Traditional Custom Tech: '49-52 Chevy Quarter Panel Scoops
Discussion in 'The Hokey Ass Message Board' started by Bass, May 25, 2007.
  1. chopolds
    chopolds
    from howell, nj
    Nice use of Packard trim,, as well.....great choice!
  2. Ok Flame Me Some
    Where's The Lite's Gonna Mount and What Kind WilL They Be For These Rocket Pockets?
  3. FASI
    FASI
    Very well done....
  4. Bass
    Bass
    from Dallas, TX
    Thanks 'FASI'....as you can see I'm really fond of your car! What are these teeth anyway? I knew at one time, but now I can't recall.
    Beautiful job, by the way.
  5. BadLuck
    BadLuck
    *****in'...looks like a missle launcher!
  6. Petey
    Petey
    I really like it.
    Good job.
  7. great car! very traditional. i'm not a fan of "too much" either. you nailed it. please do a post on that merc surround.
  8. Elrod
    Elrod
    Awesome touch, and well done!
    I was curious about that pocket collecting dirt, dust water, etc... Did you build a drain hole into that? Is one needed do you think?
  9. 67Imp.Wagon
    67Imp.Wagon
    Really nice touch.Definately a custom with a "K"
  10. Once again BAD ***. Keep us posted on the build. Looks like you are staying busy with the new shop.
  11. Slate
    Slate
    Great job! I have a similar question as Elrod, as I despise rust and try to think of any long term way of avoiding rust. Will you put in a drain hole (or do you think that it will just get water coming in from the wheel well? I was thinking that (for those who do this later) the slope of the bottom of the pocket could run from the rear to the front, so that any moisture will drain back out without having to put in a drain hole. I know this is just picky ****, but just a thought for those doing this next time. Not to detract from a really cool mod!
    With the side trim, it really dresses up the car!
  12. Bass
    Bass
    from Dallas, TX
    That is exactly what I did! You can't tell from the pictures, but the scoop insert is set into the car at enough of an angle to create a back to front downward slope, so that water will run out the front edge if the car is sitting still. If the car is moving, the air moving into the scoop should create a bit of a "blow dryer" effect and dry out the inside.
    It'll probably collect some road grime regardless, but it'll just have to be cleaned when the car is washed.
    I didn't want to take the opening all the way back into the wheelwell, because it would then collect brake dust, and mud or rocks or whatever else the tire would throw into it.
    I am however considering making the scoop functional to feed some fresh air into either the rear p***enger compartment or back into the trunk to the air compressors for the air-ride. It would be fairly easy to add a tube into the top of the pocket and either route it into a vent in the rear interior panel, or into the trunk.
    Anyway, thanks for bringing that up...it's a detail I inadvertently left out of the intial post.
  13. Slide
    Slide
    You might want to call Frank Livingston before you do that. He left them open in one of his Fleetlines, and it took him a while to figure out why his headliner kept flapping when he was driving.. even with the windows up!
    Really nice work, though. This is already a real nice car.
  14. publicenemy1925
    publicenemy1925
    from OKC, OK
    Very cool. great tech.
  15. It's work like this that makes me realize that I am not nearly the fabricator that I wish I was. Amazing work
  16. flt-blk
    flt-blk
    from IL
    Looking good Brian,
    I always wondered what you did over there.
    And when did you get a slip roll???
  17. Vrey great work,its awesome to see crafstmanship like that,thanks for the post and inpiration.
  18. bigken
    bigken
    Hey Bri, that looks fantastic. I too, like watching the progress. Keep up the good work.
  19. Ole Pork
    Ole Pork
    I've been contemplating a scoop on my '51 project for some time now. That is ***-bustin' great . I don't care for the teeth, but I think I'll go w/some lighting in the scoop for nights. They say imitation is the most sincere form of flattery. I think a lot of us w/be flattering you, Bro. Really great job, and a superb job of do***enting it. Keep up the good work...Ole Pork
  20. Woogeroo
    Woogeroo
    from USA
    well done, I love it.
    -W
  21. bobx
    bobx
    from Indiana
    damn that car looks good.
    nice job.
  22. lonestarvulture
    lonestarvulture
    from TEXAS
    thats a really sharp ride, thanks for sharing!
  23. kustombuilder
    kustombuilder
    from Novi, MI
  24. Bassfire
    Bassfire
    from Mart, Tx.
    Looks great! Gotta get by the shop and look at it in person.
  25. SinisterCustom
    SinisterCustom
    WOW!!!!
    Nice.....
    Good to see a NICE kustom being built a**** a sea of hotrods here......
    Gonna be a jaw-dropper.....
  26. mortecai
    mortecai
  27. gbones32coupe
    gbones32coupe
    just have to say that is cool
  28. rytang
    rytang
    from Arizona
    Amazing work!!
