I have a new girlfriend and as usual she is difficult...
Discussion in 'The Hokey Ass Message Board' started by lotus, Aug 12, 2007.
  1. lotus
    lotus
    from Taft, CA
    Whew...it was a long ride and I had a blow out on the trailer but I am home with the truck. Here are some pics.
    Me taking the spare off my truck and putting it on the trailer. I actually had to flip it around and run it backwards so it would not rub. Maybe not the safest but I made it home nice and slow.
    The sunset is really orange from all the smoke in the sky from california being on fire. It looks like it is snowing outside from the ash.
    I am not sure what this rearend is...does anybody know (I am thinking it is a 9" with re-drilled drums to match the camaro front clip bolt pattern)?
    I am happy to be home with the truck. I have to unload it in the morning and then go get a new tire for the borrowed trailer. When my friend dropped off the trailer when he heard I was going to long beach he was like oh...I do not know if the tires will make it as they are pretty tore up.
    I would like to thank everyone who helped load it up too. My friend that was supposed to go was a no show and my wife who went with me for company was busy studying for a state board test next week.
  2. NealinCA
    NealinCA
    Looks like 63-64 Chevy Impala. That is the same rearend I have under my 49 GMC.
    Neal
  3. lotus
    lotus
    from Taft, CA
  4. 49ratfink
    49ratfink
    chevy used those rears for p***enger cars only from 55 - 64. dont know what you call them...
  5. battersea boys
    battersea boys
    from surrey
    the weight distribution doesn't look right, It shouldn't push down the back of your pick up like that, or the hitch is in the wrong position. That's probably what made the tire blow overheating..... I talk from lots and lots of experience...
  6. 6deucecaddy
    6deucecaddy
    Cool adventure. Sorry I couldnt be there bro to help. My girlfriends mom was in town. Hope your happy with your truck. Post progress pics. Good luck.
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I agree with battersea boys..I haul all sorts of heavy **** on my 18' dual axle trailer..with my z71 and it dont look like that goin down the road..you have the load too far forward on that trailer. too much tongue weight..and those tires on that trailer ****! they do not look like trailer tires..there is a difference!
  8. lotus
    lotus
    from Taft, CA
    yeah the tires on that trailer are shot and I do not think they are trailer tires.
    I noticed it was making my truck squat. I should have had it back about a foot and a half to the rear (live and learn). My truck squats a little bit to the rear anyway but not as much as seen in these pics.
    I am also thinking I should probably had a hitch with a slight drop in it too since my truck is not stock height.
  9. Deuce Roadster
    Deuce Roadster
  10. You can also put the car on facing rearward so the engine weight is over the trailer axle(s). Oh, by the way, your new girlyfriend is kind of cute.
  11. lotus
    lotus
    from Taft, CA
    yeah she is kinda cute...a little rough and rusty around the edges but that ****'ll buff out.
    no engine/****** in this one.
  12. Al Von
    Al Von
    Nice scenery in the background of that tire-changin' pic!
    Forgive my ignorance, but what causes the big gap between the cab and the bottom of the front fenders on old pickups? Is it rusty cab mounts that let the front of the cab sink? I see old trucks like that all the time.
  13. Lil' Billy
    Lil' Billy
    from Georgia
    Is that a longbed?
  14. oldmule
    oldmule
    from Colorado
    Nice girlfriend, I bet she takes less money than the breathing kind to make you happy....
    On the trailer thing, A friend pointed out to me once this little tidbit.
    If the thing you are hauling on the trailer is only worth the cost of used or automotive tires, then it's no big deal. But why would you stick cheap tires on a trailer that is hauling something of great value to you? I buy car trailer tires now, and change them out every so often. I don't wait for weather checking.
