Frame ID Numbers- How Do I Decode?
Discussion in 'The Hokey Ass Message Board' started by Dooce, Jul 9, 2007.
  1. Dooce
    Dooce
    I just picked up a frame for a project of mine and need to find out the exact year, so I can buy the correct parts. Its suppose to be a 73-87 chevy 1/2t frame, and the guy thinks that it is a 76, but not 100% sure. I know that these years aren't H.A.M.B. friendly, but this is the only place I know to ask. I only have three different numbers:
    T8S517353- found this # on top frame rail, p*** side, where the cab sits.
    7S483- found this one on the p*** side frame horn, outside frame rail.
    7802644- found on gearbox, probably not much help.
    If anyone can send me to a website that has this information, that would be very helpful. I have been searching for one the past week and cannot find anything. The local Chevy dealer wasnt much help either (go figure). Thanks again, DOOCE
  2. squirrel
    I would give it a wild guess as behing a GMC truck from 1978, built in St Louis.
    at least that's what I would guess if I saw that T8S.... number sequence on an engine block.
  3. Dooce
    Dooce
    thanks squirrel, I tried decoding the same number as if it was the vin, and thats what I came out with, but the numbers are not in the same place as they would be in the vin. It shows that there should be 4 other numbers between the T and the 8.
    Is there any more numbers that I may of missed somewhere that mght be of more help?
  4. squirrel
    they used a similar "partial VIN" on engines, it gives only the carline, year, and plant, plus the 6 number serial sequence.
