Airbags...
Discussion in 'The Hokey Ass Message Board' started by unpunk01, Apr 15, 2004.
  1. unpunk01
    unpunk01
    Looking for some help with air bags. I just bought a 1950 Ford and I want to bag it. I'm not going to be doing three wheel turns, bouncing it or any of that minitruck ****...I just want bags.
    Can someone point me in the right direction on good components and/or kits? Do I need two compressors? The box with all of the switches?
    I'm a FNG...I need all the help I can get! Thanks!
  2. OGNC
    OGNC
    I would help you, but all I know how to do is "that mini-truck ****"...
  3. JSM56
    JSM56
    you'll probally just want two switches, a front and a back. don't really need a switch box for 2 switches. could even do manual valves. youll probally want 2 compressors and at least seven gallons of air tank. dont run half inch line and valves, because it WILL be too fast. either mono leaf it with a panhard in back, or four bar it. depending on how low you want to go, you might want to notch the frame in the rear. in front on a shoebox, you can flip the shackles for an easy couple of inches drop.
  4. unpunk01
    unpunk01
    JSM...thanks for the info!!! You know where I should get the parts to do it?
    PS - Is the Pink Poodle still open?
  5. unpunk01
    unpunk01
    Wait...Pink Poodle was in SJ...how about River City Brewery?
  6. nor cal nic
    nor cal nic
    check out this site... www.airride.com and in my '50 i'm runnin' one tank... it does the job just fine. good luck.
    nic
    ps
    i love NADS...
  7. Cranium
    Cranium
    Unfortunately the Pink Poodle is still open.
    Yeccch...
  8. Whiz
    Whiz
    [ QUOTE ]
    [/ QUOTE ]
    bwhahahahaha
  9. Radshit
    Radshit
    I used to have a mini-truck...back in the eighties...
    But I have, for a short while longer, anyway......a '50 F-1, and it has bags on all four corners.......I have one compressor and two switches....a switch for the front pair and a switch for the rear pair...... Recently, I installed an adjustable 400 psi pressure switch...it keeps the tank at about 200 psi.....
    The 3/8th inch airlines are all I need for a fairly quick lift...not too fast....at least nothing John Law is going to notice at an intersection.....
  10. unpunk01
    unpunk01
    Last time I was at the Poodle, some guy stabbed the bouncer and the bouncer...I swear to god...looked at his stomach, wiped some blood off and then kicked the **** out of the guy who stabbed him. In fact the bouncer bit the guys ear off! But then again...some of the dancers could have done the same thing!
  11. unpunk01
    unpunk01
    Thanks for all the great info, guys!
    Is there a certain brand out there that is better? I was told that they are making a bunch of cheap **** kits and to watch out for that...unfortunately, I don't know my *** form a whole in the ground when it comes to airbag systems!
  12. CharlieLed
    CharlieLed
    [ QUOTE ]
    [/ QUOTE ]
    LMAO.... [​IMG]
    Say Court, aren't you baggin' that RPU?
  13. autocol
    autocol
    kustombuilder, mike brimm, is an airbag distributor, installer, and most importantly, HAMBER.
    pm him. he can hook you up.
  14. unpunk01
    unpunk01
    Thanks for the info! I'll drop him a pm.
  15. unpunk01
    unpunk01
    more help?....anyone?
  16. OGNC
    OGNC
    Okay, I'll help. But it is against my better judgement.
    Brackets: www.suicidedoors.com they're cheap and made from the same steel as everybody elses (hope you don't mind writing a check to a mini-trucker).
    Bags, compressors, shocks, fittings, vlaves and airline: www.deviouscustoms.com Good prices, great service.
    other sources: www.mastreimagecustoms.com Same parts as the rest, really good prices.
    Good luck with your S-10.... er, um I mean ShoeBox.
  17. Dirk35
    Dirk35
    Does Elpolacko here distribute a air bag systems?
    Ib buy from him with out a thought. Steve is good guy.
  18. [ QUOTE ]
    [/ QUOTE ]
    Hey OGNC - do you have any info on those MIC airbags?? Are they any good?? or reliable?? Just thought I would look around before I buy a whole set..
