Rear End?
Discussion in 'The Hokey Ass Message Board' started by nero, Jul 9, 2007.
  1. nero
    nero
    Want To Change The Rear End In My 36 Ford Sedan..350 With 7004 R.any Good Road Gears For This Combo? I Plan To Change Complete Unit.there Is A 86 Mazda Truck Rear In It Now 390.1
  2. 57 HEAP
    57 HEAP
    Since you have an OD transmission already, anything with a higher ratio will lower the crusing rpm. Try a 3.73:1 or 3.5:1 you will still have good acceleration for a dead stop and highway engine speeds will be low.
  3. nero
    nero
    Any Idea For A Rear Axle That Will Fit????52.5 Backing Plate To Backing Plate..
  4. A Chopped Coupe
    A Chopped Coupe
  5. 55 dude
    55 dude
    check out toyota trucks (2wd) they are narrow have ford 5 on 4.5 bolt pattern also. they are cheap and stout, they actually have larger diameter axles than a 9". i had a 75' toyota truck with 302/c-4 and tried in vain to blow up the rearend and failed.they also have dropout 3rd member similar to a ford.
  6. nero
    nero
    Whats The Ratio??
  7. Deuce Roadster
    Deuce Roadster
    Most knowledgeable Hot Rodders measure a rear end width this way ( shown above :) )
    Using the backing plate to backing plate method leaves too much room for errors. Brake drums will vary in width from 1 and 1/2 inches to 3 inches ( different models and different makes ) . That makes room for a error of 2 to 3 inches when using the backing plate method.
    ALSO ... most of the on-line rear end widths site use the wheel mounting flange method.
    IMHO ... the perfect rear end for a 35 to 40 Ford is the 57 to 59 Ford 9 inch series rear end. Gear ratios are available from 2.47 to 6.50.
    3.25
    3.50
    3.56
    3.70 _______ ALL are fairly common and easy to find ..
    The 9 inch Ford has the BEST parts supply ... available. Gaskets, bearings, seals ... along with millions of Ford donor cars :D
    Here are a few on-line site with rear end widths ... most rodders go for a rear end in the 58 inch range for a 1936 Ford ...
    http://carnut.com/specs/rear.html
    http://www.quickperformance.com/Technical%20Info/sus_measure.htm
    http://www.maliburacing.com/ford_9_inch/ford_nine_inch.htm .... way down on the page ... ;)
    http://www.mustangsandmore.com/ubb/FordRearDimensions.html
  8. SinisterCustom
    SinisterCustom
    Toyota 2wd, generally 3.73's...... these are narrower than ANY 9", just as strong as a stock 9"...cheaper (usually free) and EASY to get parts for and work on......
    Later model 'Yotas...mid 80's and up are a little wider than the earlier ones, @ 2" or so......
  9. timothale
    timothale
    I have a ford 8 inch in my A It came out of a maverick. some of the 6 's and the V 8 's came with 5 bolt wheels
  10. toadfrog
    toadfrog
    from Arkansas
    Toyota?????
    Not in My american tin.....
    Just got a rear dif from a 93 Lincoln Mark VII , 8.8" , 3.55 posi, with disc brakes. 5 on 4 1/2 wheel pattern.
    Picked the whole car up with running 5.0 HO for $300. Should make a great donor car.
