junkyard bench seats. what fits a 32 Ford???
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jul 11, 2007.
  1. kustombuilder
    kustombuilder
    from Novi, MI
    so who has done it and what bench seats fit good right outa the donor car into a 32 Ford coupe??? buddy is building a 3 window and wants a junkyard seat. he's not a high dollar, fancy seat aftermarket kinda guy.
    thanks
  2. What fits a 31 roadster pretty much fits a 32 roadster.
    The coupes are pretty similar as well.
    That said, here's a reprise of a post I did a while back.
    29-31-32 Roadster ****pit Measurements
    Here’s a set of ****pit measurements for 28-29, 30-31 and 32 roadsters.
    Henceforth called, 29, 31 and 32 just to make life easy in the typing dept.
    It took a few days to get the measurements because a 29 wasn’t readily available, but yesterday my pal was home and I measured his.
    A couple of things will impinge on these measurements.
    One, we all read the tape a little different, but not too different.
    The other, the 29 is a Gennie, the 31 is a Brookville and the 32 is a Wescott.
    The Wescott 32 is recognized as being very accurate and in my case, the body dropped right over a stock specification re-pro Deuce Factory frame and the two front and two rear holes in the body lined up perfectly with the threaded bolt holes in the frame.
    (You have to drill the center body holes yourself.)
    The Brookville roadsters are right on the money from what I read and hear.
    They bolt right up to stock A frames and other factory A pieces with no problems.
    The 29 may have some differing measurements vis a vis ****pit width at the rear of the doors.
    This is because whoever owned the car in the past leaned against the drivers side quarter panel when driving and over time the quarter panel sagged out away from the body a bit.
    Easily rectified with a little cranking on a small come-along and the addition of some square tube bracing.
    The car was a running, stock Model A roadster when it fell into my pal’s hands.
    It didn’t take long to get the A running gear out from under and a TCI frame with SBC power installed.
    You’ve probably seen me comment that my 32 is a tad short on legroom, but it’s not bad.
    Sweetie and I spend the day in it now and then with no problems.
    We take breaks every hour or two depending on what we’re doing and where we’re going.
    The 31 is a long term project and right now it’s a roller with seating, pedals and steering installed.
    It looks like it’s going to be a more than comfortable car when you consider the good ergonomics of the mid-90's ChryCo Soccer Mom mini-van two p***enger - true middle - seat.
    As an aside, this particular seat can be ID’d by looking for armrests on both sides of the seat.
    A while back I got another one at a garage sale, reputed to be from a later year ChryCo mini-van and it only had an armrest on the right side.
    It’s ok in the comfort dept., but not as cushy as the older version.
    This particular seat could be useful to someone trying to get as low in the ****pit as possible since the seat bottom including frame is a bit thinner than the mid-90's seat I have in the 31.
    Along with that, this seat has a simpler base that would be easier to adapt to the 30's era - and probably earlier - thin fender cars.
    N/A (Not Available).
    The measurements:
    Length
    From back surface of the eyebrow - which is the raised piece at the back of the cowl under the windshield - to the center of the top edge of the rear ****pit rail:
    29 = N/A
    31 = 40 1/2"
    32 = 42"
    Width
    Across the ****pit at the front door gap:
    29 = 42 3/4"
    31 = 42 3/8"
    32 = 41 1/2"
    Across the ****pit at the rear door gap:
    29 = 49"
    31 = 49 3/8"
    31 = 48"
    Between the tabs that the middle arm of the top irons pivot on (just behind the rear door gap):
    29 = 49"
    31 = 51 ½"
    32 = 49 5/8"
    Width
    Taken at floor level.
    This measurement has a small bit of estimation factored in due to the tape measure being held at trans tunnel height, but it should be pretty close:
    At the front door gap:
    29 = 36"
    31 = 37"
    32 = 37"
    At the rear door gap:
    N/A due to all three cars have the seat installed.
    Depth
    Straight down, just to the right of the steering column and equal from the top of the eyebrow to the bare floor:
    29 = 28 3/4"
    31 = 28 1/2"
    32 = 30 1/4"
    (The 32 is has carpet, jute backing and a wood floor so this measurement is a bit of an estimate, but it should be close.) - (A height measurement taken in the center won’t work here due to the differing height of the trans tunnels.)