  15. bwiencek
    bwiencek
    I'll agree with everyone that it was loaded too far forward - Here's a quick way to set tongue weight if you don't know how heavy the load is... measure the tounge with the trailer attached - then have 2-3 friends stand on the tongue to get ~400 or so extra on the tongue - take the difference then when loading the car measure the tounge and go for a little lower than that height - should get you close enough on a sub 4000 lb car... (i.e. 10%)
  16. lotus
    lotus
    from Taft, CA
    The front body clip is just sitting on there. The inner fenders need to be trimmed more so that the front body clip can sit properly on the camaro clip.
  17. lotus
    lotus
    from Taft, CA
    no. shortbed. the space in front of the rear fenders is larger on the longbed.
  18. Just Gary
    Just Gary
    I believe they're called "Hotchkiss" rearends when the gear set & entire center pumpkin can be unbolted and removed from the front side of the housing. My '55 Chevy's rearend looked the same (as mentioned in another response), as do 9" Ford rearends.
    After '64, Chevy went to the 10- and 12-bolt rearends, which had removable inspection covers on the back side.
    Good looking girlfriend. She looks like a keeper. ;)
  19. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Find my Camaro clip post- it shows you how to get the sheetmeytal attached the easy way.
    Killer truck! I love those things...
    and before you ask, a camaro (second gen) rear end is the right width to work with- the hotchkiss rear ends are not known for thier strenght- but they both have the same bolt pattern. 5 on 4-3/4
    and flipping the axle over the leaf is "easy cheesy".
  20. ls7gto
    ls7gto
    does the center chunk of the rear have a big P on it? if it does ill take if off your hands !
  21. lotus
    lotus
    from Taft, CA
    wish I had read this before I went under the truck. Next time I am out in the garage I will look.
    I got the front body clip off (just had to lift it off), the hood off, and the bed off today...all of which was easier then getting it off the trailer and in the garage by myself. hahaha.
  22. lotus
    lotus
    from Taft, CA
    already had it book marked! thanks for making that tech post too.
  23. 55 dude
    55 dude
    don't haul one loaded backwards! that puts the load on the tail and really causes the trailer to become unstable causing it to whip back and forth. if their is no engine and trans you can haul either direction.
  24. lotus
    lotus
    from Taft, CA
    Well The front body clip, hood, and bed are off the truck. I took a putty knife, wire brush, de-greaser, pressure washer to the front and rear frame and then gave her a bath in ospho. I will let that dry over night then wire brush it again and hit it with some primer to seal her up. I will do the same to the cab area when I get it off.
    I was told the camaro clip I have is from a 75. I wish there was a way to tell for sure. But if it does not matter then I do not care. I am going to put in the leaf springs that I have fixed up with new bushings and stripped down to four leafs (were 8) and put the ford 8.8 rear in the truck hopefully on friday. I am putting the rear ontop of the leafs and will notch the frame with some pipe.
    Here are some pics from tonight. Sorry they are not the best but it was dark.
    Just realized I really need to clean my shop too.
  25. lotus
    lotus
    from Taft, CA
    I had a pretty good day after work. I wire brushed the frame again then hit it with some primer. I am sure I will be wire wheeling some of it off for welding/cutting/boxing but oh well. I like having it primered instead of in bare metal. looks cleaner too.
    I took the old rear end out and started putting in my other leafs that have the new bushings in them. I also have the new rear end sitting underneath there and hopefully my new plate/shock mount thingies will be in on friday so I can snug it all together.
    Here are a few pics. There are 16 new ones in the folder. A link is available in my sig.
    These are the rear wheels I want to run but boy are they wide.
  26. You said girlfriend- I see twins!
  27. Lil' Billy
    Lil' Billy
    from Georgia
    I was wondering the same thing.
  28. lotus
    lotus
    from Taft, CA
    hehe...twins. My wife is the one that loves to call my hot rod projects my other girlfriends. I will have to tell her I have twins hidden out back. She will get a kick out of that.
  29. 'Cept they're not two 20-year-olds, they're two 50-year-olds :eek:.
  30. lotus
    lotus
    from Taft, CA
    ouch...but Bo Derek was born in 55 so it is not all that bad!
