Sorta offset carb adapters???
Discussion in 'The Hokey Ass Message Board' started by Fat Hack, Apr 8, 2004.
  1. Fat Hack
    Fat Hack
    from Detroit
    I was telling my brother in law about the slightly off set 4v carb adapters I remembered seeing years ago at local speed shops (now defunct). They basically bolted to the intake and allowed you to position your carb either a little further forward, or rearward, depending on which way you installed them.
    It wasn't a BIG offset...like maybe a half inch or so...just moved the venturis back or forth a little to allow the carb to clear obstructions such as another carb, a distributor or whatever.
    (He bought an Offy dual quad manifold for his 348 and wants to run Holleys, but they won't quite fit. With the offset adapters I was recalling, he could do it...although I think two CARTERS look better on a 348/409...and they'd fit without adapters!)
    Maybe it was Trans-Dapt or Mr Gasket that sold the adapters?
    Anyone know...or have a couple?
  2. Germ
    Germ
    I think SAMIYAM showed me soem WEIRD **** like that one time in HIS GARAGE,, But then AGAIN sam HAS the COOLEST **** in his GARAGE,,,,
    It's like he DOESN't EVEN care it's there......
    he had some weird CARB and INTAKE stuff for the NEWER carbs,,,,,
    I need to get that ***** to sell me some 97's,,,
    Maybe I was seeing things
  3. gettingreasy
    gettingreasy
    I remember seeing some Offy offsets, they offset it like 4" tho. I belive they were for a dual quad to make it into a crossram lookin intake, they were pretty damn cool looking.
    -Jesse
  4. Lownwuf
    Lownwuf
    They are made by Offenhauser, lets you run duel Holleys without the float bowls hitting. I dont have my Offy catalog handy or I would look up the part # for you.
  5. Phil1934
    Phil1934
    #5880 $50/pair in PAW
