How to clean an abused paint gun?
Discussion in 'The Hokey Ass Message Board' started by Chad s, Aug 12, 2007.
  1. Chad s
    Chad s
    I have a paint gun that I have had for around 3 years, that i'l admit to being awful about properly cleaning. Its a 1.8mm tip gun that I have used for spraing primers and epoxy, and I havnt always cleaned it as well as I should have each time after use, and now its just really messed up. Its a sharpe finex, so its nothing terribly expensive. I am ordering a rebuilt kit, as Im sure whatever I use to remove all of the paint buildup will ruin any seals inside.
    It still does p*** paint, and air, however the fan is very limited in width, and it takes a lot more than the 30 psi reccomended to get any paint flow, and even at around 80psi, paint flow is bad.
    My question is, what can I use to soak it in that will desolve all of the epoxy sealer and 2k primer that has built up in all of the p***ages? Urethane thinner hasnt worked, and neighter has laquer thinner.
  2. 302GMC
    302GMC
    from Idaho
    Try naptha ...
  3. Casey
    Casey
    paint stripper
  4. Carburetor cleaner? Give it a good soaking. Anyone out there hear about using this?
  5. Gerg
    Gerg
    i use paint stripper and just let all the metal parts soak for a week
    then i take a safety pin to anything else left on it s****e it off. It took me 3 tries to get my gun cleaned but it works now and it was free :)
  6. Chad s
    Chad s
    did you guys install a rebuild kit after soaking it, to replace all rubber/plastic parts?
  7. Goztrider
    Goztrider
    from Tulsa, OK
    What about using a torch tip-file to help clean up/out the flow holes?
  8. Gerg
    Gerg
    well on mine i was able to pull out all of the rubber seals and save them so i didn't replace mine. Dunno about other guns mine is a POS lol
  9. Stude-sled
    Stude-sled
    SG-14 spray gun cleaner made by Klean Strip.
  10. What, a commercial, on the market, solution to the cleaning problem.
  11. Rand Man
    Rand Man
    The pattern is messed-up on mine. It's like the top half of the fan pattern is cut off. Is that a clogged problem or an adustment problem?
  12. Take it apart if you can, soke all the parts in lacquer thinner over night or a couple of days, brush all the parts and blow them off with compressed air, especially the nozzles etc. Run straight lacquer thinner, thru the gun, repeat if you have to.
    I do this every couple of month.
    Replace the hose between the cup and the gun and the cup gasket.
    It should be as good as new.
  13. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I buy spray carb cleaner at the Dollar Store and I use it to clean my guns. After cleaning with the carb cleaner I usually flush the gun with laquer thinner. If yours is as bad as you say, it might not help but you could try.
    John
  14. banzaitoyota
    banzaitoyota
    ultrasonic sink?
  15. Jalopy Jim
    Jalopy Jim
    Soak it for a week in MEK - available at Home Depot.
    Seal the container well and wear gloves when handling. It even cleans gel coat guns.
  16. Chad s
    Chad s
    I never thaught of MEK. Thats nasty stuff, basicly the main component in plastic cement. It should eat through anything on a paint gun, Im going to try that.
  17. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Think of a spray gun as you would a carburator-
    They do much the same thing, atomize fluids. If they have air leaks
    or plugged p***age ways, they won't work well, if at all. Anytime you
    remove a packing or gasket from a gun plan on a rebuild. Ya would,t
    pull gaskets from a carburator, try to reuse them, and expect it to
    work out, would ya?
    Acetone, parts dip (the real ****), paint stripper will all work, it's a
    matter of what kind of finish has dried in the gun. Lacquer thinner is
    pretty much diluted acetone so don't waste you time with it. Do not
    use any metal tools i.e. wire, picks or torch cleaners to clean the
    p***age ways of a gun. To do so is the quickist way to turn that gun
    into a primer gun.
    S****ey Devils C.c.
  18. Chad s
    Chad s
    Im just gonna put your number on my speed dial, you always have a good answer to my questions.
    Im gonna start soaking it tonight.
  19. I've found that the only thing MEK won't cut is epoxy.
  20. rick55fla
    rick55fla
    from Cen Fla
    I'm a painting contractor and we spray all kinds of different stuff. We use MEK or Xylene to clean our stuff. Xylene is the only thing I've found that will clean Red-Ox primer.
  21. mortecai
    mortecai
    I used kleenstrip on my old NAPA spray gun. It worked really slick, but I removed all of the rubber parts first.
