing.com
    Bicknell Racing Products: www.bicknellracingproducts.com
    Ch***is Shop: www.ch***isshop.com
    Ch***is Engineering: www.ch***isengineering.com
    Roo
  13. what fenders
    what fenders
    i get some stuff from the ch***is shop www.ch***isshop.com good sorce for brake fittings too
  14. rodknocker
    rodknocker
    check out your local steel supplier for gussets,my steel place sells them different sizes dirt cheap,they're mostly s**** for them,gold for me.
  15. nmpontiac
    nmpontiac
    from Taos, NM
    Look at TabZone on line. All kinds of stuff in the way of tabs, etc.
  16. scootermcrad
    scootermcrad
  17. Sellers Equipped
    Sellers Equipped
    from San Jose
  18. Clyde
    Clyde
    from Las Vegas
    Scooter,
    Try the local sand buggy shops thay are down off of Valley View. Tons of stuff to choose from and you can get you hands on them, instead of ordering from pic's.
  19. J.D.
    J.D.
    from Clovis, CA
  20. flt-blk
    flt-blk
    from IL
