Axle drop problems
Discussion in 'The Hokey Ass Message Board' started by KrisKustomPaint, Jun 13, 2007.
  1. KrisKustomPaint
    KrisKustomPaint
    So it probably wasnt the best idea to use a model A kingpin in my axle dropping jib but i had one so I did and now its stuck. any ideas on getting it out? I tried heat and beat the hell out of it but all i managed to do is break an impact socket.
  2. KrisKustomPaint
    KrisKustomPaint
  3. litemupok
    litemupok
    no idea. bttt
  4. skidmarkjunkies
    skidmarkjunkies
    Use your axle as a wall hanger, and Buy one from an Alliance member here on the board. There is alot to heating and dropping an axle i would not try it myself. Good Luck
  5. Bondobob
    Bondobob
    Hydraulic press should do it. Oil it up first.
  6. KrisKustomPaint
    KrisKustomPaint
    [​IMG] Re: Axle drop problems
    <HR style="COLOR: #999999" SIZE=1><!-- / icon and ***le --><!-- message -->Use your axle as a wall hanger, and Buy one from an Alliance member here on the board. There is alot to heating and dropping an axle i would not try it myself. Good Luck
    dropping the axle wasnt a problem but i should have used a solid king pin. I'm gonna try to cut the king pin out with a sawzall so i can get the axle in the shop press. i guess i bent the king pin while i was dropping it.
  7. funguynstc
    funguynstc
    i dont think a sawzall will mark a hard king pin,best bet is like BONDOBOB said,press it out
  8. 5wbomber
    5wbomber
    hahaha...................shoulda left it for someone else..............us the later kingpins...........to get that one out use a br*** punch and wailon it.