    Straight down from the lower edge of the rear ****pit rail to the floor:
    29 = N/A
    31 = 26 ½" (27 ½" to the top of the ****pit rail from the floor.)
    32 = N/A
    These figures are N/A due to the seats are installed and you can’t get behind them without dis-***embly.
    Vertical height of the door at the front door gap. Measurement taken to the sill plate - or call it the body’s frame support for the body and not the ch***is proper:
    29 = 22"
    31 = 24"
    32 = 26 3/8"
    Vertical height of the door opening at the rear gap, again, taken to the sill plate:
    29 = 22 1/2"
    31 = 24"
    32 = 25 ½"
    A small bit of the disparity between front and rear measurements on the cars is due to the very front top of the doors sweeps up a bit or a bit more depending on the which car we’re looking at.
    The rear gap measurement was taken at the opening due to the sill plate - and floor - are not accessible with the door closed and the seat installed.
    Length of the door top, measurement taken at the top of the belt line:
    29 = 22 3/8"
    31 = 24 1/8"
    32 = 26 3/8"
    Diagonal measurement taken from extreme left of toeboard/floor juncture going up the to middle of rear ****pit rail:
    29 = 56"
    31 = 58 3/4"
    32 = 60 1/2"
    Keep in mind that the cars the measurements were taken from all run 14 ½" steering wheels.
    The 31 & 32 have Grant wheels, the 29 has an aftermarket wheel that’s retained by eight machine screws to the adapter.
    Steering column length from toeboard to bottom front edge of the steering wheel:
    29 = 28 1/4"
    31 = 27 3/8"
    32 = 28"
    Both the 31 and 32 have home-built aluminum ball bearing steering columns and the 29 runs a GM tilt column of unknown vintage and origin.
    The 29 column is tilted up one notch due to the column proper is installed at a little steeper angle than the 31 and 32 non-tilt columns.
    Since the 29 column was set where it’s driven I left it as is and took the measurements.
    Distance from the back edge of the eyebrow to the front top of the steering wheel:
    29 = 4 3/4"
    31 = 4 1/2"
    32 = 4 3/4"
    Distance from bottom edge of steering wheel to floor:
    29 = 18 1/2"
    31 = 15 1/2"
    32 = 18 3/4"
    Steering column
    Taken from the front edge of the door top to the center of the column. Keep in mind all three of these roadsters are modified from stock as desired by the owner, so this measurement won’t be a whole lot of use to a stock steering column Model A roadster owner.
    29 = N/A - lost this figure somewhere along the line, but it appears close to the 31& 32.
    31 = 9 1/4"
    32 = 9"
    Center of seat back to top surface of brake pedal.
    Realize that brake pedal height as well as angle and seat back cushion thickness will create a disparity in these figures:
    29 = N/A
    31 = 39"
    32 = 39"
    Center of seat back to top surface of throttle pedal - s**** type in the 32, similar aluminum round piece in the 31.
    Throttle pedal travel is about the same in both cars:
    29 = N/A
    31 = 42"
    32 = 41"
    Center of seat back to toe board about 2" above the 45 degree juncture between toeboard and floor:
    29 = N/A
    31 = 45 1/2"
    32 = 46"
    The figures to the seat back center could be off a small amount as the seat back centers are in different places on the 31 and 32, but that was taken into account.
    Even so, the same point on each car’s seat back was used to take the three figures from both the 31 & 32.
    A small bonus measurement:
    Hoodtop centerline, measurement taken on the hood proper and not the opening:
    29 = 27 3/4"
    31 = 32 3/8" - note that this is not a stock measurement due to the 31 sits on a 32 frame and has a Rootlieb custom length hoodtop.
    32 = 32"
    (Stock hood center line length on 31's is 31 5/8".)
    All in all, an interesting little project.
    I was a little surprised to see how close the cars came in most areas.
    Especially so when comparing my pal’s 29 to my 31 & 32.
    I’m 6' tall with a 32" inseam and weigh 195#.
    He’s 5'11" with a shorter inseam and about 40# heavier than I.
    Even so, his 29 is comfortable for me to drive.
