Mystery SW part...
Discussion in 'The Hokey Ass Message Board' started by Ruiner, Jun 14, 2007.
  1. Ruiner
    Ruiner
    Before anyone makes a crack about the "invisible" part, I don't have pics of it...what "it" is, is a Stewart Warner piece that was screwed into the speedometer cable port on a Saginaw 3 spd gearbox, I first thought it was to adjust the speedo for oversized tires/gearing...but it appears to be a 1:1 drive...it's not a straight through box, but rather a dog-leg about 2 inches long...is it indeed what I thought it was? I'll try to get the serial number for you guys later...
  2. 55 dude
    55 dude
    sounds like something for clearance, like going around crossmember. with 1-1 ratio thats my guess but after looking at the picture probably a yugo part.:D :D
  3. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    SW made right angle adaptors for changing cable direction in tight spaces. Sound right?
  4. modernbeat
    modernbeat
    from Dallas, TX
    Most likely an angle adapter for clearance in the tunnel.
  5. modernbeat
    modernbeat
    from Dallas, TX
  6. lanechange70
    lanechange70
    It should be for correcting ur speed it may only be 0.90-1.10 correction. you may have to turn it 10 revolutions to see it turn9-11 times, if ur doin 66mph and only reading 60mph. 4wd's may use as much as 2.5-1 but recheck it, some cars offered more than 1wheel/tire combo and corrected the speedo by this item only camaro/nova with 195/70r14 w/o,235/60r15 w
