lowered shoebox tires
Discussion in 'The Hokey Ass Message Board' started by Odd ball, Aug 3, 2007.
  1. Odd ball
    Odd ball
    hey.. i finally got my spindles flipped and the car setting down niceley... but! i have g78-15's on it now... too big, i cant hardly turn... i think i found a good set of ford 14'' wheels, but i need to know if there is a good size white wall i can use? i may just put some small radials on it, im not sure... but i would like to know if any of you guys have a good tire reccommendation?
    thanks
    dan
  2. old beet
    old beet
    Its been 50 years, but I think I had a problem putting 14s on my 51. It also had flipped spindles and I used 57 Ford wheels. Maybe a later wheel may fit........OLDBEET
  3. ubolt
    ubolt
    from colorado
    My 51 ford sedan had 14"x6 wheels on it. The tire size was like a F78 14. The tires meausured about 26.5 high. They fit with a spindle flip and 1 cut coil. There was a little rubbing. I still have the full set so i can get you the exact tire info. They are even for sale but i'm in Colorado!
    Here they are mounted. I think this is with the flipped uprights....
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    I think that 14's on a shoebox seem a little small, but those F78's don't look bad. I plan to run 15's on my shoebox but now maybe not...
    On the other hand, I have 14's on my '63 Ford with a 7.50 x 14 tire, and they look nice on the rim. Roughly a 2" ww.
  5. Rags To Richs
    Rags To Richs
    I have flipped spindles and currently running 14 inch rims.... The Rims hit the control arm.... Stay with the 15's they clear
  6. tedster
    tedster
    Hopefully he figured it out in the last six years huh.
