question for the buick guys
Discussion in 'The Hokey Ass Message Board' started by Tin Can, Jul 5, 2007.
  1. Tin Can
    Tin Can
    I have a 53 buick special and am in need of some rear brake shoes. I cannot find anywhere that carries them. Napa, autozone, Lee auto, nowhere. I got a pair from Napa that looked like they would work, but not go. literally. So I guess my question is where can I get a set of brake shoes for the rear of my 53 special? Thanks ahead of time
  2. kaydub
    kaydub
    from Cali
  3. Tin Can
    Tin Can
    I saw them earlier, I have to send my old shoes to them so they can reline them and send them back to them. I was hopin to find somwhere I could just order a set
  4. ZZ-IRON
    ZZ-IRON
    from Minnesota
    This should get You a pair of 53 special brake shoes.
    Brake & Equip. Whse Inc. 455 Harrison St NE Mpls,MN 55413 Ph # 612-378-3141. They have wheel cylinders, master cylinders,shoes,etc. for many makes, the old stuff. I bought wheel cylinders for my 56 Hawk there. I get my Buick goodies there.
  5. Kanter doesn't have them? Google up Kanter auto parts.. I forget their URL.
  6. palosfv3
    palosfv3
    Check to see if theres a Midway Truck Parts store nearby. They reline shoes for trucks and relined shoes for me several times with just a 1 to 2 day turnaround.
  7. leadsleadolds
    leadsleadolds
    here are the sites your gonna be using often. Ive had five Buicks so far seems more often than not you'll have to order most everything. Autozone and NAPA have been pretty usless unless you have a ford or Chevy.
    cl***icbuicks.com
    oldbuickparts.com
    Im not sure if the buick farm is still up but do a search for that
    and http://www.wheatbeltbuick.com/
  8. mn_leaf_fan
    mn_leaf_fan
  9. Tin Can
    Tin Can
    mn leaf, these are for the front. The rears are only 1.75" wide on my buick. Thanks for the link though
  10. ZZ-IRON
    ZZ-IRON
    from Minnesota
    I checked Brake& Equip, 1.75 wide. Nothing on hand, He said they can re-line them $55.00 for a set. I usually have good luck with them.
  11. 8straight8
    8straight8
  12. Gr8ballsofir
    Gr8ballsofir
    Try to find a local Brake and Clutch shop. I get mine relined.
