Thinking about buying this for another project ...
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Jul 14, 2007.
  1. Chopperman
    Chopperman
    What do you guys think ?
  2. squirrel
    59 buick boat! neat looking, I hope you have a use for it....
  3. Smith79
    Smith79
    then buy my car to pull it
    could of had a boat like this about 8 yrs ago for 75 bux, wish i wouldn't p***ed on it
  4. Chopperman
    Chopperman
    he wants 600.00 . I'm going to offer him 250.00 for it. If I get it sweet if not, no big deal.
  5. low budget
    low budget
    from Central Ky
    59 buick was my exact thought also............................kind of looks like a old thunderbird from the front though?
  6. Mistersponge
    Mistersponge
    Sweet *** boat.
  7. rick55fla
    rick55fla
    from Cen Fla
    I read an article about a guy down here in Fla. that restores old boats,,his next project is one of those. He says they are very rare,,if you can get it for $600.00 you need to grab it.
  8. InPrimer
    InPrimer
    I would put '61 Comet tail lights on it and when you are towing it to the water, it would sure confuse the guy behind you.....
  9. NostalgiaT
    NostalgiaT
    cool boat love those old 50's style of boats good luck in getting it
  10. chitbox dodge
    chitbox dodge
    from dunlap tn
    im not really a "boat guy" but i like that one. what is it? what kind of drive set up would you normally put on it too? id go as high as the guy would want for it myself. youre not losing much really and could most likely sell it for at least what you have in it on here perhaps.
  11. junkyardjeff
    junkyardjeff
    There used to be one that looks similar sitting in a garage without a door in a alley somewhere in town,I wish I could remember where it was at as I would like to try to buy it. Jeff
  12. Brewton
    Brewton
    Give Cl***icfins here on the HAMB a shout, he restores these old boats. He might be able to give you some insight about this boat.
  13. Tore
    Tore
    Look for cracs in the keel its a very weak point on old glas boats
    Wery cool by the way !
  14. junkmonger
    junkmonger
    I like the old wooden boats, but that thing is pretty cool too. If you find out what it is, post it on this thread. I'm curious who makes it.
  15. rustrustler
    rustrustler
    A boat is a hole in the water surrounded by fibergl*** into which one pours money.
  16. publicenemy1925
    publicenemy1925
    from OKC, OK
    Totally *****in boat.
  17. mcload
    mcload
    Couldn't agree more. Better get some prices on outboard motors as well. If I did a boat, it would be an old wooden CrisCraft runabout with inboard engine. This thing could end up just as worthless after you've finished, so don't do it for "investment" purposes, do it because you want to own and drive it. Remember, you're taking on someone else's headache!!
  18. Maricopa
    Maricopa
    Didn't I last see a couple guys in tights and capes driving that thing?
  19. damnfingers
    damnfingers
    Another vote for this comment. Unless you need it :rolleyes:, skip it.
  20. davey
    davey
    they used wood under the fibergl*** for stregth in the transom and for stringers in the bottom check for soft spots .if there are any you got a tough repair.
  21. Jethro
    Jethro
    It's the Bat Boat!....
  22. mcload
    mcload
    Batman should tell that fairy Robin to go forward and release the bow line...then maybe they could get somewhere. Holy Batfart!
  23. Harms Way
    Harms Way
    You beat me to it,....... without question, the easyest way to loose money without even trying.
  24. Aaron51chevy
    Aaron51chevy
    Cool boat, I like how far back the windshield is set. Check the transom (where the motor goes) for flexing, look in where the drain plug goes and see if it's solid or mushy. Stand in the boat make sure the floor doesn't flex too much. Old boats are cool, but can be alot of work to be sea worthy. The outboard will probably be 2-3x the cost of the boat for vintage, and alot more for new.
    check out www.fibergl***ics.com its the HAMB for old gl*** boats
    Here is mine!
  25. zimm
    zimm
    from iowa
    ya thiking somthing like this?
  26. Aman
    Aman
    from Texas
    That's a cool looking hull. Looks like the transom has been regl***ed so find out how it was repaired. Some guys will gl*** over bad wood. If he has already replaced the wood and then gl***ed it you should be good to go. Don't think that building this boat is going to be cheap. Boats are expensive and require contant maintinance. You'll have to store it inside too if you want to keep the finish looking good. Good luck, looks like it would be alot of fun at the lake and would diffinently draw a crowd at the boat ramp. Oh, don't use the old cable/pulley system, get a no feedback steering cable for safety. Over and out.
