can you damage your electricals by welding?
Discussion in 'The Hokey Ass Message Board' started by autocol, Jul 31, 2007.
  1. autocol
    autocol
    hi guys,
    the bonnet release cable mount broke off the bottom of the dash in my (OT) daily. i want to weld it back on because opening the bonnet (BTW, that's the "hood" for you guys) is a major pain in the **** now...
    is there any precautions i should take on the electrical side of things? particularly as this car has a later model EFI motor in it, i'm keen to NOT blow up anything expensive! welder will be a TIG, if that makes a difference.
    cheers,
    col.
  2. nexxussian
    nexxussian
    Unhook the battery. Other than that, I would place the ground (I believe that would be "Earth" to you) clamp as close to the weld as is practical, so you minimise the chance any stray 'trons could wander where they shouldn't
  3. nexxussian
    nexxussian
    No guarantees of course, and good luck with that, not to mention the not burning your car to the ground part.
  4. SanDiegoJoe
    SanDiegoJoe
    The sparks and heat will really do a number on any carpet or upholstery that you have in the car... Any dash plastic or paint will be affected, too.
    - Joe
  5. Deuce Rails
    Deuce Rails
    Wow! What kind of spattering TIGs do they use in Australia??
  6. stickylifter
    stickylifter
    from Detroit
    I have always heard that you should disconnect the battery just in case.
  7. boozoo
    boozoo
    If I was to do it, I bet I could find a way to make it spatter. :D
    "TIG - making me feel incompetent since 1985"
  8. hotrod1940
    hotrod1940
    I suggest a drill.
    For added strength, I suggest two bolts, instead of one.
    Just kidding, a six inch bead of good old arc weld is better.
    To answer your question, yes, you can damage your electricals by welding.
    Disconnect battery ground cable bolt, remove ground cable from post. reverse procedure after welding.
  9. hooligan32
    hooligan32
    from USA
    From what I remember from my auto repair cl*** you shouldn't weld anywhere within the range of a vehicle's computer, as current can cause damage to the internals. I am only guessing that since it is your daily and has EFI that it is a newer vehicle with a computer.
  10. 59NASH
    59NASH
    I work on heavy equipment, they have 6 computers in them. When we weld we turn the master switch off, just disconnect the battery, and place the ground cable as close to the welding area as possible.
    We have had problems when we the batteries were not disconected.
  11. GTS225
    GTS225
    FWIW....I burned out an MSD in my o/t race car. Had the battery disconnected, MSD was still mounted on the dash, and I was welding in the trunk. Grounded on rear frame rail, welding sheet in to install fuel cell, using MIG welder. (Filling spare tire well.)
    With my experience, (or bad luck), I'd pull the car's computer out, and disconnect the battery, just to play it safe.
    Roger
  12. arkiehotrods
    arkiehotrods
    If someone tried to weld my electricals, well, hell yeah, it would damage them!
    Oh, I misunderstood the question.
  13. Dirty Dug
    Dirty Dug
    I have several times but turned off the battery switch, never any problems . I don't know , though, if the switch made a difference or not.
  14. a body shop i use always disconnects the battery and clamps some sort of gizzmo onto the battery cables before they do any welding on a computer equiped car to protect the electronics
    that's all i know, maybe check with a good body shop in your area?
