Bodymen Favorite Filler?
Discussion in 'The Hokey Ass Message Board' started by SlowandLow63, May 26, 2007.
  1. Squablow
    Squablow
    All my cars are filled with Rage.
    Me and my buddies have a little ongoing joke, whenever we're ready to spread mud we say we're going to put some more Rage against the machine.
    I've also used Marson Body Light and that USC stuff, and the Bondo brand. That stuff's all about $12/gal around here and it works but it's not as good as Rage.
    Another tip I learned recently. If your mud seems too thick in the can, or if it's a little dried out from the top not being on it, put some fibergl*** resin in it and mix it up (resin, not hardener!) It'll smooth it out very nicely and make it more workable.
  2. SwitchBlade327
    SwitchBlade327
    Another vote for Rage Gold....stuff spreads like ****er if your use to using cheaper filler.
  3. K13
    K13
    You can use pourable putties like Metal Glaze to do the same thing if you don't have resin around.
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    Thats a really gay joke, but it made me laugh. Now thats all I'm gonna be thinking while I'm working. *******!
  5. SinisterCustom
    SinisterCustom
    I've always used Martin-Seynour *sp? Micro-Lite......I'm going to try the Rage Gold on my next project....thanks guys!
  6. asher
    asher
    Dyna-deLITE
    I love this stuff.
  7. Mudslinger
    Mudslinger
    Good old Bondo. I have used that more than any.
    Rage Gold and Rage Lite.
    I also use to use duragl*** for filling behind fender patches to try and keep the water out, it seemed to work.
  8. slamdpup
    slamdpup
    i was just going through some old post and found this ..did anyone ever take my advise about the upol fantastic just curious
  9. customcory
    customcory
  10. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Hahaha. :)
  11. Bugpac
    Bugpac
    Use the keystone brand, as its just rage with a mask on, and its less expensive...
  12. SlowandLow63
    SlowandLow63
    from Central NJ
    Haha, I'm very close-minded, I tried the Rage Gold and loved it. Haven't used anything but, since. After all someone once said it was made with real bits of Rage, so you know its good.
  13. 56Sedan
    56Sedan
    In my shop I use mostly Evercoat products, Z-grip, Rage are the ones I use the most. I've used their "Lightweight" with the red & white label.. not bad for a budget filler.
    I also like their finishing putty with the blue label.. the name escapes me at the moment.
  14. kopis
    kopis
    I have used Rage gold and xtreme. They both work well for me, honestly cant really tell the difference between the two. But then again, I have never used them at the same time to compare. good luck.
  15. MetalMike
    MetalMike
    Nobody has said anything about Platinum. Every shop that I have worked at uses that stuff for a reason. P.S. Not to talk ****, but those who are talking about kittyhair etc. go buy a set of bullseye picks and a metal file. OUCH! The mental picture is UGLY! Here are some pics of something with 'gl*** before, and then after.
  16. publicenemy1925
    publicenemy1925
    from OKC, OK
    I am not a fan of the Marson Platinum. From pinholes to sanding, not a very good filler. Kinda reminds me of Dynalite.
  17. MetalMike
    MetalMike
    Funny how Squeeg's is a world cl*** paint joint, and that's all they use...
    This is gonna be a ******* contest I am sure, but just my 2cents....
  18. publicenemy1925
    publicenemy1925
    from OKC, OK
    Just not a fan of the product. Take it however you like.
  19. lostn51
    lostn51
    from Tennessee
    lead is the preferred medium with me now that i am getting the hang of it.....sorta lol. but evercoat polyester glazing putty rocks!!!!!
  20. 5wndwcpe
    5wndwcpe
    Same here. ;)
  21. MetalMike
    MetalMike
    I am not taking it wrong, what product do you like the best?
  22. SlowandLow63
    SlowandLow63
    from Central NJ
    No one's trying to discredit another's favorite product here, its not that serious.
  23. 8flat
    8flat
    I'm a huge fan of Rage...
  24. publicenemy1925
    publicenemy1925
    from OKC, OK
    I use rage at work with great results. I have used Evercoats z-grip and found it to be very good too. We stock marson platinum at work and i have used a gallon and it's not for me. The rage works best all around, sanding, provided it doesn't sit overnite. The painters are very happy with it to, and in this business, happy painters make for happy bodymen!
  25. ReposGarage
    ReposGarage
    from denton tx.
    rage ............its super easy sand,and this stuff called half time is pretty bad *** too
  26. lucky
    lucky
    been using platinum for years...will give the rage a try sometime
  27. I use rage Gold and then use Fibergl*** resin mixed into the final batch of Rage so it smooths out like gl***. Saw this on a Paintucation video and it seemed to work killer.
  28. HELLMET
    HELLMET
    upol also makes some nice fillers and glazes their dolphine filler is like rage in a bag and is like 12.00 a bag.billy
  29. happy hoppy
    happy hoppy
    do you add a separate hardner for the resin or does the rage hardener take care of that?
    I gotta try this,
    David
  30. Abomination
    Abomination
