62 Falcon Gasser
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by 62 Falcon Gasser, Jul 16, 2007.
  1. 62 Falcon Gasser
    62 Falcon Gasser
    My user name says it all! I have a totally stripped of running gear 62 falcon I picked up for $300. I want to put in a 383 Chevy with iron heads, and a tunnel ram, mated to a muncie 4 speed and a ford 9 inch. I have looked at other similiar falcons, they all seem to have the straight axle I want and the rear wheel wells and quarter panels cut. Any suggestions from anyone on doing this project. I want to do this cheaply, i.e. building the motor myself and fabing my own front straight axle. Thanks for the help and I am looking forward to sharing my build with the forum!:D
  2. Dave L
    Dave L
    from Idaho
    Welcome aboard, lets see some pics!
  3. 62 Falcon Gasser
    62 Falcon Gasser
    How do I post pics?
  4. Gasserman
    Gasserman
    from Tulsa OK
    It`s great to have another Falcon g***er here. I`m using a Speedway axle in mine and a `69 Mustang 9" .It bolted right in the stock location. Welcome from Tulsa. G***erman
  5. Doll Face Striper
    Doll Face Striper
    from Lombard,IL
    hi there 62....
    good way to post pics would be to get an account on photobucket.com
    use the html addresss and when you come on here to post pics, just click on the little icon box that has the little mountain and sun thing next to the insert link icon with the earth on it....
    hope that helped..
    cant wait to see some pics!
  6. 62 Falcon Gasser
    62 Falcon Gasser
    So find a Mustang axle you say??? What years will work? Any problems with durability? What do you run for a posi? Spool, locker, limited?
    I need advice on where to start with this car. It currently has no rear axle, needs foot wells and floor pans, and I want to paint it white. Would you do the floors first, or the rear axle or the front straight axle for that matter? I want to get my duck in a row so I don't make any costly mistakes.
    What do you suggest for cutting the opening for the tires on the rear quarter panels?
  7. Gasserman
    Gasserman
    from Tulsa OK
    I just used a `69 Mustang 9" housing which fit right on the stock rear leaf spring mounts. I`m building a front frame for the car. The front unibody is not in the best of shape , so I`m using 2"x3" .120 wall tubing to build it . Going to go all the way to the rear unibody and tie it in. On the rear I just used the housing and used all Strange engineering axles, gears, case and spool in it.It pretty much a strip only car ,but I plan some street time too. G***erman
  8. pikesan99
    pikesan99
    you came to the right place to find g***ers and even falcon g***ers... I'd like to see some pics too..
    Pike
  9. Notorious
    Notorious
    The Mustang 9" you want was used from '67 to '70, mostly in big block cars, although a few others had it such as a Boss 302. Also, '57 and '58 Fords (and maybe the '59?) used a 9" that is actually one inch narrower than the Mustang housing.
    One very inexpensive option for a front straight axle would be one from the earliest Ford Econoline vans. They use twin leaf springs and look very "g***er-ish." (Is that a word? It is now!) You'll want to do something to beef up the anemic unibody under that old Falcon though. That Falcon will look balls-out if you do all of this. I'd love to see the final result.
  10. Gasserman
    Gasserman
    from Tulsa OK
    The 9" I got out of a `69 Mustang was a 302 car. Also the Econoline axle is a lot too wide. I run a `63 Falcon with a straight axle in the early 70`s on stock unibody with out any problems. But each to his own ideas. G***erman
  11. Notorious
    Notorious
    What kind of power were you making? Are you going to tell me that you didn't have at least a six-point, subframe connectors etc? To each their own indeed. The Falcons, early Fairlanes, Mustangs and such were about as ****py a unibody as was ever made. Putting any kind of power to one without addressing ch***is rigidity is paramount to a deathwish. Extensive work was done to the Thunderbolts and they were still a major handful to drive under the best of conditions. No one in their right mind today would race one seriously w/o some serious modernization.
  12. Falcon Gasser
    Falcon Gasser
    Sounds like its going to be a great set up. For my rear wheel well openings I used 1980 Chevy Impala/Caprice front fender lips and welded them in. I fund a Econoline front axle and used it drum to drum. Love to see some pictures of your car.
    Jon
  13. chromedaddyo
    chromedaddyo
    from Ohio
    Welcome to the board.
    Nothin wrong with the Econoline but, Speedway has the whole front axle kit with spindles and disc brakes for $499!!!!!!! NICE NEW PARTS
    If you can find a small bronco or a 65 and up Econo, that is a perfect 9 inch for the Falcon. I think it is a couple inches shorter than the Mustang.
    Good luck on your project. I am looking to do an early Ranchero as soon as the Cougar is done.
    Now about this Chevy engine in the Ford,,,,,,,,,, that just may be a felony in Texas.
    Dave
  14. pikesan99
    pikesan99
    Falcon G***er, I'm digging it! I can't get enough of those!
  15. Falcon Gasser
    Falcon Gasser
    I used a small Bronco rear end in the Falcon and its narrower than the Mustang and the one I found evan had a factory nodular center section. Its been in there for 8 years and no problem yet. I run a 4.56 gear and a full aluminum spool. I would have agree with Chromedaddyo about the Chevy in a Ford thing, but run what you have and just have fun.
    Jon