    One of the reasons could be that his seat is tipped rearward a little more than is the seat in my 31.
    My 32's seat back cushion is a little too vertical, but it works since it has good lumbar support and a raised area under the backs of the legs toward the knees.
    The 32's seats are 3/4" birch veneer plywood - chosen due to higher quality and lack of voids as compared to regular plywood.
    Price differences between the two types aren’t a whole lot nowadays, all of which makes the birch veneer plywood price a little easier to take.
    My pal complains about the lack of under knee support in my 32, but it works well for me.
    My car, my choice.
    His car his choice.
    And Sweetie thinks the 32's seat is just right so maybe that’s all that counts.
    In any event, the drivers got it made in either of these little cars.
    As a small aside, I have a 6'7" friend who put in about an hour driving my 32 roadster.
    He did ok, but when we stuck him in the seat I was wondering how it was gonna work out.
    Part of it, perhaps he was used to making do when it came to fitting into small cars, but he commented that it wasn’t bad.
    I noted that he had no problems operating the throttle or brake pedals as well as there was plenty of room for his legs under the steering wheel.
    Even so, he’d be a lot happier in the 31 if I ran the seat all the way to back - which would gain 2".
    That would be about as close to the rear ****pit rail as you’d want to go since you’d be lying against it when accellerating.
    A thinner back cushion than the ChryCo mini-van cushion could help and you may be able to gain up to 4" more backspace.
    I hope these measurements help some who are in the building stage or even in the making a choice of cars stage.
    The roadsters aren’t too difficult to set up for a big guy as long as you start thinking about it early on.
    Coupes are just about as easy and - as we know - the sedan guys got it made.
    Even when sedan seats are back a ways, the rear p***engers still have a lot of leg room.
    One place where I see a lot of conflict in these cars is, guys set the engine in - which is understandable because the engine pretty much has to go where it fits the best although you can gain some room on the drivers side by setting the engine over to the right a ways - in US cars.
    Where a lot of guys run into problems is installing the exhaust manifold or header and then try to fit the steering around it.
    Far better imo to install the steering where ergonomics dictate and then build the header around it.
    And if you’re using exhaust manifolds, most engines have other manifolds available which can get you to where you want to go.
    In any event, don’t let the engine or exhaust dictate where the steering, brake pedals et al have to go.
    It will to an extent, but the main thing is to build the car with good ergonomics and build it to fit you.
    If it’s not reasonably comfortable and fun to drive, why bother?
    And a pic of a mid 90's ChryCo Soccer Mom van two p***enger seat.
    An excellent fit.
  3. john56h
    john56h
    Look at Bronco, Blazer and Ramcharger rear seats...they are narrow and might work.
  4. Big Dan
    Big Dan
    Hey Custom......... I used the center seat from a mid 90s Mazda MPV Minivan in my 31 coupe and it fit perfect and is very functionable........... Back is adjustable back and all the way forward... If you find one in the junk yard be sure to take the adjustable rack it sit on..........only payed $20 for mine........ Big Dan
  5. Dont know if you guy have em there but i'll tell you anyway. I used a seat from one of those tiny Mazda ute's (pick up) like late 70's model, fits great, the top tapers a bit, but easy to cut and bring out. Cheap also, paid $30.
  6. kustomrodder53
    kustomrodder53
    I once saw a guy witha 31 coupe use an S-10 bench seat... He took the factory cover off of it, then sectioned it with a band saw, basically removing the center arm rest. Pulled the foam off, welded the frame back together, trimmed foam, and re-installed the cover with a single pleat in the center, having trimmed the extra material away. It looked great considering it didn't cost anything.
  7. GreenMtnBoy
    GreenMtnBoy
    I've seen alot of minivan 2nd and 3rd row seats in 32 roadsters.
    Some are a little small, but there are enough different ones I would think you could find one close.
  8. elcornus
    elcornus
  9. Rio Grande Valley Deuce
    Kustom
    Measuring and hunting for seats is time consuming. Here's a time saving tip.
    I am using a middle bench seat out of a 1995ish mazda mpv van. Removing (unbolting) the lower brackets makes it easy to fasten the seat to a one inch square tubing welded vertically to the floor. You will need to weld one vertical stud for each corner.
