How to title a car with no VIN??????????
Discussion in 'The Hokey Ass Message Board' started by Lucky77, Jun 19, 2007.
  1. the-rodster
    the-rodster
    Yup, good idea.
    Rich
  2. I Drag
    I Drag
    I'm going the Broadway ***le route (papers not back yet). I have a car, with VIN, no ***le, bought legally.
    RustyNYer, with all due respect, the red tape increases the closer you get to NYC. Still, I hope you're right.
  3. Swifster
    Swifster
    As just mentioned, no two states are alike. What works in OK will not work in MI. The vehicle inspection needs to be done before the vehicle can be ***led. That car will not p*** a MI vehicle inspection. The Secretary of State in MI handles the ***les and license plates in the same office. You need a VIN before a temp plate/tag will be issued. It doesn't work the other way around.
    Look, waiting until the car is done is not the time to address ***le issues. It's when you buy the frame/shell. You need to get with the local police on the requirements of a vehicle inspection and with your local DMV for ***ling and plates/tags. This guy didn't have to go through the greif he's going to go through now. And as I mentioned, he hasn't even thought out the insurance portion of this. While insurance is required, I think he'll find it extremely hard to find an agent willing to write the policy. Adjusters aren't dumb either. If I saw a riveted plate on the frame, or numbers punched on a non-original frame (and I know the difference), the car will get sent to underwriting or SIU (Special Investigations Unit).
    EDIT: Just a note. This isn't the adjuster trying to be a *****. It is their job to verify that the car insured is what the owner is driving. Insurance fraud is why insurance rates are as high as they are. Stolen cars are sold with changed/altered VINs and the age of the car doesn't stop this from happening.
    In the case of the Pontiac above, the time to worry about ***lling that car is now. Join the Pontiac/Oakland Club and find out where the serial numbers were stamped. Use that number. Get a good, clear photo of the number and take that with you, pay your sales tax now and be done with it. It is not illegal to replace a cowl tag with a new one. It is illegal to misrepresent a car as something it's not. This is called fraud. Ask Boyd Coddington!
  4. Aman
    Aman
    from Texas
    I was down at DMV the other day and there is a big sign on the wall that states that submitting any paperwork with false or misleading information about a motor vehicle was a FELONY! Now go on down there and lie about it!!
  5. shiner1
    shiner1
    When was the last time somebody from DMV came out and made sure you had a VIN # on your car? As long as the VIN # is on the ***le, which it should be! then that is the VIN # and that's all they need to know, or want to know. Even if you get pulled over, when was the last time a cop checked your block or frame for a VIN #? Never happened to me nor have I ever heard of it happening. The only time no VIN could be a problem is if the vehicle is stolen, then the police will need the VIN for identification purposes.
  6. nick_s
    nick_s
    from Ohio
    Here is the answer to your question-
    Now get a br*** tag, engrave it with that number, either make another tag for the frame or stamp that number in the frame as instructed in previous posts...then go and get the ***le transfered into your name. What is so hard about that?
  7. ZZ-IRON
    ZZ-IRON
    from Minnesota
    rustynewyorker, is right on ! A tech post that's right on the money for all the States.
    Hey were not running drugs, were trying to built cars etc. out of old bones. Thats all.
  8. Lucky77
    Lucky77
    Okay, thanks a ton fellas. I had to sleep, go to school, then go to work today so I couldn't do anything DMV related. Tomorrow I'll try it again, I have a new plan of attack and I'll let you know how it turns out. Again, thanks for all the advice.
  9. onemintcaddy
    onemintcaddy
    In Minnesota you take 4 photos of the car from the front, Side, Ect. and bring in anything you have on the car,If you don't, Wright what #'s you can get from the car doun and bring that in. Tell them it's ben sitting in your yard for over 6 years or so and you need to tab it.
    I was trying to file for lost ***le and the lady told me that's to mutch work,,, Do it this way. :eek:
  10. sheepdog
    sheepdog
    I have had it several times.
    It depends a lot on the state you are in but I know in California they run Vin numbers all the time at the DMV (I had to show them where it was on my p/u) and more often by the CHP. More than just those agencies will run them as well. Tow yards do it to make sure the car they towed is the actual car they towed. Smog test centers verify vin and I am pretty sure engine block numbers as well. And yes I realize many of those do not apply to us.
    A piece of paper is exactly that, a piece of paper. They verify to make sure you are not doing exactly what is being described in this thread. Granted these are newer vehicles than what is being described here, but it does show they check.
    I would imagine in most states no vin will almost surely cause serious headaches as well as impounding of the vehicle until it is sorted.
  11. buckeye_01
    buckeye_01
    I ran into the same problem with a 66 Plymouth I bought. It came with a ***le, but the vin plate was missing. I bought a little chunk of stainless, cut it, cleaned it, stamped it, and stuck it back on. I had an Ohio out of state inspection performed, and had no problems at all. As mentioned before, have all your ducks in a row and make sure you tell everyone the same thing. Good luck.
