safty first
Discussion in 'The Hokey Ass Message Board' started by skratch, Jun 30, 2007.
  1. skratch
    skratch
    tuesday i set down to cut an INCH of metal.
    and bam the 4 an 1/2 inch cut off wheel exploded..
    if you know anything about my work and being safe.i always wear a welding jacket,welding gloves and a full face mask.
    tuesday ,i had everything else on except for the facemask.i opt for the gl***es..now,i'm pretty vain... so when i'm holding my face full of blood and pieces of a cut off wheel..i was really freaking out..it didn't hurt as bad as getting my hands tattooed..so i wasn't that worried,but,have a hole in my face ..... was really tripping me out..
    a hole all the way through into my mouth..and a 3 inch cut under my lip is not that cool...
    4 s***ches in my mouth and 13 on my face.........sounds cool.but,it's not.
    buckle up kids.and wear those masks..
    learn from uncle skratchy
  2. damn that suxs, those things are dangerous i've had several explode on me. I always leave the gaurd on my grinder. hope all heals well
  3. VonXulu
    VonXulu
    from Ventura Ca
    Damn dude, That ****s. Remember when I was "Helping-out" on my truck and you yelled at me to put on some safety gl***es! Where did you go, Holy Cross or Saint Joe's.
  4. Gas Huffer
    Gas Huffer
    I always use gl***es, but seeing that makes you think twice about full on coverage. Thanks for the words of advice and good luck on you recovery.
  5. 49ratfink
    49ratfink
    that's messed up. what caused it to explode?
    I have this thing about not being "in line" with any spinning object if at all possible. like when you are cutting and you are looking at the wheel and all you see is the edge. my thinking is if something flys off it is going straight out . would that have made a difference in this case or am I just fooling myself.
    always wear gl***es..never a face shield. mebbe I'll head over to OSH tomorrow and get one
  6. skratch
    skratch
    it seems like 1 out of 100 do explode.i have had them come apart soon as you turn on the grinder.it have gotten damaged in the drawer or on the shelf..who knows..
    i was not look directly at the blade.i actually had it a little above me..
    STUPID!
  7. Chris P
    Chris P
    from Tucson
    I always find my self using the cut off. And every time I think what if this wheel come off and goes in to my chest. It scares me but not bad enough to do any thing. Now I think I'm going to take a couple more precautions, like my leather welding jacket, full face mask and gloves. I hade a chopp saw blade explode on me once I had to change my pants after that one. Hope it heals up ok.
    -Chris
  8. JohnJoyo
    JohnJoyo
    Alliance Vendor
    from Austin, TX
    DAMN SKRATCH! glad you're ok, could have been a lot worse. Not to make light of the situation, but chicks dig scars...I learned tonight that's true :)
    BTW, did you take the guard off your cut off?
  9. Muttley
    Muttley
    Yes it ****s but you are very lucky it didnt end up a few inches lower or higher.
  10. skratch
    skratch
    i'm so lucky...
    and yes.i'm a dumb ***.no gaurd.
  11. Yes, the guard. People have a habit of removing them.
    On the plus side you have a second mouth. Glad you are not dead or worse.
  12. Nocturnal
    Nocturnal
    from CO
    Thanks for the "Safety Check"...I usually get one after a visit to the junk yard, but am long over due for one dealing with the "SHOP"....
    Hope for a quick recovery.
  13. gasser52
    gasser52
    an inch? what were you cutting?
  14. Zerk
    Zerk
    Glad it wasn't worse, and thanks for the visual...it made me think twice.
  15. STIFF
    STIFF
    from Rat Town
    God damn you Skratch! Even your scars are cool!!
    Hope you heal up good, safety matters kids!!
  16. roosters hot rods
    roosters hot rods
    tattoo's are so much better than scar's....that looks painful hope your ok dude.....grow the goat in thick........rooster
  17. Flatman
    Flatman
    I can sympathize, I had a 4" biscuit wheel explode and carve a 1/4"
    groove into my shin. It took a long time to dig out the fragments.
