What is the COOLEST Looking V8 you would have in your HotRod
Discussion in 'The Hokey Ass Message Board' started by AHotRod, May 27, 2004.
  1. Lucky Strike
    Lucky Strike
    Maybe it's just those crazy cool carbs but I like this one:
  2. I' like all the 49 to 59 Amercian v-8's. But my MEL is my favorite.
  3. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
  4. Jorge Hernandez
    Jorge Hernandez
    The nicest looking engine is the V-8 Ford Flathead.
  5. AHotRod
    AHotRod
    Your Coupe is awesume!
  6. 55chieftain
    55chieftain
    If I was building an older hotrod than what I have (mine are a 41 and 55) I would be using an 30-32 Oakland/Pontiac v-8. The intake and exhaust manifolds are on top of the engine and the exhaust goes thru the inside of the block and comes out on the drivers side.
  7. patgizz
    patgizz
    from cleveland
    dual quad 348/409.
  8. Tudor
    Tudor
    from GA
    here is my coolest v8
  9. DUB
    DUB
    Caterpillar 3508, thank you for asking, I had one of these in a 777, real work horse
    By DieselBiker
  10. Mercmad
    Mercmad
    from Brisvegas
    Full or semi dressed flatties will always be KQQL !
  11. GeeRam
    GeeRam
  12. kustomkat
    kustomkat
    Any sort of Y-block, Ford or Lincoln.
  13. wicked willys
    wicked willys
    from ne ohio
    My favorite without a doubt is the 348/409. I have just always loved there look and sound. Nailheads and ardun flatties are cool too.
  14. ynottayblock
    ynottayblock
    mine would be a factory supercharged 312 thunderbird y-block
  15. CRH
    CRH
    from Utah
    Pontiac tri power engines look cool. Paint it the factory baby blue, too. And the good old flathead sure looks right at home in an early rod.
  16. How about a Rocket with Chevrolet script valve covers?
  17. GOSFAST
    GOSFAST
    Building just about all the above mentioned units they all have their own "very distinctive" appearance AND it comes down to the customer's own preference.
    I've most recently delivered a couple "dual-quad" 409's, a couple of the early 392 Hemi's, dual carbed and a "blown", I have a "Flathead"
    or two here at all times, and one of the best one's I got involved with most recently is up in M***achusetts running around the streets on pump-gas in a '51 Willy's "old-school".
    The photo below shows the "Nailhead" finished and just before it made some 11.7/11.8 p***es up in "New England Dragway" as I said, on "pump-gas"!!! A real "eye-catcher" for sure!
    When choosing a unit (engine) for a particular "ride" you should try to keep the entire project as close to "period-correct" to the type of vehicle as possible, within reason of course.
    For "all-out" street-rod style builds where the engine is very visible, it pays to "do your homework" most thoroughly.
    Thanks, Gary in N.Y.
    P.S. Just about all my customers' with these type cars want to be able to use "pump-gas" from nozzles, they try to avoid builds requiring "special" fuels!!
  18. Mercmad....I recognize that mill, Norris Wrights ' roadster. I took this pic when I was about 12.
  19. Abomination
    Abomination
    Not sure if this 318 Poly has come up before...
    ~Jason
  20. 4 port Riley
    4 port Riley
    A Novi, four cam Ford Indy engine, 4.5 litre Maserati, Cosworth F-1, Ardun, 392 Chysler, 289 Small block Ford with 4 Webers. Really nothing special!
  21. edgeabilly
    edgeabilly
    My 331 Hemi.:D
  22. skratch
    skratch
  23. tfeverfred
    tfeverfred
    It would be WAY too much power for it, but I'd love to have a Hemi in my T Bucket. If anything, just for the look of it.
  24. usedall9
    usedall9
    Now I know why you liked the color of the seat belts in the f100...
  25. GearHeadSoul
    GearHeadSoul
    Here ya go...
  26. R1A9N8D0Y
    R1A9N8D0Y
    My vote would be either a 409 or a 318 Poly with the sawtooth valvecovers and 3x2bbls
  27. ss34coupe
    ss34coupe
    Skratch, I'm with you, there is nothing better than an early Caddy!
  28. Von Rigg Fink
    Von Rigg Fink
    from Garage
    well if i had the money..and say what you will...
    I have always wanted a full blown race 426 Mopar hemi ..about a 1968 or 69 set up..all done up , but still be streetable..(on the edge)
  29. haroldd1963
    haroldd1963
    from Peru, IL
    Here are a couple of my favorites.
    The nice one is in our 31 Roadster.
    The other is a recent addition to the spare parts dept.