  19. SpeedRacer2002
    SpeedRacer2002
    hey man i can get you a whole kit 4 bags brackets hoses manual valves compressor tank fittings 1/4" lines and valves is 980.00 and the 3/8 kit is 1200.00
  20. RF
    RF
    Um, yeah, uh, MIC is "out of business". I don't think you'll have any luck there. And take mini-truckers' advise when it comes to bags...they may be jotos, but they know bags.
  21. thanks RF..
    Speederacer - I sent ya a PM....
  22. junk runner jr
    junk runner jr
    [they may be jotos, but they know bags.
    [/ QUOTE ]
    um yea... thanks I think...
  23. lowburban
    lowburban
    There is a shop in Florida called R.A.W. that does good work. I do lots of air suspensions as well as Body drops etc.. and there are certain brands that are much better than others. The best valves are GC, but Herions or Parkers are good valves as well. If M.I.C. is out of business their is no one else that makes good manuel valves.
    1/4 inch line is a waste of time, it will be painfully slow. 3/8 is the way to go, not to fast but not slow as christmas. If you run monoleaf in the back you do not need a panhard bar, the springs will do that job. I use only Firestone or Slam specialties bags. Con***ech are supposed to be good as well but I've never used them. Any bag with the metal band around the top will give you trouble eventually. All the stuff I've seen from suicidedoors has been good. Also if you run compressors it is really worth it to shell out the extra cash for the big 100% duty Firestone compressor. We won' even install the 317's anymore because we have to much troube with the reed valves in them going out. I've had the big Firestone in my suburban for over 4 years and it has never had any probs.
    Good places to get parts www.ifcustoms.com or www.ekstensive.com. Bill at Ekstensive Metalworks is a genious and has done many old rides. Avoid Aim industries at all costs, it's almost all trash. Alot of people have had trouble with stuff from FBI.com as well.
    Hope this helps. Feel free to pm me or email me at cfore@bryanisd.org.
  24. OGNC
    OGNC
    I might be a Joto, but I am not the one who noticed Cameron's **** Knob... On a lighter note, Master Image is still in business. They just moved to Laguna. They were actually bought out by a HUGE air ride distributor and now their prices are even lower and they have a ton of stuff in stock.
  25. RF
    RF
    You sure 'bout that? Check your link again...
    And the knob was definitely meant for you.
  26. SpeedRacer2002
    SpeedRacer2002
    MIC isnt out of business they just got bought out by another company and they kept the MIC name and the service is much much better...
  27. Satinblack
    Satinblack
    Bags? "We don't need no stinking bags!" [​IMG]
  28. RF
    RF
    I knew they got bought out...I was on the owner's list of "who to call today and tell them I'm now a millionaire and retiring" the day the papers were signed. I hadn't heard of what transpired with the new corp. owners, so I apologizes for spreading any false news. Regardless, Minitruckers are still jotos, but they know bags!
  29. Ok, I am a FNG when it comes to bags as well. But my ?? is why do some comp. sell their kits with shocks and other dont?? How would I determine the size of shock needed once I install the bags. Would it be the same as I have now?, I dont think so..any advice is appriciated. I probably should have asked you speedracer, but I felt like I already asked you a bunch of dumb*** ??'s...
  30. Fry
    Fry
    from SK, Canada
    No kits come with shocks, usually just bags, valves, line, sometimes fittings, sometimes compressors and tanks. Brackets, shocks, and model specific stuff are not included.
    For shocks just install your bags and set the ride hieght you want with your bag brakets then measure the distance from fully colapsed to fully extended and get a shock that allows the full travel. If your bagging to go lower you probably want to relocate your shocks to they don't bottom out like the stock location probably will.
    As mentioned before Jason @ www.suicidedoors.com has cheap, good quality parts such as bags, brackets, valves, shock relocators, etc.
    http://www.bagginit.com/tech.html has diagrams on wiring and basic bag knowledge, seems to help some new people to bags.
    4 valves in my opinion handles like **** due to air transfer, I'd get 8 valves personally.
    Stay away from anything from AIM.
    What do I know, I'm just a minitrucker [​IMG]