  12. Just ran across this here on HAMB. This may help so of you!:confused:
    Selling: Misc.
    Price: $100 each shipped​
    way too many too list so i will just list some of them.
    ALL ***LES ARE CLEAR INDIANA ***LES
    please do not reply to this thread
    pm or e-mail only monza@mw.net
    CHEVY CARS
    37chevy cpe, 39 chevy 2dr, 39 chevy sed,41 chevy sed, 47 chevy 2dr sed, 48 fleet coupe, 48 chevy sed, 48 chevy 2dr,
    48 chevy convertible, 49 chevy clbcpe, 50 chevy 4drsd, 51 chevy 2drsdx2, 53 chevy 4drsd 210, 53 chevy 4dr, 54 chevy 2dr, 55 chevy 4w, 56 chevy 2s, 56 chevy 4s, 56 chevy 2drsd, 57 chevy 4drsd, 59 chevy 4s,
    CHEVY TRUCK
    40 chevy trk, 41 chevy trk x3, 45 chevy trk, 49 chevy trk, 50 chevy panel trk
    GMC TRUCK i have 2 1947 gmc trk ***les, 53 & 54 gmc tractor ***le
    DODGE TRUCK
    46, 47 x2 , and a 48 dodge trk ***les, 58 dodge tractor
    DIVCO 1945 & 1948 divco trk
    FORD TRUCK 59 ford truck
    FORD /MERCURY/LINCOLN CAR
    52 ford 2dr(MISSOURI ***LE), 53 ford 2s, 54 lincoln 4dr, 56 ford 2s 57 ford 4w, 58 ford 300 2dr, 58 merc 4s, 60 ford 2s
    PONTIAC
    37 sedan, 41 sed, 46 sdcp?, 50 4drsd, 51 2s, 51 coupe, 51 4drsd, 52 2drcp,52 coupe, 52 2drsd, 53 2s, 53 2drsd, 54 2drsd, 54 2dr, 55 coupe, 55 convertible, 55 4s, 56 sedan, 57 4drsd, 57 sd, 60 2s
    BUSY BEE 1946 homemade scooter???
    DESOTO toomany to list
    PACKARD too many to list
    DODGE , CHRYSLER, PLYMOUTH too many to list. tons of these
    <!-- / message --><!-- sig -->__________________
    51 chevy truck--
    <!-- / sig --><!-- edit note -->
  13. Tall Tom
    Tall Tom
    from Austin MN
    I've been waiting to respond to this and Today I got my ***le in the mail for my 26 T coupe.
    What I did was to tell the whole truth to the Minnesota DMV local office. They have a form you fill out, you put down everything you know about the car, take four pictures and have a bill of sale. I also told them the serial number on the Stock 26 frame. I explained that in 26 the car came with a frame number and the same number stamped on the block. The engine that came with it was a 24 so I asked them to look up the frame number to see if someone else was using it. No one was and that was all there was to it. I paid the sales tax and all the other fees, and am getting personalized collector plates "MY 26 T", it cost me $253.00.
    Tom
  14. The easiest way for you might be to call your DOT office and ask them what you need.
    I just did a couple here in ND. I will admit that our state is fairly easy going when it comes to ***leing vehicles.
    The local Highway patrolman stops by to ck out the cars and does the paperwork that I hand in to the DOT office.
    One car has the ser.# and I have a bill-of-sale (BOS is very helpful), go to DOT off., done deal.
    One car has ser.#, NO bill of sale or ***le, So this car has been in our family for ever :rolleyes: -and we lost the ***le !??, ((that also means we didn't buy it so there is NO tax to pay !! :D)) go to DOT off., done deal.
    Car has no ser.#, bill of sale, ***le, nothing !! Hwy Patrolman fill out app. with all the correct info, yr.-make-model, etc. Go to DOT off. and they issue a VIN # that you apply to car. Done deal.
    If a ***le isn't availabel, a bill-of-sale can save you a ton of headaches, get one.
    GOOD LUCK :)
  15. No one can tell you what to do. But if you think about it a minute you can probably figure something out.
  16. 1929 hotrod
    1929 hotrod
  17. 1929 hotrod
    1929 hotrod
    I have a 1929 Model A and there is a vin number on the left front frame. It is on the top under the hood hold down body skirt just in front of the firewall. I've worked on so many old cars. Chevy vin number is the engine number.
  18. 1929 hotrod
    1929 hotrod
    I have a 1929 Ford Model A it is a Tudor Sedan. The VIN is on the left front under the hood hold body tin. I've worked on a few of these cars and the VIN number is on the top left of the frame in front of the firewall. If you are working on a Chevy the VIN is the engine number for many years. The laws changed so in I think it was in the 40's it was required to be on the frame of all vehicles.
