gm 1 wire alternator question
Discussion in 'The Hokey Ass Message Board' started by Mockie, Aug 13, 2007.
  1. Mockie
    Mockie
    I have a 50 chevy, converting to 12v. I bought a gm 1 wire alternator, but am having trouble finding what to do with the connections from it to the voltage regulator, or if I need to keep the regulator at all. I've tried searching these questions with no luck. Any help would be great.
  2. touchdowntodd
    touchdowntodd
    run one wire to the battery, tape off the factory regulator wires in case you wanna return to stock, or pull it all out, you will never need it again.
  3. "touchdowntodd" said it all.
  4. Arizona Geezer
    Arizona Geezer
    Yup, what he said!
  5. Mockie
    Mockie
    thanks for the help to all, Can I still run directly to my charging guage or do I need to step back down to 6volts?
  6. what does a `50 chevy have to indicate charge?
    if it's an amp gauge nothing needs to be done....if it's a volt gauge 12 volts may peg the needle. keep in mind some gauges that look like volt gauges are actual amps
    if it has an indicator light...it will not work with a 1 wire alternator
  7. lewislynn
    lewislynn
    Go here for everything you want to know about 1 wire and 3 wire alternators.........http://www.madelectrical.com/electrical-tech.shtml
  8. hammrd29
    hammrd29
    well it tells you to run your 1 wire to the starter side where the battery connects
  9. lewislynn
    lewislynn
    You mean the battery side of your starter solenoid...the regulator is internal .