    Flatman
  18. Shifty Shifterton
    Shifty Shifterton
    Stop holding the workpiece in your teeth!
    seriously, glad you're ok.
  19. buzzard
    buzzard
    Alliance Member
    Man, I bet that was a bunch of blood. Glad you're relatively okay.
  20. budd
    budd
    thats a nasty cut, hope it heals up without any nerve damage, i took the gard off my grinder when i got my finger stuck between the gard and the cut off wheel and it cut the nerves to 1/2 the end of my finger, i have never had a disk explode but have watched them explode on others, usely it happens right after they drop it and pick it back up and turn it on without looking, if i drop my grinder i always check the wheel to make sure it hasent broken, if it cracked i take it off, safety is somthing you have to look after yourself, know what the dangers are, i worked in a place that had a row of punch presses, the largest one being 100 ton and guys would stick the arms in the open dies right up to there sholders with the machine running to change the parts they were stamping, i may as well stuck my thumb up my *** as to try and tell them that wasn`t safe.
  21. Think about it...setting a wheel that deep into unforgiving material is asking for trouble. Would you try to freehand (as in no guide fence) something through a table saw? Just a little binding from moving off axis and its gonna grab hard or blow.
    Don't get me wrong I'm glad it wasn't worse (could have severed major vessels in your neck, bro!) but lets all think things through. This is a great hobby but frought with danger if we get too comfy.
  22. bobbleed
    bobbleed
    from Awesome
    ****.....scary stuff man.
  23. JamesG
    JamesG
    Great post, I hope everyone reads this.
    BE CAREFUL PEOPLE!
    At least you got a cool scar out of it.
    And, glad to know your ok.
  24. COOP666
    COOP666
    from Austin TX
    Wow, Skratch, I didn't think you could get any uglier...
    As my wife is fond of saying: Chicks dig scars!
  25. skratch
    skratch
    i needed to cut just little bit of a door jam.
    and it seems to be healing fine..i can take out the s***ches monday...
  26. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Thanks for posting this Skratch, this made me realize how much I have let safety slip myself since I have been working in someone else's garage and not my own...................it will be a full face shield for me from now on......I wish you a speedy recovery, Littleman
  27. Aman
    Aman
    from Texas
    You may want to reconsider cutting the 1" stuff with a cut off wheel. I always thought they were for the thinner stuff. I use the full face shield but never use the disk shield so, I guess I'll be putting them back on now! Like was said before, guess you're lucky it hit were it did and not 2" higher or lower. It could have cut your throat or hit your eyes. Dat gives me da willys!!
  28. 23 bucket-t
    23 bucket-t
    At least your scar goes good with your tattoo.......... :cool:
  29. HemiRambler
    HemiRambler
    Full face shields are a good thing, but they have there dangers as well. A friend of mine was grinding beams on the job when he felt something hit his eye. BTW he WAS WEARING a full face shield. He wasn't in any serious pain or anything, but he said it felt like he had dirt or something in his eye. No matter what he did he couldn't seem to rinse it out. The boss tells him to get back to work - my buddy says "Fu-# that, I'm going to the hospital" They looked him over and told him he LITERALLY SPLIT his eyeball in HALF. It looked fine but apparently the impact "fractured" it. He was blind for a fairly long time and eventually he got SOME vision back - not all.
    Never ever really did find out what happened. All's we could determine was that a "chip" must have bounced off the INSIDE of his full face shield. Ever since that happened to him when I wear a full face shield I STILL wear a pair of safety gl***es underneath. And while I may look ridiculous - I feel pretty safe.
    Skratch - thanks for sharing - who knows how many can benefit from your posting this. Hope you heal quickly.
  30. DE SOTO
    DE SOTO
    WELL IF YA STOP BUYING THE 20 PACK AT THE 99cent STORE, THEY WOULD'NT EXPLODE SO OFTEN !!!! :D
    Seriously though, Glad yer O.K. and it wase'nt more life threat'nin