    You'll have to drill out the square tubing so you can run a bolt through it and the seat feat. Adjust the seat height with the length of the one inch square tubing studs.
    Take out the head rests and drop a mexican blanket - You're There
    my man!!!
    Easy to find, inexpensive, and easy installation.
    Hope this helps.
    RGV
  10. Best fit I know of is the rear seat from a 90's Honda Aerodeck. These came in black leather and had a separate, stand alone frame. They have a single squab and a split back. Adjustable for reach and rake too.
  11. fuzzface
    fuzzface
    A friend of mine used a pinto station wagon seat when he built his but that was back in the days where pintos were everywhere.
  12. TommyLeDouche
    TommyLeDouche
    I have a 36' ford pickup, width wise it should be close to the same as your 32'. I used a center seat out of a 90's caravan, but I'll bet any year mini van would work. The seat fits great and is confortable, just got to cover it and your good to go.
  13. Jimmy2bottle
    Jimmy2bottle
    hell yea mid 90's caravan.. 30 bucks at pull-a-part.. and you know you picked a winner when the condom falls out between the cracks.. but dont forget to beat the arm rests off and remove the under frame or it wont fit..
  14. I think Jimmy2bottle is kidding about beating the armrests off.
    I hope so anyway, mine came off by unzipping the upholstery and pulling one or two bolts each side.
    You'll note in the pic above that the folding armrests fit - and fold up or down - in the roadster, but they're off now.
    I found a later ChryCo Soccer Mom two p***enger middle seat at a yard sale for $10.
    Like new, it looks to be a 1999 & up.
    Not quite as cushy as the older ChryCo seats, but not bad.
    Nice part is, the base has mount tabs at all four corners.
    The mid-90's seat has the front p***enger side toward the center a bit, the rest are at the corners.
    No big deal, a 3/16" tab about 6" long will adapt it to a 1" square tubing base easily.
    One identifying factor between earlier and later ChryCo van seats is the mid-90's model has two armrests and the later ones have one on the right side.
    Blackjack - what's a "Squab" in seat parlance?
  15. Dirk35
    Dirk35
    I used the same seat Tommy used in my 35 Ford PU. Came out of a 90s Dodge. The tilt mechanism is on the p***enger side is the only down fall. Other than that, its a great fit. I also grabbed the seat belts (3 point matching color to the seat) and they were increidibly easy to install.
    My seat has no arm rests, seat belts for middle p***enger are bolted to the seat frame itself. Then I bolted the other 6 bolts using the factory bolts to nuts that I welded to brackets to the body. I bolted the floor ones through the support structure of the cab, not the frame.
    Ive been planning to do a tech post about it.
    It was stupid easy and fits well!
  16. George G
    George G
    Middle seat from a Mazda MVP Van. Late '80's. Works great. Seat back tilts and it has forward and back adjustment.
  17. Jimmy2bottle
    Jimmy2bottle
  19. Most don't even require tools to get em out. Just flip the release levers and heave-ho :D
  20. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    i used one from a ford ranger in my 5 window.
    but it has been way to long to remember how much we narrowed it.
  21. punkabilly1306
    punkabilly1306
    from ohio
    what about a back seat out of a 90' F-150...i have one that is black leather that would make a cool roadster seat
  22. greezy28
    greezy28
    I have heard of people using 84-2001 jeep cherokee rear seats. Should be very plentiful in junk yards. I have one if you want measurements PM me and I'll check it out.
  23. Donald Clifton
    Donald Clifton
    I'm using 2002 Honda accord seats.
    thanks
    Don
  24. Kan Kustom
    Kan Kustom
  25. Good that this thread has come up again since last July 2007. :confused: The OP has probably worn his seat out by now :D and newbies may come up with new original :rolleyes: ideas. Anyhow, welcome to Don the newbie.
  26. Early 90's Mopar mini-van two p***enger - true middle - seat...That's what's in the car in my Avatar. Was just about a bolt-in...
  27. HOTRODPRIMER
    HOTRODPRIMER
    Leave it to a newbie and his first post to raise a 10 year old thread, HRP
    Donald Clifton
    Last Activity:
    Today at 7:16 AM
    Tuesday
    1
